Question about ATN Optics
Not working new batt nothing model#40589
New batteries still no power-up
Check the contact in the batt compartment for obstructions or corrosion etc. No power means broken circuitry - either physical dislodgement of electronic/ electrical parts or damaged electronic components.
Apr 01, 2013 | Canon Speedlite 430EX TTL Flash
Won't crank has new battery
if the lights come on you'r getting juice from the batt,if they go out when you crank the motor over batt is bad or you have bad batt connections
Aug 27, 2012 | 2000 GMC Jimmy
Brand new will not start
like no juice? if no juice bad batt.. i just baught a new supermoto rode it 0ne day.. came out next morning no power.. nothing... tried to jump to take to dealer no power.... took batt. to dealer picked up new batt. under warrenty... went home power....
Apr 09, 2011 | Triumph Bonneville T100 Motorcycles
I have a sony cibershot camera for over a year now, it has always worked nicely, up until a month ago, it suddenly wont turn on anymore. I,ve already charged and re-charged the battery but nothing...
make sure the batt is charging and working fine.check also the batt contacts.make sure its clean.insert batt to your camera.instead of pressing the power button, press the play button instead to power camera on. if unit turns on,might actually be an issue w/the camera unable to power on in camera mode.if it turns on initialize cam (p.75 of the manual).see if it works.if still wont turn on try using a diff batt (or if you have an optional ac adapter model#acls5k use it, attempt to power on cam to isolate issue w/power source).if batt or ac adaptor not available try to check batt with another cam if possible to test batt. if still unit doesnt turn on using a fully charged, diff batt, or using an ac adaptor,unit would reuire service. hope this info helps.thanks:)
Apr 06, 2010 | Sony Cyber-shot DSC-H9 Digital Camera
It just stoped working I thought the batt needed charging. Did not help I bought a brand new batt and it still won't do anything. nothing comes on
I just took the thing apart. Unscrewed front cover and just pokeing around with a feeler gage and it started working.
Dec 31, 2009 | Canon PowerShot G2 Digital Camera
Husqvarna will not start with the key. NOTHING. Can jump start it
try jumping as long as the old mowers batt.is 12 volts if that dosnt work buy a new batt.
Apr 06, 2009 | Garden
Wont go on
Are you sure the 'New' battery is of the correct type?
what is the oriniginal Battery- Type and Voltage
What have you replaced it with?
Nov 18, 2007 | Panasonic Lumix DMC-FZ20 Digital Camera
Wont turn on
Well have you tried putting brand new fresh batt's in the unit? If they are rechargeable they may have simply discharged or if "normal" batt's they may just have gone flat.
Jul 14, 2007 | Uniden TR620 (14 Channels) 2-Way Radio
Optics Logo
49 people viewed this question
Top ATN Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Tony Parsons
Tony Parsons
Frank Hunter
Frank Hunter
Level 1 Expert
Are you an ATN Optic Expert? Answer questions, earn points and help others
