Question about Kenmore Kitchen Ranges
I have a self-cleaning, smooth surface kenmore stove mod # 95002100. I lost power during a storm, and the surge created some type of error code - ''E1 -F1-''. I am renting and do not have the manual. The stove works, but the oven won't, can't figure out what it wants. Have unplugged, but error code just comes back.
catriver
  • 878 Answers
SOURCE: My display window reads e1 and f1 and we can't get anything to work
tholt, for the model posted F1 E1 is a eeprom error in the board. Try pressing and holding cancel/off key for 5 seconds. If that doesn't work unplug or disconnect the power for 1 minute. Plug it back in, if the error comes back it probably is a bad control board. Most common cause of control failures is caused by corrosion on the connectors. I would seat and reseat all the connectors to the board, including the keypad ribbon. Give this a shot and post back, Catriver.
Posted on Apr 20, 2007
fridgetech
  • 473 Answers
SOURCE: Crosley Range
Here are the fault codes for Crosley ovens:
Failure
Code
Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (usually the touch pad)* F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC) F2 Oven too hot Replace relay board (if present) or bad oven temperature sensor F3 or F4 Open or shorted oven temperature sensor Replace oven temperature sensor F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Check for proper voltage F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or un-stick button F8 Analog/Digital supervisory Replace clock assembly (also called the ERC) F9 Door latch supervisory Check door lock circuit or replace clock assembly (also called the ERC) F0 Function key stuck Replace touch pad or clock assembly (also called the ERC)
Posted on Oct 27, 2007
ngfam1
  • 639 Answers
SOURCE: Whirlpool Super Capacity 465 Stove
Hi bigdawg,
Happy to help you!
for this problemI would advise you on this occasion to call service.
These guys are good!
A&E factory service does most brands warranty services.
They are open 7days/24hours nation wide.
call tonight! 1-800-905-9505
I am happy to assist you!
Neil
PS. Before you leave this site please leave a "Problem Solved" rating for me on fixya.com
Posted on Aug 25, 2008
SOURCE: E1 F5 error on self cleaning oven
Press the self-clean button. The panel becomes blank(---), then press the up arrow( ^ ). The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning.
This code means the control has detected a problem with the door latch switch. Switch is defective and needs replaced. Part # is W10107820 and cost is $39.99. You can get it at http://www3.sears.com/.
Before calling a repair shop,go to the circuit breaker box and turn off the power to the oven. then turn it back on and then see if the door is released and the error is cleared.
its probaly bent door latch or door sensor gone bad. try pushing on the door when you start the clean cycle see if that helps.
if not our suggestion would be to replace the part....
good luck...
if you got insight into your problem from us , A very helpful rating is appreciated for answering your question
Posted on Aug 10, 2009
tbirdfan1
  • 3051 Answers
SOURCE: An F1 error occurred when self-cleaning. I've
hello there:
On Magic Chef ranges, F1 usually indicated a defect in either the keypad or the electronic control. If the error shows when the keypad is disconnected from control, the problem is usually in the control. If the error ceases with the keypad disconnected, the keypad is usually the cause.
On some models the keypad and electronic control are 1 integral part in which case the whole control assembly usually has to be replaced to correct the problem.
: Until you can get this part replaced you can disconnect the ribbon cable from the board and the error should go away can
: disable the beeping? if this is happening
The buzzer circuit may be able to be separated from the rest of the control. If wired to it, the wire(s) may be able to be cut. or removed
hope this is very helpful for you
Best regards Mike
Posted on Jan 19, 2010
Kenmore stove
This is the link to the instructions for troubleshooting the error on your stove. You may need to replace a part.
http://www.applianceblog.com/mainforums/threads/34276-F10-Error-when-using-bake-or-self-cleaning-seems-to-work-fine-when-using-broil
Nov 29, 2013 | managemylife.com
F-10 error code on stove
What Kind Of Stove? The following is for troubleshooting an F-10 error on a Kenmore stove:
My oven is flashing a F10 code and the door is locked. This happened while the oven was in self cleaning mode
more than likely the tco thermal cutout fuse has opened during cleaning and now the ovens latch motor cant get power to open,its under the top cover where the surface elements are located its a frequent thing with all ovens/stoves
Jan 12, 2013 | Kenmore 40494 / 40495 / 40499 Electric...
My kenmore model 9114552192 drop-in oven keeps defaulting to F1
That error means either the main board is bad or the temperature sensor is bad, most commonly the temperature sensor/probe is bad and needs to be replaced. If you need detailed instructions on making this repair than visit the link below.
Appliance Repair Help With Live Chat
Mar 26, 2017 | Washing Machines
After self- cleaning my Kenmore Gas Range, I have not been able to get the 'Cooktop Lock' light turned off! So while I can use my oven for baking I can't turn the gas on the top of my stove! I have...
This may be a silly question but, did you just try turning off the circuit breaker for a couple minutes to see if it resets itself when you flip it back on?
Nov 21, 2010 | Kenmore Kitchen Ranges
Oven went in self cleaning mode and shut off door unlocked f90 error code will not bake
During the cleaning cycle, there was a temp sensor malfunction that may have damaged the temp sensor. this is a common occurrence with this model. this is refereed to as a runaway temperature code. the sensor lost control of the cleaning cycle and it got to hot. the temp sensor is fried and it will need to be replaced.
May 22, 2009 | Stoves Ovens
Kenmore Select Clean Self-Cleaning Electric Range Model 6659580
This means you hace a problem with your clock. Take the back off the stove and then pull the ribbon connector off the clock and clean the terminals. If that doesnt fix it replacing the clock should fix it.
Nov 16, 2008 | Kenmore 91112 / 91114 / 91117 Electric...
Error code E1 -F5- Broil element comes on and wont shut off
if it is a whirlpool, kitchen aid or kenmore by whirlpool you need to check the self clean latch asembly found on the rear of the unit. check the micro switches with an ohm meter. always remember to unplug the oven before you test any thing or replace parts. not sure why the broil wouldnt shut off. but the f5 error is definatly related to the door latch.
Sep 06, 2007 | Kenmore 95822 / 95824 / 95829 Electric...
F1 Error code
i just had this same issues happen after running the self clean cycle. f1 error, fan would come on, fan would turn off. its not the control board, its the temperature probe. I picked up the part for 40 bucks and put it in myself. plugged the stove back in and it was good to go. the old temperature probe's wires melted during self clean. note to self: clean you over the old fashion way with some elbow grease.
Mar 30, 2007 | Kenmore 46123 Stainless Steel Electric...
Kitchen Ranges Logo
Top Kenmore Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
