Question about Plantronics Cs540 Wireless Headset
Cs540 humming While on a call, there is a humming/static on the connection and it is not from my caller.
I want to buy Plantronics CS-540 online. Recommend a credible website.
Well buying Plantronics CS540 is an excellent choice. You can find various websites online which are offering Plantronics headsets online. I do not know your geographic location but if you are in US then I would suggest that you should check HeadsetZone, Telegiants.com as they usually offer headsets at the most affordable price.
Plantronics CS540
Plantronics CS540
Apr 26, 2017 | Plantronics Radio Communications
Headset troubleshooting
I can hear the caller but they can not hear me...what is the solution?
Jul 15, 2014 | Plantronics Cs540 Wireless Headset
Cs540 caller hears echo
Hello, if they are hearing echo, you are speaking too loud. Or have the receiver too close and talking too loud. Or the person on the other end of the line has phone line problems.
May 16, 2014 | Plantronics CS50 Wireless Headset
My home theater speakers make a constant hum whenever my receiver is on. The loudness of the hum changes with the volume control, and goes away entirely when the system is muted. All components are plugged...
jd40,
Sounds like a grounding issue. The first two places to look into is the powered subwoofer and antenna. During your last test, did you leave the FM antenna and subwoofer connected? Many times the hum is directly related to the antenna and/or the subwoofer and to how they are grounded; creating a ground loop through the receivers ground on the outlet. If the antenna is grounded to the dwellings wiring, hum is inevitable and sometime you can get a ground loop hum from how or how & where the subwoofer is grounded. Try taking them completely out of the loop.
Also try taking it further back to the basics, start with the receiver plugged into a known good grounded outlet with no surge or line conditioner in the loop and nothing connected to the receiver, nothing. Use one speaker and different wire to test each speaker output while in tuner and any other mode but phono. With no signal, you will either get nothing (no hum or static) or just static in the tuner mode. No hum is a good sign. Some systems will mute the speakers if no signal is connected to eliminate the static from being produced through the speakers but a ground loop hum will most likely still be produced even in mute. If you get a hum when nothing is connected to the receiver, try looking into getting a better grounded outlet, even maybe to a different dwelling.
-Chris
Jan 30, 2010 | Yamaha 5.1-Ch. Surround Sound Home Theater...
Vtech model 2656 caller id is not working. How can I fix this?
Found this on the VTECH support site regarding your model:
Tip 1 of 1
Caller ID and Call Waiting ID are subscription services, available from most local telephone service providers. You must subscribe to these services in order for the features to work on your phone. Contact your local telephone service provider for more information.
In addition, your caller must be calling from an area that supports caller ID.
Both you and your caller’s telephone service provider must use compatible caller ID systems.
If you subscribe to DSL service for this telephone line, DSL filters must be plugged into EVERY phone jack that has a phone. The DSL signal can cause caller ID disruption, static, noise and other issues on your line. DSL filters block the high frequency DSL signals from being transmitted to the telephone. If you are not using the DSL filters provided by the telephone company, this will cause static/noise and possibly caller id issues on your phones.
In most cases, we recommend you connect the plug end of the DSL filter into the telephone jack, then connect a telephone cord between the filter and your phone.
Please contact your service provider to obtain DSL filters and installation information.
Caller ID and Call Waiting ID may not be available for every call. Common reasons are incompatibilities between your and your caller’s service, transmission errors and answering calls before the ID data is received.
In addition if you would like to contact them or get more info on your phone, then use this link:
http://www.vtechphones.com/vtechui/support/faq_index.cfm
Nov 22, 2009 | Vtech VT 2656 Expandable Cordless DSS...
Caller can't hear me and I can't hear them
If your phone is newer, then take it to the Aple store to exchange. If they did not replace it for you, then you need a professional to replace the MIC.
Thank you
Apr 02, 2009 | Apple iPhone Smartphone
Loud hum with static when speakers turned on
There is def. a loose connection somewhere in your system. This is a grounding problem within the system if nothing else. Def. a "lazy" connection somewhere.
gurutim
Mar 10, 2009 | Bose Companion 3 Series II Multimedia...
Static on the line, not heard by the caller
this is not in the phone its in the line you need to let your service provider know about this problem so they can fix it
Mar 08, 2009 | Uniden DCT646-2 Cordless Phone
Buzzing/humming sound when mic is inserted while on AC power
if its not usb mic you will have the humming
if it is a usb mic the port that you connected to needs a mic to be further away from comp your picking up a static charge from comp to mic
May 26, 2008 | IBM ThinkPad T30 2366 Notebook
Plantronics Cs540 Wireless Headset Logo
Top Plantronics Lands Phones Experts
Andrew Taylor
Andrew Taylor
Are you a Plantronics Lands Phone Expert? Answer questions, earn points and help others
