DRC69705E22 region code
RCA blu ray/ dvd video player won't play regular dvd any longer
Laser assembly has lost the ability to focus and play back. Replace unit since repair not cost effective.
Dec 19, 2016 | RCA Televison & Video
RCA DRC69705E22 manual
I have the Rca portable dvd player model numberDrc69705e22 I am looking for the male to male usb cord that connects the two screens. I cannot find it anywhere and the male to male usb cord I founded not work because it was for a computer.
Feb 19, 2014 | RCA DRC69705 7"" Dual Screen Portable DVD...
Rca drc69705e22 pinout
Its used to connect the the two 7" screens together only. Cant hook up to computer.
Dec 30, 2013 | RCA Televison & Video
I own a 5-DVD Changer with a Home Theatre System. It is an LG Model # LH-E932TB. It was working great then all of a sudden it now says ''CHECK REGIONAL CODES''. Does anyone know what to do...
Have you changed the Regional Code of the DVD changer? Changing of Regional Code of the Changer is permitted for 5 times. To view movies of different region code, some people change it. Suppose you or someone have viewed a movie of different region movie after changing the region code & now you are trying to view a DVD of your region. In this case you will have to change the region code to your region. Changing of region code is available through the setup of the Changer.
-sonsunny
Jul 09, 2011 | LG Audio Players & Recorders
Changing region code
you can change the region code with updates but its risky cos once you upload the update for the region code it may not let you play the other region coded games
Oct 01, 2009 | Sony PlayStation® 3 (60 GB) Console
Mac book pro is currently locked to region 1,
Home Index DVD Region Codes
In order for you to view a DVD's content, the region code on the DVD and the region code for DVD Player must be the same. Your DVD drive is automatically set to a region code the first time you play a coded DVD. If the region code for a DVD does not match the current region code for DVD Player, a dialog appears for you to change the code for DVD Player.
IMPORTANT: You can set the region code for DVD Player only five times (including the original setting). The fifth time you change the code, it will be permanently set. The following map and table indicate the code for the various regions. Some DVD discs can be played in any region, and are sometimes referred to as having region code 0. These discs can be played regardless of the region to which DVD Player is set.
Mar 30, 2009 | Apple Computers & Internet
Unlock region codes
i fund this by dargan and it worked for me "Def" Camino Real 3, Panama:
icon_minipost.gifRegion code hack posted by dargan, August 23 2008:
Same hack for DVD283 worked for DVD-277
<clipped from other post>
Region code hack posted by mhardial, January 25 2008:
DVD Regional Codes
Code Location
**1** USA (incl. territories), Canada
2 Europe (Germany), Japan, South Africa
3 Southeast Asia
4 Latin America, Australia, New Zealand
5 Russia, rest of Asia and Africa
6 China
0, 255, 9 MULTI REGION
Region Code Change
NOTE: Make sure you DO NOT have a disk in the tray while performing the region code procedure
DVD Players
New DVD283
1. Open DVD Tray
2. Press the “Menu” button
3. Press 8888
4. Press the “Display” button
5. Region Code Number shows up. Use the numeric keypad to select your region code number (0 – 6).
6. Press the “Setup” button to exit.
Mar 07, 2008 | Televison & Video
PS3 region code
Yes you can.. Blu-ray discs are not region coded.. However if you trying to play a DVD or any other format disc then it would not be possible since these are region coded.. However the PS3 games are region free.. can be bought from anywhere and played anywhere..
Hope this helps!!
~vMOT
Feb 16, 2008 | Sony Playstation 3 (PS3) Console
Programmed for region 2....Need to change to 1
Q: What is Regional Coding enhancement(RCE)?
A: It's a digital enhancement added to some Warner Bros and Columbia DVDs to stop region 1 (R1) DVDs from playing on Region-free DVD players.
Q: What's the difference between Region Coding and RCE?
A: Regional Coding enhancement(RCE) is an additional layer of protection which some studios have placed on select REGION 1 DVDs to prevent them from playing on region-free or multi-region players. Region Coding is a part of the DVD spec which divides the world into 8 regions:
Region 1: U.S., Canada, U.S. Territories
Region 2: Japan, Europe, South Africa, and Middle East (including Egypt)
Region 3: Southeast Asia and East Asia (including Hong Kong)
Region 4: Australia, New Zealand, Pacific Islands, Central America, Mexico, South America, and the Caribbean
Region 5: Eastern Europe (Former Soviet Union), Indian subcontinent, Africa, North Korea, and Mongolia
Region 6: China
Region 7: Reserved
Region 8: Special international venues (airplanes, cruise ships, etc.)
Basically, DVDs released in each region will typically only play on players sold in that region. IE a DVD released in the UK *Region 2* would not play on a player sold in the us *Region 1*. You can tell what Region a DVD is coded for by looking at the back of the box for a Globe with a number on it. The number correlates to the region list above. If a DVD is listed as 'Region 0' it means that it isn't coded for any region and should play on ALL regions players.
Dec 14, 2007 | Philips 30DV693R 30 in. TV/DVD Combo
REGION CODE
Region Code Change
DVD Players
New DVD283
1. Open DVD Tray
3. Press 8888
5. Region Code Number shows up. Use the numeric keypad to select your region code number 0
DVD283
1) Open DVD Tray
2) Press STOP
3) Press 70 plus region code 0 Example 700. Region
5) Wait five (5) seconds; the unit will automatically exit the region code menu.
Nov 02, 2007 | Coby DVD-283 DVD Player
Televison & Video Logo
64 people viewed this question
Top Televison & Video Experts
