Question about PSC Falcon 4420 Barcode Scanner
Label printing the scanner is printing the label before and the new label
How to print labels
Use Avery Label sheet.
Set correct paper size on Word and the Operating system.
Use label from Sheet feed tray only.
According to the printer specifications for the Officejet 8600 Pro Plus, the following label sheet sizes are supported;
HP Officejet Pro 8600 All in One Printer series N911 Manuals
Mar 15, 2016 | HP Officejet Pro 8600 Plus e-All-in-One -...
Zebra gk420d not printing shipping labels properly on ebay
You have to go to printer drivers on your Operative system, then open printer properties, general tab, you will be able to check the horizontal/vertical setting of the label there.
Mar 02, 2014 | Zebra Gk420d Direct Thermal Printer -...
How to print on transparency film on sharp ms 311ON
Firstly, make sure that you have copier safe transparencies.
Then follow the instructions below, except choose transparency instead of envelopes/labels. and make sure you choose the correct type from the print driver as well. They must match for it to pull the paper in.
How To Print on Envelopes or Labels on Sharp Printer
Dec 06, 2013 | Sharp "MX-3110N Color Copier, Printer,...
We're using 4.00 X 2.00 inch labels. The barcode is printing just under an inch long when it should be about 2 inches long so our scanners cannot read the barcodes. The text is printing out the
in some barcode software you can see the preview. if you click on the barcode itself maybe you can stretch it out to fit better. or try swapping to 2 by 4 format and see if that works. good luck
Aug 12, 2017 | Zebra ZM400 Thermal Label Printer -...
Barcode scanner won't read printed labels
1. The printhead in your printer might be scratched (evidenced by thin white streaks through your print). This is common, and the most likely cause. Printhead must be replaced.
2. Material might be stuck on your printhead (usually evidenced by wide white streak vertically through print). Printing surface of printhead can be cleaned with rubbing alcohol and cotton ball.
3. The ribbon might be wrinkling due to uneven tension, producing intermittent diagonal streaks in your print. This is somewhat common, but doesn't fit your description as well as 1 & 2 above. Mechanical adjustment and/or proper media loading solves ribbon wrinkles.
4. Poor pressure and/or printhead alignment. Evidenced by grainy, light or no print on one side or the other of the media. This is somewhat common, but doesn't fit your description as well as 1 & 2 above. Mechanical adjustment solves printhead pressure and alignment issues.
Dec 11, 2012 | Datamax E-Class E-4203 Label Printer
Failed to load the print preview or failed to print.
You need to run the Wasp software under an Administrative account or Right click the program Icon and select run as administrator (only need to do this 1 time, not over and over again). Once the program loads, set the label printer again by clicking file at the top left and selecting Setup Label Printer. Select your label printer. Now try printing the labels again.
Jul 19, 2012 | Wasp Technologies Inventory Control...
The labels from one of our heat sensitive label printers are unreadable by our barcode scanners.
Unreadable labels are related to the print head, make sure to clean the print head thoroughly with an alcohol swab and make sure the platen roller is clean also. After cleaning and it still is having issues scanner than you have bad sectors on your printhead.
Hope this helps.
Apr 14, 2011 | Zebra Desktop DA402 Label Printer
DYMO THINKS ITS OUT OF PAPER ....
New versions of the Labelwriter 400 (original and Turbo) do not take Generic Labels. It is an issue with the firmware Dymo have installed - it will only relabelwriter400.jpgad the genuine labels made by Dymo. currently there appears to be no work around to solve this isses.
The Dymo OEM labels have lines print on the back, if you use labels without these lines, the printer gives an "out of paper" error
The only printers in the Dymo Range that will take our generic labels are the Dymo Twin Turbo and the Dymo Duo (both the more expensive from the range).
Dymo have only made this change in the last 6-8 months, old 400's will work with cheaper generic labels
Aug 09, 2008 | Dymo LabelWriter 400 Thermal Printer
Won't read fonts
Please try to reset your scanner configuration, using some utilities from it's manual book (usually available at it's case/box), restore it (usually by scanning it) to original factory configuration or scan a label that would enable all symbologies.
Aug 03, 2007 | Opticon LGE1105RHHS-000 Handheld
PSC Falcon 4420 Barcode Scanner Logo
Top PSC Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Jax Planet
Jax Planet
Electric Dime
Electric Dime
Are you a PSC Computer and Internet Expert? Answer questions, earn points and help others
