Question about Dell Office Equipment & Supplies
Get out sleep mode
I want to keep a dell b1160 out of sleep mode to enhance first print time
3 Suggested Answers
SOURCE: dell axim 51v
I have the same problem. Its from an over sensitive switch. You arent actually opening the battery case you are pressing against it. This triggers the switch and makes it think you are taking the battery latch off. I haven't actually tried it but you could open up the Axim and cut the cable going to that sensor/switch?
Posted on Mar 11, 2008
SOURCE: Monitor keep going into "sleep" mode
try to reseat the memory modules and restart the computer and computer boots to normal mode/then go to power options in control panel and disable the sleep mode option for the hard disk
Posted on May 14, 2009
DEll latuide E6320,its Freezed when i keep for long time not working , Goes to sleep mode
Right click on the battery icon and choose power options (depending on OS, it may be called something else) to change the timing.
Dec 28, 2016 | Dell Computers & Internet
Disable power saving mode
Sorry, but you will NOT be able to DISABLE the power saver mode on this printer. The printer will still go into "power saver mode", but it takes longer to do so, if you set diffrent as default time delay [ Two power saver modes: (1) print to standby mode 35 Watt, user-definable 1-30 minutes, default 3 minutes ; (2) print to powersaver mode 4 Watt, user-definable 5-60 minutes, default 10 minutes ].
See also:
Dell 1250C problems with sleep mode
Oct 01, 2014 | Dell 1320c Laser Printer
Dell Inspiron 530s Desktop fan motor keeps running
It\'s NOT the fan. Check the power save settings on the computer ITSELF. Check your BIOS settings as well. Inspirons ALL do the same thing with waking up.
Nov 05, 2013 | Dell Inspiron 530s Desktop Computer
Dell xps400 usb keyboard driver
http://download.cnet.com/input-multimedia-usb-keyboard/3000-2110_4-108663.html
This package supports the following driver models:
hope it helpa you
Oct 18, 2011 | Dell (002TR) Motherboard
My Dell Monitor keeps going into sleep mode immediately after booting up.
Make sure your computer's screen resolution is fine for that when you power up the computer press F8 key 5 to 6 time untill you can see safe mode and other menu if you are able to see safe mode then enter in enable vga mode then enter as admnistrator go to control panel->display property ->settings change screen resolution to 1024*768 then apply and restart it.Let me know if you need further assistance.Thanks for using FixYa.
Aug 03, 2011 | Dell Dimension 4600 PC Desktop
Will not display
For clarification, may I know how long that your computer before it going to sleep mode?
You can change the settings on how the computer hibernate or gone to sleep mode by going to display properties >> click on the screen saver tab >> clcik on the Power button. There you can set the time on how long the computer will gone to sleep.
Let me know for any clarification.
Jul 08, 2010 | Dell E173FP 17" LCD Monitor
Low battery warning
That is because while a computer is in sleep mode, it is still using power to keep the memory. The battery is only used when the computer is turned off. You should replace the battery as soon as you can in order to keep your computer running properly.
Jun 29, 2009 | Dell Dimension 2400 PC Desktop
Check the power setting in control panel of windows. If you have a monitor from another computer swap them and see if the problem stays with the computer or monitor.
May 12, 2009 | Dell Dimension 3100 PC Desktop
Infrequent use of Xerox Phaser 8500
The reason he told you that is because ;
if left on permanently the fuser unit has a lamp ( nowadays the newer ones use a ceramic) the lamp continually comes on to keep the fuser warm and ready for you to print.which may cause the lamp to burn prematurely, most business keep theirs on all day with out the sleep mode( too busy to wait to warm up),
But, when you use the sleep mode most models do not turn on the lamp ( if it does it only puts out minimal power) but keep the power ready, which is why when you go to print it takes awhile to warm up.
The lamps are very resilient and last several years before having to change.
Jul 17, 2008 | Xerox Phaser 8500/DN Printer
23 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
