Question about Bowflex TreadClimber TC5
It started squeaking very loudly. I cleaned under the belts and lubeededlt
Lubed under the belts, but it seamed to make it worse. only had it since the frist of Jan only have used it three times a week at 30 mins max
Squeaky noises under the hood
IT COULD BE AN IDLER, TENSIONER, OR THE BELT SLIPPING, THESE ARE SEALED YOU CAN'T LUBE THEM. IT SOUNDS LIKE THE BELT IS SLIPPING, BUT IT COULD BE SLIPPING BECAUSE OF A FAULTY IDLER\TENSIONER. REMOVE THE BELT, MAKE SURE ENGINE IS SHUT OFF, AND YOU HAVE THE KEYS, ROTATE ALL THE PULLEY'S AND THE ALTERNATOR PULLEY THEY SHOULD ROTATE FREELY AND RUN TRUE, AND NO ROUGH FEEL TO THEM, OR THE TENSION COULD BE TOO WEEK TO KEEP THE BELT TIGHT.
Jun 09, 2013 | 1996 Oldsmobile Bravada
Nordictrak T5.7 treadmill squeaks while walking
please LUBE the deck belt and roller bearing very important
if the problem persist after you did. Is time to change the deck belt.
God bless you
Jan 08, 2013 | Exercise & Fitness
What would cause a serpentine belt to squeak after the tensioner pully has been replaced
Pulley alignment is the next place to look, DO NOT USE BELT lube, makes it worse.This presumes that each and every pulley turns easily.....
Mar 12, 2012 | 2005 Ford Taurus
When i take off theres a squeak under vehicle
start by getting the thing lubed at your next oil change. take some armor-all with you and pay them some extra bucks to spray that stuff on all your bushings and shocks. if that does not help then you have to wait until the squeak gets worse and identifies itself.
Jun 28, 2011 | 2005 Chevrolet Colorado
My printer is squeaking very loudly whenever it
Take it apart, and clean and lube the components.
Oct 14, 2009 | Lexmark C532dn Laser Printer
My 2002 Maz Protege (156K) squeaks really really loud (sounds like fingernails on a chalkboard), but ONLY on these occasions: 1. I turn my car on, and it's been raining. It will squeak for about 2 minutes,...
you need to tighten or repace you fan belt.if it has a self tensioner that may need to be lubed where it pivots or repace it if that does'nt work.
Aug 29, 2009 | 2002 Mazda Protege
My 2005 ford escape has a terrible squeek coming from under the gas pedal. It becomes worse as I accelerate. I can't find any type of linkage to lube.
there is nothing under the floor of the pedal will make that terrible squeak sound. have your belt check make sure they are tight and not slipping, it will also make that loud squeak sound if it slips. go to auto parts store and purchase a can of WD40 and spray it on all the pulley under the hood. have the engine off while spraying the pulleys. don't worry if it get on other parts of the engine. Common problems with pulleys squeaking on many vehicle.
Aug 24, 2009 | 2005 Ford Escape
How to repair instructions
The rollers behind the drum need heat resistant grease. You'll need snap ring pliers to remove them. Clean and inspect everything inside, vacuum all lint. Have a spare belt, they're cheap. Check the tensioner pulley for lube, but don't get any where the belt touches.
Mar 29, 2009 | Maytag PYE2300AY Electric Dryer
Dryer making loud squeaking sound
Try checking the glide wheels under the barrel they may need to be cleaned and lubed.
Mar 11, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Bowflex TreadClimber TC5 Logo
47 people viewed this question
Top Bowflex Exercise & Fitness Experts
Howard
Howard
Glenn Mayer
Glenn Mayer
ka4iup
ka4iup
Are you a Bowflex Exercise and Fitnes Expert? Answer questions, earn points and help others
