Question about Vehicle Parts & Accessories
Removal of front brake caliper on a dodge magnum
I need to remove the front brake caliper assembly on a 2006 dodge magnum
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 189 Answers
This is now september i hope by now you have this work done if not where do you live
Posted on Sep 09, 2014
SE. How do I remove transmission oil cooler line?
How To Install Replace Transmission Cooler Lines 2001-06 ...
? 5:45
https://www.youtube.com/watch?v=SFEXmxxBMK8
Oct 31, 2013 - Uploaded by 1A Auto Parts
How To Install Replace Transmission Cooler Lines 2001-06 ... In this video, 1A Auto shows you how to remove, replace and install leaking or broken Transmission Cooler ... How To Install ReplaceDo a Front Brake Job 2001-06 Chrysler ... 2003 Dodge Ram 3500 trans cooler replacement how to 11-24-12 ...
Search DODGE MAGNUM Cooling > Transmission Oil ...
www.factorychryslerparts.com > ... > Transmission Oil Cooler, and Lines
DODGE MAGNUM Cooling > Transmission Oil Cooler, and Lines. ... Please let us know what we can do to achieve this goal. ... Our inventory covers the following years of MAGNUM: 2005, 2006, 2007, 2008, ... Click X to remove the keyword.
Leaking Transmission Cooler Line Replacment Recommendations ...
www.dodgeintrepid.net > ... > General Discussion (First Generation)
Dec 12, 2015 | 2006 Dodge Magnum
How to change front wheel bearings on a 4 wheel drive dodge nitro?
HUB AND BEARING
1. Raise and support the vehicle.
2. Remove the tire and wheel assembly.
3. Remove the caliper adapter. Refer to Brakes/Hydraulic/Mechanical/CALIPER, Disc Brake - Removal.
CAUTION: Never allow the disc brake caliper to hang from the brake hose. Damage to the brake hose will result. Provide a suitable support to hang the caliper securely.
4. Remove the disc brake rotor. Refer to Brakes/Hydraulic/Mechanical/ROTOR, Brake - Removal.
5. Remove the wheel speed sensor. Refer to Brakes/Electrical/SENSOR, Wheel Speed - Removal.
Fig. 47: HALF SHAFT BEARING BOLTS
6. Remove the axle shaft nut. (if equipped with four wheel drive)
7. Remove the three mounting bolts (1) for the hub. bearing assembly.
8. Remove the hub/bearing.
Installation
INSTALLATION
Fig. 48: HALF-SHAFT BEARING BOLTS
1. Install the hub/bearing assembly to the vehicle.
2. Install the three mounting bolts (1) for the hub/bearing. Tighten the bolt to 130 N.m (96 ft.Ibs.).
3. Install the axle shaft nut. Tighten the nut to 135 N.m (100 ft.Ibs.). (if equipped with four wheel drive)
4. Install the wheel speed sensor to the hub. Tighten the bolt to 13.5 N.m (10 ft.Ibs.). Refer to Brakes/Electrical/SENSOR, Wheel Speed - Installation .
5. Install the disc brake rotor. Refer to Brakes/Hydraulic/Mechanical/ROTOR. Brake - Installation .
6. Install the disc brake caliper adapter. Tighten the nut to 135 N.m (100 ft.Ibs.). Refer to Brakes/Hydraulic/Mechanical/ROTOR, Brake - Installation .
7. Install the tire and wheel assembly. Refer to Tires and WheelsAYheels - Standard Procedure . 5250a498-52fa-4c0c-8687-d0c1ee25e9f7.jpg Auto Repair Help US
Sep 02, 2014 | 2007-2011 HA590245 Dodge Nitro Front Wheel...
How do I get to the front/side blinker bulb on my 2006 dodge magnum sxt
There go
Remove the entire lamp assy
Been that way for 20 years
Aug 25, 2014 | 2006 Dodge Magnum SXT
I am replacing the front brake pads, and have removed the old pads. I can get the new pads in place, but cant fit the caliper assembly back on the rotor. what am i missing?
YOU NEED TO SQUEEZE THE PISTON FOR THE CALIPER. IF YOU PUT A LARGE C-CLAMP ON THE OLD BRAKE PAD AND SQUEEZE IT TIGHT, IT SHOULD GO.
