Question about Nikon Coolpix 4300 Digital Camera
There are white lines in monitor of my nikon s4300...help??
My son dropped the camera now all that shows on the monitor is white lines...the screen is not cracked or bleeding or anything how can i fix this??
    Top Expert:
  • Nikon Master
  • 6,702 Answers
I'm afraid only a technician can repair this. Perhaps some parts must be replaced.
If the camera still makes good pictures, perhaps you better learn to live with the lines. Check is the white lines appear on an image you view on your computer. If so, the sensor or processor is damaged. Then you better start looking for a new camera, because that will be cheaper than to repair you S4300
Posted on Mar 21, 2014
SOURCE: Directions to replace LCD screen for nikon D300
You can find a replacement LCD screen for Nikon D300 in this link:
http://www.pantallas.biz/epages/wwwpantallasbiz.sf/en_GB/?ObjectPath=/Shops/160419/Products/%22Nikon%20D300%22
I hope it helps.
Ignacio del Olmo
Posted on May 30, 2009
dlundmark
  • 797 Answers
SOURCE: coolpix nikon digital camera
This sounds like a broken or cracked LCD screen. The backlite is working, thus you will get the white screen. The LCD could also be disconnected internally, or has other problems. But this is a direct problem with the LCD.
A camera like this can usually take pictures, and you may be able to use it to set the menus by using the video cable to the TV or computer screen (some flat screens have video inputs).
Posted on Jul 25, 2008
  • 4 Answers
SOURCE: nikon d90 lcd screen
clearly not good! bring it to a repair shop is the only thing to do I guess.. good luck with it!
Posted on Oct 29, 2009
  • 126 Answers
SOURCE: white lines in photos
CCD unit is not working properly, take it in for repair.
Posted on Mar 26, 2010
lock123
  • 6831 Answers
SOURCE: The camera is Nikon S3000. It was dropped with the
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Feb 08, 2011
THE RECHARGEABLE BATTERY WILL NOT WORK
There are two possibilities. First, the camera's internal charger may be defective or second; there may be a defective circuit in the camera that is draining the battery. I would buy an external battery charger and try recharging the batteries outside of the camera. The chargers are not too expensive. If that does not solve the problem, you need to contact Nikon for repair information at 1-800-Nikon-US (1-800-645-6687) 9AM-8PM EST, Monday to Friday.
Jun 26, 2014 | Nikon COOLPIX S4300
Stuck on please wait
Check your current firmware version before beginning:
  1. Turn on the camera.
  2. Tap the menu tab at the bottom of the monitor to display the setting controls and tap Setup (wrench icon)
  3. Tap Firmware Version in the Setup menu(wrench icon)
  4. The cameras firmware verison will be displayed.
  5. Turn off the camera.
Basic Download and Installation instructions: (New firmware versions contain all previous versions.)
Windows
  1. Create a new folder with an appropriate name on your computer's hard disk.
  2. Download F-S4300-V12W.exe to the folder created in step 1.
  3. Run F-S4300-V12W.exe to create the folder titled S4300Update, containing the following:
    • firmware: folder containing the firmware.bin file
    • firmware.bin : the firmware located inside the firmware folder.
  4. Insert the memory card containing the firmware folder into the camera and turn on the camera.
  5. Tap Firmware version in the Setup menu and follow the instructions displayed to upgrade the camera's firmware.
  6. After the upgrade is complete, turn the camera off and remove the memory card.
  7. Check the Firmware version item in the setup menu to confirm that the camera's firmware has been upgraded.
For detailed instructions, please see the PDF files below.
Macintosh
  1. Download F-S4300-V12M.dmg.
  2. Double-click the F-S4300-V12M.dmg icon to mount the disk image titled, F-S4300-V12M.
  3. A folder titled S4300Update, containing the following files, will be created inside the disk image:
    • firmware: folder containing the the firmware
    • firmware .bin: the firmware
COOLPIX S4300 1 2 firmware update Nikon Knowledgebase
Mar 28, 2014 | Nikon COOLPIX S4300
Black screen
Oh my Gosh, that the worst thing you could have done. please take up fishing or demolition our product is now damaged and will have to be repaired at a nikon service center they advise you futher.
Jan 22, 2014 | Nikon Coolpix S4300 16.0-Megapixel Digital...
Nikon coolpix s4300 date and time problem
the default time is set to military. in the setup menu find the default settings and change the time setting.
Mar 25, 2013 | Nikon Coolpix S4300 16.0-Megapixel Digital...
Why my coolpix s4300 will not charge
How old is the battery in the camera? Most rechargeable batteries will eventually lose their ability to charge. Usually one cell of the battery fails and the battery never reaches full charge. If the battery is more than a year old, replace it. The Coolpix S4300 uses the EN-EL19 and suggested retail price of $41.
If you have tried a new battery, I would suspect a problem with the charging port. That isn't something I recommend fixing yourself.
I hope this helps.
Jan 04, 2013 | Nikon 26304 Coolpix S4300
Camera constantly takes blurred pictures
Appears that the auto focus mechanism is not working, This anomaly is most obvious in lower light situations when focusing is much more critical.
If the camera was new and two months old I would either return it for another one or have Nikon repair the lens assembly under the terms of its warranty.
Aug 30, 2017 | Nikon Coolpix S4300 16.0-Megapixel Digital...
Nikon coolpix s4300 keeps saying file contains no image data
Call Nikon they can fix it they ask you to send it to them and they tekk you how much you send it and they fix and mail it back it shouldnt cost that much nothing is broke.
Jun 11, 2012 | Nikon Coolpix S4300 16.0-Megapixel Digital...
Nikon D2X camera dropped it takes pictures intermittently.
i'd take or ship the camera to Nikon, or an authorized Nikon service center, for repair. you're unlikely to get around this problem any other way. good luck...
Mar 03, 2009 | Nikon D2X Digital Camera
Nikon Coolpix 4300 Digital Camera Logo
82 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
