Question about HHB CDR850 CD Recorder
HHB 850 CD Burner - lockup problem
The unit locks up midway through finalization of a CD. Turning the burner off and restart brings the machine to exact same point. I had to take the unit apart to remove the CD.  Even with the CD removed the unit fails to return to normal/ready status.  Is there any factory restart technique?
Re: HHB 850 CD Burner - lockup problem
I did find out how to do the manual eject, for a stuck cd. Open up the machine, looking at the front/top, on the lower left side of the cd transport there is a white plastic gear that can be turned with your finger, ejecting the cd.
Posted on Dec 21, 2007
I just encountered this same problem. i was able to get the cd out by following barbhirsch's advice (see solution #2). after closing the cd tray, and powering the machine back up, however, it was still *stuck* halfway through the finalization process. however, i did come up with a solution...
1. with the power off, remove the disc per barbhirsch's instructions.
2. leaving the cd tray in the open position, turn the power back on. upon powering up, my hhb automatically started looking for a new cd, and the problem was solved.
hope this is of help to anyone who is having problems with this!
Posted on Apr 07, 2008
I spoke with the HHB factory. they said you cannot use high speed media. You need to use 32x or slower. I too have seen this trouble.
Posted on Apr 05, 2008
  • 112 Answers
The 850 has a test mode accessed by shorting a jumper on the display board,but you could try the 830 method - hold in the menu/delete and the auto/manual keys for longer than 5 seconds. Careful, don't adjust anything, just power off to exit test menu.
Posted on Dec 09, 2007
0 characters
3 Points
Hhb cdr830 burner will not finalize cd. What is my solution to this problem?
This sound like a sled positioning problem. The TOC is written in the center of the disc. In order for that to happen the sled needs to be able to get to the most inner section of the disc. This can not happen if fuzz or other contaminants are on the sled worm gear or if the end position switch is dirty or defective. This needs to be seen by a technician that works on these units.
Seek out a well known service shop that has good reviews to work on this. There are shops in Chicago that take your money but do not fix the product- many of my customers tell me about them as I have to fix their equipment. That is all I can say without seeing the unit.
Sep 16, 2012 | HHB 830 Plus CD Recorder CD Player
HHB CDR 850-No laser lit up...shouldn;t there be light ie. laser
YesI when the unit is first turned on the laser will emit a red light when scaning, if no beam is present it is time to replace your player, not cost effective to repair.
Mar 05, 2012 | HHB CDR850 CD Recorder
How to finalize a cd after recording
Press Finalize, then after it displays a time like 4:04, press Pause. It will count down while finalizing. Press STOP to cancel.
Dec 28, 2010 | HHB BurnIt CDR830 CD Recorder
Need owner's manual for HHB CDR-850 Where is reoaur cebter?
what is it you need? what is reoaur cebter? I have the machine and manual. My recorder died last night after 10 years. very disappointed!
Aug 07, 2010 | HHB CDR850 CD Recorder
User manual
You can get it at, or at their website.
thanks and good luck
Jun 04, 2010 | HHB 830 Plus CD Recorder CD Player
Machine is confused. The laser lens may have dust on it. open it up and gently clean laser with a Q-tip. My recorder died last night. I wanna' cry. it was very usefull to me with my music. Now I'm screwed after 10 years of owning it. Good Luck
Dec 10, 2009 | HHB CDR850 CD Recorder
Cannot use the finalize function anymore
they wear out have it serviced and cleaned
Nov 05, 2009 | HHB BurnIt CDR830 CD Recorder
HHB 850 needs repair
You can contact HHB service team on 020 8962 5000. Or visit their web site and go to support and complete an equipment repair form and they'l get back to you. You can also email the engineers whose names are listed in the contact section. Web site is Hope it helps
Dec 26, 2008 | HHB CDR850 CD Recorder
HHB CDR-850 Professional loading problem
I had the same problem with mine. The manual says to unplug it from the power and plug back in. That did'nt seem to correct anything. I also was having an issue with recording. It would'nt record data for tracks and recording would scramble. I had this burner for 10 years and loved it untill last night when it crapped out on me completely. I am VERY disappointed!
Mar 30, 2008 | HHB CDR850 CD Recorder
About the HHB CDR 850 compact disc Recorder
You may need a new laser - it's a sony unit inside.
Aug 14, 2007 | HHB CDR850 CD Recorder
HHB CDR850 CD Recorder Logo
577 people viewed this question
Top HHB CD Players Experts
Sam Palermo
Sam Palermo
Are you a HHB CD Player Expert? Answer questions, earn points and help others
