Question about Proactiv ECount Electronic Golf Score Counter
Can' set time on ecount4
Unable to set time
Model #MWG9111SL
am/pm may not be a separate control. Try setting the hours 12 hours ahead to change from am to pm.
Apr 20, 2015 | Emerson Microwave Ovens
Unable to reset the time on the timer it keeps flashing all the time therefore i am unable to use the oven
hold the first three buttons down , then using the last two buttons , set the time, oven should now work
Jan 17, 2011 | Belling DB2 Dual Fuel (Electric and Gas)...
Unable to set the dual time on my new watch
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to B&M watch manuals.Rate me, please
Mar 16, 2010 | Baume Et Mercier Hampton Classic Square...
Unable to set the correct date. Able to get to menu:additional functions,timer settings and the date and time settings, but unable to change the time
Type everything in and then press OK. If its showing up on scan time then go to Add Funct-System-Date and Time. Make sure time zone is set correctly
Nov 30, 2009 | Canon imageRUNNER 1023iF Black and White...
Can't change date or time on my new Pentax K2000
Date/time are set at "first use" or through the tools menu.
Remove the batteries.  Leave the camera overnight, this may be enough to lose the current settings and allow setting new date/time.
Press Menu button.
Press right arrow on the 4-way controller to get the Tools (spanner) highlighted.
Press down arrow to get to date (or time).
Press right arrow
Now set to your preferred format.
If this does not work, try changing another item in the Tools menu.  If that change is not accepted, then it's into the dealer.
Jun 21, 2009 | Pentax K200D 10 Megapixel Digital SLR...
Unable to change application settings in my nokia 6233
DO RESTORE SETTING OF UR PHONE THEN TRY AGAIN IT SHOW SAME PROBLEM
REMOVE MMC BACK UP OF ALL UR DATA FROM PHONE MEMORY INSTALL NOKIA PC SUITE IN UR PC AND DOWNLOAD UPDATES FOR UR MOBILE FROM NOKIA.COM INSTALL IT AND UPDATE UR MOBILE ONLINE.IT WILL FORMATE UR MOBILE ,RESET UR ALL UR SETTING
Nov 05, 2008 | Nokia 6233 Cellular Phone
Unable to display Date or time in pictures taken from Canon PowerShot A720 IS
You have to select 'Postcard' for the image size -- on the same menu as L, M1, M2, M3, S, Postcard.
Oct 30, 2008 | Canon PowerShot A720 IS Digital Camera
I have a CD Clock Radio. I am unable to set the time. When I set the time, the wake up time comes on. I am also unable to set the wake up time and delete or change tje wale up time.
RETURNED THE CD CLOCK RADIO AND TOLD THEM IT WAS TOO COMPLICATED FOR ME. I WASN'T GOING TO PAY TO BE TOLD HOW TO OPERATE IT. THAT WAS MY EXPERT SOLUTION.
Jul 29, 2008 | Audio Players & Recorders
Casio AQ-161 combi watch - unable to set the digital time
The Casio web site has all manula on line. The model no is 3352
Good luck
Jun 25, 2008 | Casio Watches
Proactiv ECount Electronic Golf Score Counter Logo
75 people viewed this question
Top Proactiv Golf Experts
FastHarley
FastHarley
ray gallant
Ronald Prier
Are you a Proactiv Golf Expert? Answer questions, earn points and help others
