Question about Samsung MW1030WA Microwave Oven
Does not heat the food
Everything works but does not heat the food
My smeg microwave will not heat the food ...... possible causes
If everything else is working but it won't heat the food, the causes are the magnetron "common failure" or the high voltage capacitor and diode can be a factor, the three work together to heat the food. Depending on the nature of repair it can be close to the cost of a new microwave oven.
Feb 27, 2011 | Smeg FME24X Microwave Oven
Lg 700 w microwave everything is working as normal but the food is not heating up
There three parts that will cause this, the first is the magnetron "heats food" the most expensive part, followed by the high voltage capacitor and diode, they work in conjunction to generate the high voltage to cook the food.
Feb 03, 2011 | LG Microwave Ovens
Microwave will not heat food everything else seems to work, timer, rotating plate everything works but heating food
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
=0=0=0=0=0=0=0=0=0
Sep 14, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Food will not heat everything else is working
If it does not heat, with all other functions working, the problem lies with the magnetron circuit. The magnetron is the part that makes the microwaves to heat the food. Typically, the magnetron fails and shorts out. Symptoms when this occurs is a loud hum from the oven and does not heat the food. The replacement magnetron costs are close to the price of a new microwave oven, so it rarely pays to have it fixed.
Feb 16, 2010 | Goldstar Microwave Ovens
Microwave has works but doesn't heat
Sounds like the Magnetron has stopped working. The Magnetron is is a specially designed powerful magnet that generates the high frequency microwave energy used to heat food.
Jun 14, 2009 | Magic Chef CMV1000B Microwave Oven
Once I place food in to get re-heated, I noticed that my microwave did not heat the food, even though everything else worked...can you help
time for a new one. the microwave unit is dead, no the oven. the microwave unit is the heart of the oven. so, if that goes, everything else goes.
Apr 07, 2009 | Maytag MMV4205 Microwave Oven
My micro wont heat the food but everything else seems ok
I have a GE Spacemaker Microwave, model # JVM1650WB008
The lights work and everything runs in a normal operation, it will not heat the food. I have changed the fuse and still the same, no heat.
Oct 05, 2008 | Microwave Ovens
MICROWAVE NOT HEATING
I have the same problem. Everything seems to work except it doesn't heat up food.
I remember last time when it was working. I pressed the start botton before I closed the door. So it didn't start automatically, and I pushed start and it worked(it still heat up the food), but it doesn't work now. Help Please!!!
I have a Whirlpool Gold GH5184XPQ.
Thanks in advance
Aug 27, 2008 | Microwave Ovens
Microwave won't heat food.
built in 3/94 is it worth fixing how much for magetron
Dec 30, 2007 | Maytag MMV1153A Microwave Oven
Samsung MW1030WA Microwave Oven Logo
27 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Devabhakthuni...
Devabhakthuni...
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