REMEMBER TO RATE THIS ANSWER
THANK YOU
Dec 26, 2010 | 2006 Dodge Grand Caravan
I need to replace the brake rotors and pads on the front of my 2008 Dodge Magnum SE. Is there anything special I need to know. Haven't replaced brakes on this new of a car before. Thank You
You'll need the Allen or Torz wrench that fits the locking bolts on the caliper so you can remove the calipers and you will need a caliper compressor to compress the caliper cylinders to install the new brake pads once you replace the rotors. I would have the Rotors checked to verify they need to be replaced before replacing them. It is possible you can save money by simply having them turned instead. $25 for each rotor is better than the normal $150 to $250 to get new ones.
Sep 30, 2010 | 2008 Dodge Magnum
What tools needed to replace front brake pads & rotors
Brake Pads
Removal & Installation
Front
3.4L front disc brake assembly
4.0L and 4.7L front disc brake assembly
To Remove:
  1. Before servicing the vehicle, refer to the precautions in the beginning of
    this section.
  2. Remove or disconnect the following:
    • Front wheel
    • Clip, 2 caliper pins, the anti-rattle spring then remove the 2 brake pads
      and the 4 anti-squeal shims
To Install:
CAUTION
Only replace brake pads on 1 side of the
vehicle at a time. Failure to use this procedure could cause the caliper pistons
on the opposite side of the vehicle to pop out requiring the reconditioning or
replacement of the brake caliper.
  1. Remove a small amount of brake fluid from the master cylinder.
  2. Install a used brake pad into the caliper and compress the caliper pistons.
  3. Apply disc brake grease to both sides of the inner anti-squeal shims.
  4. Install or connect the following:
    • Anti-squeal shims to the new brake pads
      NOTE: When replacing worn pads, the anti-squeal shims must be replaced
      together with the pads.
    • 2 brake pads
    • Anti-rattle spring and the 2 caliper pins
    • Clip
    • Front wheel
  5. Depress the brake pedal several times to seat the brake pads.
  6. Check the brake fluid level and top off as needed.
Rear
To Remove:
    this section.
    • Rear wheel
    • 2 cylinder slide pins from rear caliper assembly
    • Caliper assembly from rear caliper mounting
    • 2 brake pads with anti-squeal shims from rear caliper mounting
    • 2 anti-squeal shims from each disc brake pads
    • Pad wear indicator plate from the inner side disc brake pad
    • 4 pad support plates from the rear caliper mounting
To Install:
  1. Install or connect the following:
    • 4 pad support plates on the rear caliper mounting
    • Pad wear indicator plate on the inside brake pad
      Note: Install the pad wear indicator facing downward.
    • Anti-squeal shims on each brake pad
    • 2 disc brake pads with anti-squeal shims to the caliper assembly
  2. Apply lithium soap base glycol grease to the sliding part of 2 caliper slide
    pins.
  3. Install or connect the following:
    • Disc brake caliper assembly with 2 caliper slide pins
    • Torque to 65 ft-lbs (88 Nm)
    • Rear wheel
  4. Depress the brake pedal several times to seat the brake pads.
  5. Check the brake fluid level and top off as needed.
--- Removal & Installation
Front
To Remove:
    this section.
    • Front wheel
    • Front brake caliper assembly
  3. Make matchmarks on the disc and the axle hub.
  4. Remove the front disc.
To Install:
  1. Align matchmarks and disc onto axle hub.
  2. Install or connect the following:
    • Front brake caliper assembly with the 2 bolts
      1. Torque to 90 ft-lbs (123 Nm)
    • Front wheel
Sep 23, 2010 | 2003 Toyota 4Runner
How edo i remove the front brakes from my 2006
You will have to remove each front wheel. I recommend doing one side at a time so you can use the other side as a guide if you need a model for reassembly.
There will be two threaded caliper bolts that hold the caliper on. Remove those, and carefully pry/lift the caliper off its bracket. This is good time to inspect your rotors, and if they are really pitted or rusted on the surface where the pads contact them, have them turned or replace if economical to do so.
