Sportster 5 no power
Will not power on
2007 SPORTSTER HANDLEBAR CLAMP IS LOOSE
Hi Anonymous, for more information on your question please visit the websites below and good luck:
Harley Sportster INSTALL 5 5 in RISERS
Apr 14, 2013 | 2006 Harley Davidson XL 1200 C Sportster...
My sportster 5 satellite radio is not getting signal
Is it "Aquiring Signal" or "Antenna Not Detected"? It could be the antenna, the dock, or the radio itself. For whatever reason, the Sportster 5 seems more fragile in the dock connections. TSS Radio has a repair guy who can fix this issue. You can reach him via email at sales@tss-radio.com
Jun 15, 2012 | Sirius Sportster 5 Satellite Radio...
My sirius sporter 5 keep turning off and on while driving
Power or Signal drop-off can be fix at ebay item# 360454042820
http://www.ebay.com/itm/ 360454042820
Dec 12, 2011 | Sirius Sportster 5 Satellite Radio...
How to hookup tailight wires for an 05 harley davidson sportster xl 1200 c 5 wire hookup
Orange/white = 12 VDC
Blue = 12 VDC for tail light
Red/yellow = Power from brake light switch (to stop light)
Black = Ground(s)
Purple = Left Turn Signal
Brown = Right Turn Signal
Jun 22, 2010 | 2005 Harley Davidson XL 1200 C Sportster...
1993 harley sportster 1200 headlight quit working
could be a bad ground in the head light bucket or the jumper from frame to the triple tree
Jul 15, 2009 | 1993 Harley Davidson XLH Sportster 883
Sirius Sportster 5 won't power up.
Check the fuse in the power to the dock. They blow out all the time.
Mar 16, 2009 | Sirius Sportster 5 Satellite Radio...
Signal wiring for 74 sportster
CONNECT IT BETWEEN POWER SUPPLY AND THE SWITCH. POWER IN ONE SIDE POWER OUT THE OTHER
Dec 03, 2008 | 1979 Harley Davidson XLH 1000 Sportster
Extending the power cable
Provided that your soldering skills are sufficient, you should be ok. Just be sure to observe the polarity (don't switch the wires around) and use an adequate sized wire.
Sep 03, 2008 | Sirius Sportster 5 Satellite Radio...
Power but no signal
I work for sirius so I know about all of these different issues and the most common one is the connections. It is imperative that the radios be connected to power with the cig lighter adapter. This adapter had circuitry in it that lowers the cars 12 volts to 5 volts which the sirius unit ooerates on. The old units were 12 volt and could hard wired into the vehicles fuse block, but all of the new radios operate on 5 volts. If this is not the issue with either of you then you have defective units. Being that all warranty replacement are with remanufactured units, your chance of getting a problematic unit increases after the initial return of your new unit.
Feb 09, 2008 | Sirius Sportster 4 SP4-TK1 Satellite Radio...
Power supply to Sirius Radio
yes, some sirius radios work on 5 volts, and some work on 12 volts. Your sportster replay is a 5 volt unit. If you trace that wire back, you will find a cigarette lighter plug with a transformer built into it, with either wires soldered to the terminals, or a female cig plug wired up behind the dash. Whatever sirius unit you plan on hooking up, I strongly reccommend using the transformer that it came with......however if you're willing to take a chance, it's most likely 5 volts.
Aug 18, 2007 | JVC KT-SR1000 SIRIUS Radio Receiver
 Grubhead
Grubhead
