Computers & Internet Logo
A
Anonymous Posted on Mar 19, 2014
Router remote management
You have no autority
Remote Access
IF you are getting public ip from your isp, please go to administrator tab of the router and first change the router's password which is on the top on same page in black dots,,type your new password by deleting old one and re-confirm it just below and save it..router will prompt for the new password just to let you know settings are saved now enable remote managment option on the same page and port is 8080(default, you can use your own port number) and save setting..now you are ready to access your router remotely for that note down the public ip you are getting on your router's status page and in remote location you need to type something like :- http://x.x.x.x:8080...x.x.x.x is your internet ip (public) and 8080 is port number for remote management.
For host applications need to know which application you are running according to that need to open port in the router using Port Forwarding feature of the router.
1helpful
1helpful
Cannot access remote management of WRT160N Router at all.
did you changed the Remote Management Web Interface to use a different port other than port 80? some defaults to use 8080. So in your case, try this address in IE: http://10.0.0.250:8080
Port forwarding & Remote Management setup on Linksys WAG200G
here is how you set up port forwarding:
1. log into the router;
2. Click the Applications & Gaming link near the top of the page. 3. You should now see a new menu. Click Single Port Forwarding or Port Range Forwarding.
4, Enter sth like: HTTP; 80; 80; TCP; 192.168.0.1; check
5. When you're finished, click Save Settings near the bottom of the screen to save your changes.
go to administration-> remote administration to set up remote management
Remember, remote Administrator requires you to forward the 4899 ports.
2helpful
D-Link DI 524 behind VNC access remotely - Need help....
Open a browser and type in htp://192.168.0.1 to access your router's web management interface. Enter the username and password (default is username admin and no password)
Go to the Advanced Tab and Virtual Server
Name=VNC
Private IP=IP Address of your Home notebook
Protocol Type=TCP
Private Port=5800
Public Port=5800
Set Schedule as you like
Enable the rule and click Apply.
To access you Home notebook from anywhere other than your house, go to http://10.0.57.46:5800
Next - remote management of the router.
The IP address that you enter on the remote management page is the IP address that is allowed to connect to the remote management. If the 194.145.183.83 is the IP address of your office, this should work. Be sure you apply a password or anyone going to http://10.0.57.46 will have access to you router, I also recommend changing the port from 80 to 8080 so that http://10.0.57.46:8080 has to be typed to access the remote management interface.
1helpful
Remote Access
If you want to access your router remotely, you just need to enable remote management on your router so you can access it using your internet IP colon the port number usually its port 8080.
How can I manage the Prestige 310 ?
# Menu driven user interface for easy network management Local and remote console management # Windows configurator Telnet remote management # TFTP (Trivial File Transfer Protocol) firmware upgrade and configuration backup and restore
1helpful
How do I use the Remote Management feature on my router?
Remote Management allows the device to be configured through the WAN (Wide Area Network) port from the Internet using a web browser. Step 1 Log into the web based configuration of the router by typing in the IP address of the router (default:192.168.0.1) in your web browser. The username is admin (all lowercase) and the password is blank (nothing). Step 2 Click the Tools tab and click the Admin button. Step 3 Select the Enabled button to enable Remote Management. In the IP Address field type in the public IP address you wish to manage the router. Note: If you don´t know the IP address or wish to allow more than one IP address to manage the router then put an asterisk (*) in the IP Address field. You cannot enter an IP range. Step 4 By default the port used to Remote Manage the router is set to 8080. Change the port number by selecting the down arrow next to the Port Number drop down menu. Step 5 Click on Apply and then click Continue to save the changes. To Remote Manage the router you will need to type in the Public IP Address of the router in your web browser along with the Port Number (separated by a colon) you selected in Step 4.
Top TP-LINK Computers & Internet Experts
 Mikey
Mikey
Menachem Grossman
Menachem Grossman
Are you a TP-LINK Computer and Internet Expert? Answer questions, earn points and help others
