Question about Midland 75-822 40-Channels Handheld CB Radio
I put batteries in ths cb after sitting a while and it doesnt turn on.. i cleaned it and put back together , put batteries in and nothing .. it did work before..
Hi clean the springs and cheak for rust
Posted on Jun 16, 2009
75-822 can't remove battery pack push button
Does it have screws? If so try to remove them an take pack apart. You can always put it back together.
Mar 24, 2014 | Midland 75-822 40-Channels Handheld CB...
2001 buell balst sat. For a year.....new battery fires right up.....however when I engage the clutch it does nothing bike stays in gear....tries to move when starting .....help
Your clutch discs are stuck together, happens sometimes when a bike sits for a LONG TIME. The oil basically acts kinda like glue. you need to get in there and take the clutch discs out and clean them off and put it back together. Of course you might find that the primary(clutch area) is full of water. It happens because the vent for the clutch goes up under the seat and can act like a funnel and drain water back into the case.
May 20, 2012 | 2001 Buell Blast
I had the pacifica on ramps changed the oil now it wont start
Clean your battery terminals take them off and clean them. Turn on your headlights if you turn the key and nothing happens and the lights are bright hit the starter with a hammer try it a few times if it starts you have a bad armature in the starter. If nothing happens and the headlights go out or dim the battery has a bad connection or is bad. Check under the hood on the right above the battery the relays one is the starter relay switch it out with one of the extra ones in there. Put a volt meter on the battery just because you charged it doesn't mean it is 12.6 just sitting and not below 10 volts with key on
Nov 28, 2011 | 2004 Chrysler Pacifica
I plug my Sony Clie PEG-NX60/u into the cradle, and after letting it sit for a while, I attempt to turn it on and a green power light shows. However, nothing appears on the screen, even if I leave it for a...
First try the easiest solution,
turn your phone off, take out battery,leave for about 5 min.
put back together, then turn back on.
I hope this helps you : )
Debbie
Aug 04, 2011 | Computers & Internet
Trans is stuck in neutral, has been sitting long time
Strip the box down, clean and put back together with any new parts to replace the worn pawls and bent springs etc.
Jan 06, 2011 | 1976 Honda Cb 400 F
My o2 orbit keeps turning off. How can I stop this happening
currently researching this problem myself, im going to try a full inside clean by opening it up cleaning it and putting it back together, if this doesnt work im going to try a hard reset.
however if this doesnt work im forced to buy a new battery coz it seems to me as though the battery is not holding its charge.
Nov 21, 2009 | O2 Xda Orbit Smartphone
The screen light on my phone doesnt work
More than likely, you've turned the back light off all together. Go into the menu, and display settings and find the backlight options.
If it's set to 'on' and to stay on for at least 3 seconds, yet nothing works: turn your phone off and then back on again. If still nothing, take the battery out, put it back in and start it up again.
If there's still no backlight, contact your supplier or the store you bought it from.
Jul 25, 2009 | Motorola Mobility V265
Hp not turning on laptop
you haven't got the TFT cable plugged in correctly
Jul 25, 2009 | Computers & Internet
2002 chevy silverado
clean ur battery terminals..take a wire brush and clean them..put it back together and make sure all terminals are tight...if that doesnt work..please let me know.
Sep 02, 2008 | 2002 Chevrolet Silverado 1500
Midland 75-822 40-Channels Handheld CB Radio Logo
55 people viewed this question
Top Midland Radio Communications Experts
Steve
eradiostore
eradiostore
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
