Question about Frigidaire GLEQ2152ES Electric Dryer
Not spinning tumbler doesnt spin some told me it could be a fuse? about a $75 part?
How do I fix the remote on the RC Thunder Tumbler RC Car to prevent the tire from spinning as soon as the remote control is turned on?
Use the throttle trim control to try and adjust this unwanted throttle application out. Refer to the user manual on how to trim the remote functions
Oct 17, 2016 | RC Thunder Tumbler Rc Car
Machine is stuck on fast spin.
First Start your machine with a low spin and slowly slowly increase the speed until it becomes fast I hope it helped : )
Aug 25, 2010 | GE WBSR3140DW Top Load Washer
My tumbler won't turn. Tried unloading some rocks but still having a problem.
I had the same problem, The problem is that the tumbler lid is to smooth and there is no grip from the spinning wheel. I solved this problem by taking a kitchen steak knife and roughing up the edge of the tumbler where it rides on the spinning wheel. Works great now. Best of luck
Mar 06, 2010 | Rotary Thumlers Tumbler Polisher...
My neptume will not wash clothers. the tumbler
if it's noisy in the spin i'd be in the market for a new washer,there's a spinner support assy. that goes in the rear of the drum,for the price it will cost for the part and labor you'd be close to a new washer
Feb 20, 2010 | Maytag Neptune MAH5500B Front Load Washer
During the spin cycle, the agitator makes a knocking/clicking sounds. Works good other then that.
If your machine type is a FAV6800AW or FAV9800AW the tumblers or agitator should no rotate in spin cycle maybe a 1/8 turn and no more at the start of spin cycle . If your machine is one of the above machine types maybe you have coins or something under the tumblers. You can remove the tumblers by removing the plastic tumbler caps and with a #20 torx driver. See page 37 for tumbler removal. If your machine type is not the above please disregard my post.
The Service Manual for reference. Sears Parts Direct for reference.
I have another thought but if you could confirm the machine model number that would be helpful. So many folks post non FAV6800AW machine types in this forum.
Thank you… Rich
Nov 01, 2009 | Maytag Neptune FAV6800AW Top Load Washer
My starter spins but doesnt engage
The problem is with ignition.Check it and check the spark-plug.
Aug 26, 2009 | 1994 Yamaha XV 535 Virago DX
Tumbler wont spin during spin cycle
Have the motor checked. It may stuck up and needs rewind.
Jul 22, 2009 | Washing Machines
We have a penny stuck under the white spinning things.
Hello pinkygirll,
The Service manual has the procedure starting on page 37 for the tumbler removal, take a look and see if you feel comfortable to give it a try. If you are handy or someone you know has basic mech. skill sets you can perform. You, I and many others need to check those pockets. Here is the service manual link.
http://www.fixya.com/support/r1655507-found_service_manual_neptune_top_load
The manual doesn’t call out the torx driver size required for tumbler removal. I just removed my tumbler cap and measured, it’s a #20 torx driver. If you call a repair service in make sure you have your Model# and Serial# number ready to pass along to them. You mentioned”” There is a penny stuck and the washer stops with water in it after it tries to spin.”” The tumblers do not rotate in spin cycle only the wash cycle. If you do a Spin Only cycle with no clothes in the wash basket do you hear the grinding noise? Good Luck.
Mar 03, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Whirlpool Ultracare Doesnt spin out well
this is a direct drive unit it will spin or make alot of noise. do you have the spin speed set correctlly to what your washing if so look under unit and check motor coupling and look for any signs of transmission oil leaks
Nov 10, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Frigidaire GLEQ2152ES Electric Dryer Logo
11 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
