Question about Copystar Office Equipment & Supplies
1135 jam code j0501
Rca remoe code for sony tv
Five digit codes are: 10810, 11685
Four digit codes are: 1001, 1036, 1093, 1135, 1177, 1179
Three digit codes are: 002, 030, 048
All the stated codes are for Sony TV with RCA universal remote control.
Jul 03, 2012 | RCA Televison & Video
Error code 1135
P1135 is Air/Fuel sensor Heater Circuit these are because cylinders 1,3,and 5 are not firing which also causes code P0125 .These cylinders are not making heat. the P0300 is because 1,3,and 5 dont miss constantly but they do frequently hence 301,303,and 305. P codes are for Powertrain. I would give the vehicle a good tuneup and make sure you are firing on all cylinders. Possibly need new O2 sensors if those codes don't go away(1130 & 1135) The definitions you DO have are correct. The P0125 "closed loop fuel control" thing is referring about your vehicle no longer being in "warm up" mode. In warm up mode you vehicle does not rely on sensors, it just follows default values for a specific length of time to warm up the engine, then it will adjust everything according to the sensors's inputs to the computer on the vehicle
Oct 05, 2011 | Cars & Trucks
Need driver : PCI modem, video controller for a toshiba satellite 1135 s125
here is the link for all the device drivers on the webpage.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=430235&rpn=PS113U&modelFilter=1135-S125&selCategory=2756709&selFamily=1073768663
go there and modem/display drivers are on the 1st or 2nd page.
click on the link and download and install for your laptop.
Aug 07, 2011 | Toshiba Satellite 1135-S125 Notebook
Plz i need the serial number plz
this is the Serial number for your Software
1135-1024-5436-2183-7281-5619 and
1135-1281-6160-8464-3642-5111 OR
S/N: 1135-1024-5436-2183-7281-5619
S/N: 1135-1281-6160-8464-3642-5111
remember to rate me
Jan 03, 2011 | Adobe Audition 3 for PC (22011292)
2001 6cy camry has check engine light on. code 1135
Hello. You can do this yourself.
You need to replace the Air-fuel sensor. I would strongly suggest that you purchase and install a Toyota sensor, however. The "aftermarket" sensors do not have the exact same voltage signals, and will not rectify the condition; the light will remain on. We see this quite a bit in our service dept.
We hope that this helps you out.
Dec 30, 2009 | 2001 Toyota Camry
Error P0125 and 1135 on obd2 reader
125 insufficient coolant temp for closed loop 1135 sensor heater circuit response bank 1 sensor 1--both can be caused by same problem code can go off for insufficient warm up -low coolant level-thermostat leaking/stuck open or faulty sensor reset code and see if problem returns code sometimes known to go off if vehicle didnt warm up before being turned off short distance drive
Oct 21, 2009 | 1999 Toyota Camry
Drivers for the Toshiba Satellite 1135-S155?
I have fond the model on the ASP website for Toshiba, the link that you will need is the Toshiba Ask Iris help desk. You can download most of the drivers for the laptop here.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/outFrm.jsp?ofId=AskIris&searchString=1135-S155&x=0&y=0
Based on the model number you game me your laptop is actually one of the below models,
Satellite:1715XCDS
Satellite:1675CDS
Satellite:1695CDT
Satellite:1625CDT
If you can provide the exact model I can get you the entire driver series. or just click here to download the drivers..
May 27, 2009 | Toshiba Satellite 1135-S155 Notebook
Removing the hdd in my toshiba 1135-s125
OK, This is a big undertaking if you are completely new.
1st, if you can get a static guard wrist band - great!
2nd You will be dealing with plenty of screws so keep track
In Toshiba notebooks most screws are marked. Here are some examples:
F4 - flat-head screw 4mm long
B6 - button-head screw 6mm long
F16 - flat-head screw 16mm long
B8 - button-head screw 8mm long
I have .a Toshiba Satellite 1135-S155. It should be a similar configuration, same family/1135-S1xx series.
You will have to remove a total of 9 Phillips screws.
Place the underside of the PC up.
Disconnect all power, cables and Battery from Laptop
The first screw is located just under the Toshiba Serial Number / Bar codes, just above where the DVD/CD-ROM combo drive is located.
Mine is labeled (F5). Unscrew it and place in a safe place.
Pull DVD/CD-ROM combo drive out it is an assembly.
The Hard Drive is located under the DVD/CD-ROM combo drive.
The Hard Disk Drive (HDD) is enclosed within a caddy containing the remaining eight screws.
There are four screws holding the caddy rails to the Laptop and four screws holding the rails, caddy and Hard Drive as an assembly.
Unscrew and place in a safe place/ container they are small. Disassemble the HDD from caddy assembly; place your HD in the caddy and reassembly.
Here is another Toshiba HDD access that is slightly more
straightforward than my 1135 series
So you get an idea of where a HDD is visually:
Above is a photo of the Battery sliding out
Below is the Hard Drive Removal
I hope this gives you an idea of how to go about it for your
particular Laptop
If you need further assistance, let me know
Feb 21, 2008 | Toshiba Satellite 1135-S125 Notebook
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Tammie Duggan
Tammie Duggan
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
