Question about Panasonic CQ-C1301U CD Player
Wires pulled out of plug what coloer goes where
Show wires coming out of plug
Mybengine management light comes on when damp outside car judders goes off when warm
Misfire , spark plug wires , coil etc.... Check it out at night when it's dark , with the engine compartment hood open spray water on plug wires , coils . You'll see a light show .
May 03, 2016 | Cars & Trucks
Coloer is messing up
are you meaning the fan ? replace with same type 12v ball type. same wires. most pc shop's carry the fan in stock.
Mar 26, 2013 | Toshiba 52HM95 52" HDTV Projection...
Wiring diagram for 1997 infinity q45
hi i install a bose 7in cd player came with all the plugeto install it. but the factory radio comes with a amp en the amp do not tune on so audio for the speakers ;no sound comes out.i need the coloer of the wire.that will fix my problem.thank you .my email is. enriqueruiz98@hotmail.com
Jul 01, 2012 | Volkswagen Jetta Cars & Trucks
My sansui tv can not show pichar coloer proparly
Please provide more details about the fault you experience with this tV.
Apr 20, 2012 | Sansui Televison & Video
On my 91 civic all the seatbelts are fastened and the seatbelt light still flashs and the warning beeper is beeping how can i resolve this prob.?
My guess, the switch that is in the female end of the drivers side seat belt. The switch is bad or it's come unpluged or it's corroded. It's hard to get at without pulling the seat (four bolts and a harness plug). The plug for the seatbelt plug is usually under the carpet but if you pop off the plastic cover over the bolt that holds the female end of the belt to the car body there is usually enough slack in the wire to pull it up enough to see if the plug or wire is broken or corroded. If not, pull the bolt (it will be lock-tited in so it will come out hard). If the wire looks good, ground the lead wire (wire that goes to the drivers side female end of the setbelt). If the light goes out the switch in the female end of the belt is bad. If it still does,t go out, well I'd have to be there to troubleshoot it further.
Hope this helps.
Mar 26, 2011 | 1991 Honda Civic
The right ear phone doesn't work but the other one does
check that the wiring in the plug is not broken. if you pull the plug out a little so that one contact in the jack contacts both sides,you will hear the dead side come on. If it does not,the wire is either broken in the plug ,or where the wire goes into the headphone.
Dec 30, 2010 | Bose QuietComfort 2 Consumer Headphones
Hi my friends Trailblazer won't start. We have ruled out the battery the starter the cylanioid and battery connections. Any ideas?
Now you need to check for spark. Pull a plug wire, and insert a loose plug in the disconnected wire. Crank the engine to see whether there is spark across that gap.
If there is, reconnect the plug wire, take the hoses or whatever off where the air goes in the engine (I am presuming this is fuel injected), and spray starter fluid in the throat, and see if the engine will show signs of life. If it does, you have a fuel problem.
Jun 25, 2010 | 2004 Chevrolet TrailBlazer
Wiring on plug for fule sending unit
one wire usually to sending unit (which is a rheostat ) from inside it is soldered then up and out to plug....repair anyplace you can get a length of wire to work with or solder a new one in place where old exists now and out to your torn wire..good luck
Jan 13, 2009 | 1990 Ford Probe
Panasonic CQ-C1301U CD Player Logo
16 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
