My machine won't work.
The solution that was sugested for my copier did not work. someone had sugested that I reset the code to zero, but they did not tell me how to do this. I had paid already, so my problem is still pending.
  • 30 Answers
I'm afraid that I need more information in order to be of any assistance. Make model and the original problem would be essential.
Let me know and we'll see what we can do.
Bill Monroe
Posted on Oct 31, 2007
    An user who is expert in 3 categories / brands.
  • 1,362 Answers
What is the problem? please repost.
Default codes for reseting after fixing u code prob on xerox 5328
It has been a while since I worked on one of those but..
If it was for a fuser web you want to, power the machine off. Then hold the Zero button while you turn the machine on. That will enter it into diagnostics. Then enter 10, then press start, press 65 and then enter zero and start to reset that.
If it is still coming up with the code. then press zero as you power the machine on and then enter, 20 then start, then 3 then press start.
It also could be enter 20 then start then 5 then start. One of those two will clear out the fault and reset the machine.
Feb 19, 2010 | Xerox Office Equipment & Supplies
you can reset you unit to go back in zero code
Oct 28, 2007 | Office Equipment & Supplies
Konica minolta biz hub C250 need to reset admin code URGENT
you cannot overide the administrator password on the konicas the default password is 12345678 try that
Oct 30, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
L6 is a Polygon Motor Lock.
Unfortuantly there isn't a whole lot you can do. You can try and reset the code, but most likely you will need a Certified Sharp Rep to replace your LSU.
To reset,
Make sure your machine is awake and ready to copy.
Simply press,
c, *int*, 0, *int*
(Clear, interrupt, zero, interupt)
The machines screen will flash blank.
Simply type in
and press copy.
The machine will reset the code and restart.
If this does not work enter sp modes again.
and try code '16'
Willi Williams
Service Engineer.
Aug 17, 2009 | Sharp Office Equipment & Supplies
How to change counter reading in ir8500
You can not. The chip needs to be reflashed by Canon in order to be reset to zero
Jun 18, 2009 | Canon Office Equipment & Supplies
Af2045 always shows sc 990
if you are getting the sc990 code, you will need to have someone come out and do preventative maintenance (PM) on the machine. the 990 code has to do with the drum quality, and the only way to fix it is to, at least, have the drum unit rebulit.
Apr 02, 2009 | Ricoh Aficio 1035 Copier
I thank you for the help, I still have the problem, I have no Admin Password nor do I have an access code for a Toshiba e-studio 211c Copier, I did as sugested, neither passwords worked, then I went to 0 &...
O8 - 653 is the correct code for the administrator. Whatever number is displayed after entering 653 should be the admin password. Otherwise you can just enter a new password while still in 653 to overwrite the old one.
Mar 30, 2009 | Toshiba E-STUDIO 211C Copier
Showing h4
If your machine is AR-5316,
The problem is in the fusing unit try these steps:
STEP1: Press continuously CLEAR then INTERRUPT then ZERO then INTERRUPT
STEP2: The panel display will turn off it means that you are inside the simulation if not repeat again step1.
STEP3.Then type 14 then press the print button
If these steps doesn't work you must call an authorized serviceman to check your machine, maybe something is busted on the fusing unit like thermostat or fusing lamp.
Mar 04, 2009 | Sharp AR-5316 Advanced Digital Imager...
H-3 error code in a Sharp ARC260m
The analog Sharp copiers used the crop code (clear, repeat, zero, pause).  Once the digital models came out the rules changed.  Sim 14 was for the analog copiers as well.
A good resource to get the answers you need is  They have Sharp copier technicians on there who can help you with the problem.  Unfortunately I only work on the low end Sharp models (for their product line).  The service codes are different on that machine. Copytechnet is a free service and they only deal with copiers.
Oct 03, 2008 | Office Equipment & Supplies
ID Code for KM-3035
i want to change the id code for km 3035 kyocera how to chang
Jul 30, 2007 | Kyocera Mita KM-3035 All-In-One Laser...