Before installing the new pads, you will need a good old C clamp to reseat the caliper piston back inside the caliper.
Its good to also clean up those caliper guide pins and apply a small amount of grease to keep them working right.
Then, insert new pads onto caliper and reinstall assembly back onto bracket.
NOTE: Be very careful when tightening those caliper bolts as they are very easy to break/strip, and you really do not want to "go there"
Your local parts store should be able to tell you the torque specs fort those bolts, or look it up on the net.
Once one side is done, do the the other one. After that, press the brake pedal several times and be sure you have a good firm pedal before going for the test drive.
Apr 17, 2010 | 2006 Dodge Durango
Cant remove wheel hub
here is procedure
Section 04-01: Suspension and Wheel Hubs, Front 1996 Taurus, Sable Workshop Manual
REMOVAL AND INSTALLATION Wheel Hub Bolt Removal
  1. Raise vehicle on hoist.
  1. Remove wheel and tire assembly. Refer to Section 04-04 .
  1. Remove disc brake caliper (2B120), and front disc brake rotor (1125). Refer to Section 06-03 .
Brake Shoe and Lining Removal
  1. Remove brake master cylinder filler cap (2162). Check fluid level in brake master cylinder reservoir (2K478). Remove brake fluid until brake master cylinder reservoir is half full. Discard removed fluid.
  1. Raise vehicle on hoist. Refer to Section 00-02 .
  1. Remove wheel and tire assembly from front disc brake rotor mounting face. Use care to avoid damage or interference with disc brake caliper (2B120), front disc brake rotor shield (2K004) or front wheel knuckle (3K185).
  1. Remove rear brake pin retainers (2N386). ( I think it is a T 40 torx bit you need)
  1. NOTE: It is not necessary to disconnect hydraulic connections.
    Lift disc brake caliper from front disc brake caliper anchor plate (2B292) and front disc brake rotor (1125). Do not pry directly against metal caliper piston or damage will occur.
  1. Position disc brake caliper out of the way and support with wire to avoid damaging the disc brake caliper and front brake hose (2078).
  1. Remove outer brake shoe and lining (2001) assembly from front disc brake caliper anchor plate.
  1. Remove inner brake shoe and lining assembly.
  1. Position lug bolt (1107) to clear front wheel knuckle (3K185).
  1. Remove lug bolt from wheel hub (1104).
Installation
  1. Install lug bolt into wheel hub.
  1. Using a lug nut (1012), seat wheel hub bolt into wheel hub.
  1. Install front disc brake rotor and disc brake caliper. Refer to Section 06-03 .
  1. Install wheel and tire assembly. Tighten lug nut to 115-142Nm (85-104 lb-ft).
May 25, 2009 | 1996 Mercury Sable
2006 dodge ram 2500 4x4 diesel replace brake pads front and back
Straight forward job. Remove wheels, remove 2 caliper bolts per wheel, check bolts,and bushings for wear/corrosion and lubricate, remove calipers, remove brake pads, push caliper pistons into calipers, replace anti-rattle clips, put new pads in, put caliper and bolts in, put wheels on. Start truck and press brake pedal several times to take up slack and you're done.
Apr 25, 2009 | 2004 Dodge Ram 2500
2006 subaru legacy remove front brake rotor
Hello, hope this info helps...(subytech1)...
REMOVAL
15-INCH TYPE
  1. Lift-up the vehicle, and remove the front wheels.
120334720
  1. Remove the caliper body and the support from housing, and suspend it from strut using a wire.
120334721
  1. Remove the disc rotor. NOTE: If the disc rotor seizes up within hub, drive the disc rotor out by pushing with an 8 mm bolt in holes B on the rotor.
  2. Clean mud and foreign particles from the caliper body assembly and the support. 16-INCH TYPE Refer to 15-inch type. 17-INCH TYPE Refer to 15-inch type.
INSTALLATION
  1. Install the disc rotor.
  2. Install the caliper body and the support to housing. Tightening torque: 80 Nm (8.2 kgf-m, 59 ft. lbs.)
  3. Install the front wheels.
Mar 27, 2009 | 2006 Subaru Impreza
Vehicle Parts & Accessories Logo
55 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
