Question about Brookstone HDMI Pocket Projector
Wont turn on
Pl;ugged in overnight. No power indicator light anywhere. Brand new
Sylvania tv manuals model lc195sl9
http://www.searspartsdirect.com/partsdirect/user-manuals/lc195sl8-sylvania-parts-tv+lcd-manual [] Control Panel
POWER (pl 1)
Press to turn the unit on and off.
INPUT SELECT (pl 3)
5. SETUP (p11)
Press to display the main menu.
6. infrared sensor window
Receives infrared rays transmitted from the remote
control.
7. power on indicator
Lights up when power is on.
8. standby indicator
Lights up in standby mode.
May 02, 2014 | Televison & Video
New battery In mercedes no power
I'm not a car mechanic, but, it sounds like you might want to check the fuse to the ignition switch, and, if that fails, it might be a problem with the Start Safety Switch on the transmission. Good luck.
May 02, 2017 | Mercedes-Benz S-Class Cars & Trucks
Dell GX280 orange light on MOBO
Dell Support > Optiplex GX280 Desktop PC > User Manual,
http://support.dell.com/support/edocs/systems/opgx280/en/ug/tindex.htm
I chose the Mini-Tower model because the following information applies to all models;
Small Form Factor (SFF)
Small Desktop
Desktop
Small Mini-Tower
Mini-Tower
Computer and Software Problems > Troubleshooting Tools and Utilities > System Lights,
http://support.dell.com/support/edocs/systems/opgx280/en/ug/tools02.htm#wp1114432
Now scroll down. What do the Diagnostic Lights indicate?
Post back in a Comment.
Regards,
joecoolvette
Oct 09, 2012 | Dell OptiPlex GX280 PC Desktop
D:my phone just wont turn on please help me im going insane :(
First of all please indicate the mode or phone unit next time. Here's my tip have you pressed the power button longer than 24 seconds? If you have and it still not turning on try it while the charger is plugged with it. If it still not turning on then contact the companies technical team department so they can assist you if your unit still have warranty you can exchange the unit to them for a brand new or refurbished one.
Aug 07, 2017 | Samsung Memoir SGH-T929 Cell Phone
Im getting an orange power light when charging allso it wont power on
Usually that indicates a hardware problem. Try removing the battery and leaving it out overnight then with the charger ONLY try turning it back on. If it turns on GREAT. Now try it with the battery back in.
If that doesn't work it's toast :(
Nov 26, 2009 | ASUS MyPal A632 Pocket PC
Not charging
Try to turn on the Keyboard.
There's a switch in the right side of the Keyboard.
For more information download the User Manual at Logitech Site
Sep 15, 2007 | Logitech diNovo Edge 9676850403 Keyboard
900Proview 19in.Flat panel LCD Monitor
Hi, If no indicator lights, no reaction when push the power on button, then chances are that you have a power supply problem. If your particular brand/model has a built-in power supply then it has to be opened up and diagnose. Normally most units would show a light indicator by simply plugging it into an outlet. That light changes color or another one lites up when the power on button is pressed. Absence of the first light indicator means that the system is not getting any power at all. You would be better off seeking the services of a qualified professional. But then again, it just might be the power cord which is of course relatively easy to replace. Try using your computers cord first for the monitor if it fits and matches. Hopes this work out for you and give you an idea or two. Pls post again how things turn up. Good luck and kind regards.
Aug 03, 2007 | Proview PL 566s 15" Flat Panel LCD Monitor
Brookstone HDMI Pocket Projector Logo
104 people viewed this question
Top Brookstone Office Equipment & Supplies Experts
Jerry Kramer
Jerry Kramer
Are you a Brookstone Office Equipment and Supply Expert? Answer questions, earn points and help others
