Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
Error code 1-2036 on Kodak ESP3 printer - Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
  • 31 Answers
This error code is for printer scanner. run clear utility from www.kodak.com/go/clear
and reinstall kodak software from
www.kodak.com/go/downloads.
Note-  Do not connect your printer while installing the software untill installation wizard say to do so.
MS
Posted on Jun 14, 2009
2 Suggested Answers
SOURCE: Error code 1-2036 on Kodak ESP3 printer
To askmeprinter: following your recommended steps does fix the problem TEMPORARILY. The scanner will work after being re-installed, but will cease working again after going into sleep mode.
Posted on Jul 30, 2009
My power switch and the error button won't stop blinking on my Kodak printer.
my printer is not printing paper and the paper not insert the printer
Sep 29, 2012 | Kodak ESP3 AllInOne InkJet Printer
Kodak ESP3 printer will not connect with Windows 7
On June 8,2010 Kodak released a new driver for ESP3 printer.
Version 5.3.0 for Window 7
Download it HERE
Jul 08, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak esp3 all in one home center is saying disconected but it is not
Remove the esp3 driver on the printer setup window the restart your computer to redetect the device. Also make sure that the printer has no error and also check the connections.
Dec 10, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Perhaps this will help, universal error codes for the Kodak 5100 thru ESP 9 inkjet printers:
RME: Kodak
STATUS_OK_ALL = 0,
STATUS_OK_MANUAL_DUPLEX_STARTED = 97,
STATUS_OK_MEDIA_DETECT_STARTED,
STATUS_OK_FORM_FEED_STARTED,
* Informational (0100-0999):
* Busy (1000-1999):
STATUS_BUSY_SYSTEM_BUSY = 1999,
* Warning (2000-2999):
STATUS_WARNING_IMAGE_TOO_LONG = 2998,
STATUS_WARNING_IMAGE_TOO_WIDE,
* Asynchronous Ok (3000-3099):
STATUS_OK_MANUAL_DUPLEX_COMPLETE = 3000,
STATUS_OK_PAGE_EJECTED,
* Asynchronous Warning (3100-3199):
STATUS_WARNING_BLACK_INK_LOW = 3101,
STATUS_WARNING_COLOR_INK_LOW = 3102,
STATUS_INK_TANK_INVALID_MANUFACTURER_COLOR = 3103,
STATUS_INK_TANK_INVALID_MANUFACTURER_BLACK = 3104,
STATUS_INK_TANK_VERSION_EXCEEDS_FW_VERSION_COLOR = 3105,
STATUS_INK_TANK_VERSION_EXCEEDS_FW_VERSION_BLACK = 3106,
STATUS_MEDIA_VERSION_EXCEEDS_FW_VERSION = 3107,
STATUS_INK_OVERFLOW_EXCEEDS_CAPACITY = 3108, // Will be deprecated
STATUS_WARNING_BLACK_AND_COLOR_INK_LOW = 3109,
STATUS_WARNING_PROOF_SHEET_WRONG_MEDIA_SIZE = 3110,
STATUS_WARNING_PROOF_SHEET_WRONG_SESSION_NUMBER = 3111,
STATUS_WARNING_PROOF_SHEET_NO_IMAGES_SELECTED = 3112,
STATUS_WARNING_PROOF_SHEET_READ_ERROR = 3113,
STATUS_WARNING_MORE_THAN_1000_IMAGES = 3114,
STATUS_WARNING_INVALID_DPOF_FILE = 3115,
STATUS_WARNING_NO_IMAGES_FOUND = 3116,
STATUS_WARNING_SCAN_TO_OPERATION_FAILED = 3117,
STATUS_WARNING_BLUETOOTH_CONNECTION_DROPPED = 3118,
STATUS_WARNING_UNSUPPORTED_USB_DEVICES = 3120,
STATUS_WARNING_OVERCURRENT_USB_DEVICE = 3121,
* Asynchronous and Synchronous Error (3200-3499):
* Job Recoverable. No User Interaction.
// STATUS_PRINTER_BUSY = 3201, // not used. duplicated number
STATUS_INK_TANK_REPLACEMENT_IN_PROGRESS = 3207,
STATUS_PRINTHEAD_UNCAPPED_TIMEOUT = 3208,
* Asynchronous and Synchronous Error (3500-3599):
* Job Recoverable. User Interaction Required
STATUS_ERROR_UNIT_OPENED_WHEN_IDLE = 3501,
STATUS_ERROR_MAIN_PAPER_TRAY_EMPTY = 3502,
STATUS_ERROR_PHOTO_PAPER_TRAY_EMPTY = 3503,
STATUS_ERROR_PAPER_JAM_DURING_PICK = 3504,
STATUS_ERROR_NON_PLAIN_DETECTED_DUPLEX = 3505,
STATUS_ERROR_MEDIA_SIZE_MISMATCH = 3506,
STATUS_ERROR_INK_OUT_BLACK = 3507,
STATUS_ERROR_INK_OUT_COLOR = 3508,
STATUS_ERROR_INK_TANK_INSERTED_INCORRECTLY_COLOR = 3509,
STATUS_ERROR_INK_TANK_INSERTED_INCORRECTLY_BLACK = 3510,
STATUS_ERROR_INK_TANK_NOT_INSTALLED_COLOR = 3511,
STATUS_ERROR_INK_TANK_NOT_INSTALLED_BLACK = 3512,
STATUS_ERROR_PRINTHEAD_NOT_INSTALLED = 3513,
STATUS_ERROR_BACK_COVER_REMOVED_WHEN_IDLE = 3514,
STATUS_ERROR_CARRIER_STALL_DURING_PICK = 3515,
STATUS_ERROR_MEDIA_LOADED_UPSIDE_DOWN = 3516,
STATUS_ERROR_INK_OUT_BLACK_AND_COLOR = 3517,
STATUS_ERROR_INK_TANK_NOT_INSTALLED_BLACK_AND_COLOR = 3518,
STATUS_ERROR_PHOTO_TRAY_ENGAGED = 3519,
STATUS_ERROR_FAIL_TO_DETECT_PAPER_EDGE = 3520,
STATUS_ERROR_VOLTAGE_TO_PRINTHEAD_NOT_CALIBRATED = 3521, // Should only be used at the factory
* Scanner (6000-6299):
SCANNER_ERROR_ADF_PAPER_OUT = 6101,
SCANNER_ERROR_ADF_PAPER_JAM = 6102,
SCANNER_ERROR_MOTOR_LOCK = 6201,
SCANNER_ERROR_MOTOR_MOVE_FAILED = 6202,
SCANNER_ERROR_HOME_NOT_DETECTED = 6203,
SCANNER_ERROR_CALIBRATE_FAILED = 6204,
SCANNER_ERROR_ADF_SENSOR_FAILURE = 6205,
/* Internal used errors. to be removed */
STATUS_ERROR_PAPER_JAM = 3201,
STATUS_ERROR_CARRIER_STALL = 3202,
May 12, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak esp3 scanning question
How do I scan a picture from my Kodak ESP3 printer to send to someone?
Jan 20, 2009 | Office Equipment & Supplies
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
1,176 people viewed this question
Top Kodak Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
