Question about Graco Symbio Stroller pushchair raincover basket logico S adaptor - Moon
Need new ig wheels for synbio b
The big wheels will not pump up so need new ones
95 Taurus 3.8 SHO wont start replaced everything fuel pump to big relay is buzzing even new one im lost need help
Run tests. Fuel pressure correct? Spark at plugs when cranking? Fuel injector pulse working? Compression test?
Apr 06, 2015 | Cars & Trucks
93 geo prism fuel pump fuse location?
why not just use voltmeter, to check all fuses for hot both sides? key on. (need a video?)_
why not post symptoms then ask a question.?
must we send for ever looking for that which doesnt exist.?
and did you know there is more than one engine?
and both are wired different with different EFI systems?/
4A or 7A? engine, its a toyota corolla btw.
eg:
pump pressure is zero. (gages)
i check relay, the FP relay is closed.
i check the relay input and no 12vd.
sure bad fues, is there is one.
but on many cars , lots of other things go dead too. with this fuse.
ill now guess 4a engine with coin toss. vin code 6, engine,
i open glove box. and see the book the opr guide (yes buy one)
and turn to fuse page.
or login to alldata.com and stop guessing.
i look under prizm and corolla, 93 for best clues. (big hint, wink)
this EFI has 2 relays, one is the main relay,
other is fuel pump
the main sends power to the pump relay.
so there are 2 fuses,
one is marked
EFI-Fhtr fuse
and
IG coil. fuse
the main relay drops out of the transmission A/T is not in park or netral.
if manual stick car, the clutch switch does the same
alldata.com
look up your car, your trans, your engine.
and see the schematics.
Aug 28, 2014 | 1993 Geo Prizm
NOISY SQUIRELL CAGE ON A CARRIER AC/HEAT PUMP OUTDOOR UNIT
Not unless its a belt driven wheel. If not no grease will help just make a big mess. Take the fan assembly out, take motor off the wheel, take wheel out of the assembly wash wheel with hose, dry reassemble. Or just go buy a new wheel but check your shaft on the motor if loose get a new motor also.
Mar 15, 2013 | Carrier Heating & Cooling
I need to install a new ignitor switch for my Amana oven. Can you tell me what I need to do.
Hi, What you are going to need to do is remove the drawer and the floor of the oven. Make sure the power is off take the flame spreader out by removing the nut in the middle. then take the 2 screws out holding the old ig-niter. Then from the front reaching through the drawer area un plug the wire harness for the ig-niter. Some generic ignite-rs will require you to cut and splice the wires and join with wire nuts, you can splice into either wire on the ig-niter. once the wires are joined and making sure all wires are tucked to the back re install the new ig-niter with the 2 screws. The put the oven back together in reverse order.
If you have any additional questions please feel free to comment. Mike
Dec 09, 2009 | Amana Kitchen Ranges
How do i relieve the pressure to replace the fuel filter?
 Disconnect the wiring connector of the fuel
pump.
 Crank the engine for more than five seconds.
If the engine starts, let the engine run until it
stops.
 After turning IG switch OFF, connect the wiring
connector of the fuel pump.
 Disconnect ground cable from battery.
2) Loosen the screw of the hose clamp and pull
off the hose from the filter.
3) Remove the filter from the holder.
4) Replace fuel filter with a new one
Nov 11, 2009 | 1997 Subaru Legacy
Robo Kleen pool cleaner troublshootong
One thing that you might want to try on these pool cleaners is removing the limit screw on the axle for greater angle of tandem wheels. Make sure your filter bag is not clogged or partially clogged because this cause restrict movement. Check for debris jammed in your drive system (wheels, axles, etc.)
Aug 16, 2009 | Smartpool Pool Hog Ig Robotic Automatic In...
Polaris 280 - tank track keeps coming off
I battled with the track falling off for over a season. The pool guys said they fixed it. Tried the previous solution to adjust middle wheel but no luck. My solution was to remove the left wheel and the tank (to get to the screws). The wheel mount allows for minor adjustment but it is also reversible. Turn the mount around and this will extend the wheel base much more. Mine ran for several hours after doing this and so far the track stays on.
Dec 28, 2008 | Polaris 280 In - Ground Pool Cleaner with...
Graco Symbio Stroller pushchair raincover basket logico S adaptor - Moon Logo
27 people viewed this question
Top Graco Baby Gear Experts
Joyce Nokleby
Douglas Dinnebeil
Douglas Dinnebeil
Dennis Crouse
Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
