Question about Uniden 5.8GHz Dual Cordless Phone
How do I work the intercom
Just want to know how to work the intercom
NEC DSX 22B intercom light won't stop blinking
A double-wink on the Intercom button indicates "Intercom Hold". Normally, lifting the handset and possibly pressing Intercom will take care of it. We had a phone for which that didn't work. In that case, use DSX System Administrator 3 to reset the station port. On the left side of the main window, click Reset Station Port under Utilities. Enter the extension number and click Start. It takes a few seconds and does not disturb other parts of the phone system. Hope this helps!
Aug 02, 2013 | NEC 1090020 DSX 22Button Display Phone...
Novi doorbell intercom system won't work. Got it about 8 years ago, worked OK except for minor problems until recently. Now it malfunctions constantly. We finally had to disconnect the wiring o
If you are looking for new intercom system then I would suggest you to buy it from http://www.hulksecurity.com/ .Hulk Security System not only provides intercom systems but they also offer variety of access control system, CCTV and alarm systems. Well, I hope this would help you and have sorted the concern for intercom system.
Oct 24, 2012 | Novi Wireless Doorbell Intercom Security...
Intercom does not work
There needs to be an additional instruction. I am having the same problem. From standby mode, I press Intercom, the screen says "Please wait" for 2-3 seconds, then I choose a handset. Nothing happens. The user guide doesn't have any additional instructions after this point. I don't hear any paging or anything other than silence on any handset.
Jun 15, 2011 | Uniden D16602 Twin Cordless Phone
I need to know how to page another extension. Our Avaya phones do not have the intercom button. I thought there should be a function code to program a button for Intercom, but I'm not finding it. I need to...
There are 2 buttons right below Line 1 and Line 2. Those are both intercoms.
When paging a phone, you just insert a * (star) before the extension number.
SO, Intercom*11, will page extension 11
To program on a button, feature 00, press the button you want to program, then press the left intercom and *xx (where xx is the extension number)
As far as paging all the phones, you will need to have them in a calling group (1-4), hten you can page the group to page them all.
Jan 19, 2010 | Avaya 700340193 Corded Phone
Intercom on one of the office phones has stopped working?
Press Feature * 0, then press the button you think is the 2nd intercom button. What does it say on the display?
Chances are that the button got erased. Do you know how to get into system admin programming?
Jun 25, 2009 | NorStar M7208 Corded Phone
Need to buy 2 more telephones compatible with the ones we have
Any 4 line analog phone will work. However intercom will only work on RCA
Mar 18, 2009 | Lands Phones
Interference in our wireless intercom
Wireless routers operate on 2.4GHz frequency. It's very possible that your intercom is in the same frequency range causing inerference. Try and find the frequency your intercoms operate on. If you can't find it on the unit, search the internet for the name brand and maybe you will find the info. If this is that case, (as I suspect it is), the only alternative I can suggest is to change your intercoms. Be sure to check the frequency of the new intercoms before purchasing. Anything but 2.4GHZ should work fine.
Feb 24, 2009 | Radio Communications
CD player on Nutone master intercom
Turn off the switch to the Nutone intercom system on your main electrical panel for 10 seconds, then turn on, reset unit and it will play!
Oct 09, 2008 | Audio Players & Recorders
My intercom button flashed red to green. When I push a line button, I get a two-tone beep but no dial tone. I changed the internal 9 v battery. I unplugged the phone and waited, then plugged it back in....
Each telephone must be connected to line 1 and line 2 for
proper operation. The remaining lines 3 and 4 may — or may not —
be connected to each station as you desire. First plug in the battery, then the phone lines (1 & 2 are mandatory), and third the power cord. If your intercome LED is blinking red and green, then press: STORE IN, followed by "INTERCOM" followed by a free intercom# (i.e., any of the memory buttons 1 through 16 not already assigned to another telephone set). Then wait for the phone to go through its initiation sequence during which it searches each of the four possible lines. After that concludes, you should get dial tone on your active lines. :-) Marco
Aug 29, 2007 | GE 2-9450C Corded Phone
Uniden 5.8GHz Dual Cordless Phone Logo
19 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
