Question about CoverBot iPad mini Keyboard Case and Stand HOT PINK - Aluminum Bluetooth Keyboard Case with Integrated iOS Command Keys for iPad mini
Can't get CoverBot iPad mini Keyboard to work
Paired my CoverBot Ipad mini keyboard, entered pass code, it worked, now it doesn't and I can't seem to get it working again. I don't seem to be able to get the keyboard do more than connect with my Ipad. I hit the Bluetooth option in Settings, push connect, hit the keyboard option in settings, and try the troubleshooting steps, but I can not get another passkey and don't remember what the original one was. Please help!!
How do I get my Coverbot to connect to my IPad air with bluetooth
Check your batteries in the Coverbot to make sure they are fresh. Next, make sure the Bluetooth is turned on within the iPad. Make sure the Coverbot is turned on. Click on the "Search for devices " in the Blutooth menu on the iPad. When you see your Coverbot come up, click on "Connect".
Attached is a Coverbot Youtube video, it may be of help to you. Also, attached are the directions from Coverbot. Good luck!
Nov 25, 2014 | CoverBot iPad mini Keyboard Case and Stand...
How to pair bluetooth keyboard with ipad mini?
Hi Douglas.
1. Switch on BlueTooth on your keyboard.
2. Enable BlueTooth on your iPad.
3. Search for devices on your iPad.
4. Press button if available on keyboard to get discovered.
5. Select keyboard when shown in devices list.
6. Enter pairing code sometimes 0000 or 1234.
7. Use and enjoy.
Hope this helps!
Here is the Apple site instructions:
Using Bluetooth headsets and keyboards with iPad
Here is another that explains how to do it on a MAC, might give you some clues as well:
Bluetooth How to set up your Apple Wireless Keyboard
Here is a good independent site, maybe start here:
iPad How to pair connect any bluetooth keyboard
If you prefer to watch how to do it on YouTube:
How to Connect Pair Bluetooth Wireless Keyboard to your iPad
Nov 18, 2014 | Mini Cars & Trucks
Manual
keys type all sorts of symbols,try altering the arrow key or symbol key to the left of the spacebar
Sep 03, 2014 | CoverBot iPad mini Keyboard Case and Stand...
How do I connect my Kensington folio via Bluetooth to my iPad 2?
I did not see any other comments, but to address the pairing issue between your Keyboard and iPad.... If your product is the actual KeyFolio Expert Multi-Angle Folio.
The KeyFolio Expert Multi Angle Folio and Keyboard uses a solid plastic frame to attach to the iPad. It's easy enough to slide the iPad in and out of the frame but the design means the case only works with the 4th and 3rd Generation iPad's and is not compatible with the iPad 2 or the original iPad.
Connecting the KeyFolio Expert case to your iPad is a simple process. Simply hold down the power button for over five seconds to put the keyboard into pairing mode and go to the Bluetooth settings menu on your iPad to connect it. Enter the four digit numerical code on your iPad when prompted to finalise the connection.
Pulled from:
Kensington KeyFolio Expert for iPad
If you do not fall under that product, try these steps - they shuold be the same for most of Kensington's Products:
Connecting the Bluetooth keyboard to your iPad is a simple process. Simply turn it on, press the connect button in the top right corner of the keyboard and go to the Bluetooth settings menu on your iPad to connect it. The iPad will prompt you to enter a four digit code using the keyboard to finalise the connection. (the code should be 0000)
Pulled from:
Kensington KeyFolio Pro 2 for iPad
Let me know the outcome.
Jason
May 05, 2014 | Kensington Folio Case Stand for iPad,...
Cannot get ZAGG keyboard pair to iPad
Check that the keyboard's battery is working and it's on. Turn on Bluetooth on the iPad (Settings > Bluetooth). Press the keyboard Connect button. Choose the ZAGG Keyboard on the iPad, and type the code on the keyboard.
This doc describes the process: http://cfprod.zagg.com/downloads/ZAGGfolio%20instructions/ZAGGfolio%20instructions.pdf
Good luck! :)
Mar 25, 2014 | Apple iPad Tablets & eReaders
Ipad and beikin keyboard
You will need to enable bluetooth on your iPad and then pair the keyboard to the iPad. Try the following:
  • On your iPad, tap the settings icon from the Home Screen.
  • Tap on General.
  • Tap on Bluetooth.
  • Toggle Bluetooth to On
  • Turn on the Belkin keyboard.
  • The keyboard will show up under Devices on the iPad.
    Select Belkin Bluetooth Keyboard.
  • A code will appear on the screen.
    Enter this code on the keyboard and click Enter.
A message will pop up when pairing is successful. If pairing fails, repeat the steps above. If you're still unable to pair the two leave a comment and I will help further troubleshoot.
Hope that helps!
Jan 15, 2014 | YouTube Videos
Up wand down buttons won't work on coverbot iPad Mini keyboard case
if its nt working for ipad mini..thn software may hav been corrupted.
if the up wand down buttons totally nt working with any program or device then it may b a hardware problm!!! bttr tak it to the service center of the product.!!!
Jan 04, 2014 | CoverBot iPad mini Keyboard Case and Stand...
IPad does not pair with keyboard
This article should help you
http://www.tuaw.com/2010/04/05/found-footage-how-to-connect-an-ipad-to-your-existing-wireless/
Apr 05, 2010 | Apple iPad 16 GB 3G Tablet PC
CoverBot iPad mini Keyboard Case and Stand HOT PINK - Aluminum Bluetooth Keyboard Case with Integrated iOS Command Keys for iPad mini Logo
98 people viewed this question
Top CoverBot Computers & Internet Experts
David Payne
David Payne
Are you a CoverBot Computer and Internet Expert? Answer questions, earn points and help others
