Question about Vivitar ViviCam 3632 Digital Camera
My camera is not working
I have a 3630 vivitar camera and when i try to turn it on it not works, it has batteries and i did not droped, some one know if i can get a softwer to fixed?
  • royceholmes Dec 27, 2007
    I have the 3630 and have the same problem with mine,it will come on but no lcd and I have to remove the batteries to get it to go off,sometimes the lcd will come on but most of the time it does not work. No help from Vivitar site either,doesnt even show the 3630 model.
I have a kodak easyshare m753 i droped it and it says that theres a lens error when i try to turn it on what should i do
Posted on Dec 26, 2007
Vivitar home page does no list the vivicam 3630 so that I can download the instalation disc data
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Windows Photo Gallery or any other photo cataloging program, such as Picasa ( http://picasa.google.com ).
Mar 23, 2011 | Vivitar ViviCam 3630 Digital Camera
My Vivitar Vivicam 5399 is refusing to turn on. It has worked perfectly up until a couple of weeks ago, when it started to turn off at random moments, usually soon after I had turned it on. Now, it doesn't...
Have you tried to see if the battery door is completely shut? This is usually the problem with many digital cameras with batteries. Clean the battery door and where the battery touches the metal of the door. Check to see if the door is completely flush with the camera body when you close it. I know for a fact that Vivitar cameras **** the juice out of batteries fairly quickly also. If you have the USB-cord provided with the camera, plug it into your computer and see if that holds a charge to your camera. If all else fails, call up Vivitar for further inquiry, your battery may be dead.
Mar 08, 2011 | Vivitar Vivacam 5399 Digital Camera
Lens cover does not open and camera shuts off it is a vivi 5385 vivitar digital
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine .
Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a
back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec ..
in not done the press both Menu & self time key for 2 - 4 sec.
Jun 09, 2010 | Vivitar ViviCam 5385 Digital Camera
Camera was droped now it does turn on and the lens
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
May 01, 2010 | Sony Cyber-Shot DSC-S40 Digital Camera
I tried charging it, but it will not turn on. It will not turn on when it is plugged into computer either.
Try a different new battery. If that did not solve the problem. Check the on off switch. It is possible, if you droped it, it may have been damged. Good luck
Jun 09, 2009 | Vivitar DVR-550 DV Camcorder
Vivitar v3800N battery holder missing
rcv7,
this camera has at least two different names that i know of (phoenix, vivitar ) .The battery covers are the same.
most camera repair shops have repair manuals with part numbers from the manufacturer. the only other way is to take a cover to a machine shop and have them make some from aluminum. we had this done for the pentax spotmatic when parts were no longer available.
Jan 14, 2009 | Vivitar V3800N Zoom 35mm SLR Camera
Samsung L730 wont extend lens and dosent turn on right
Try removing the batteries and memory card. Let the camera set for awhile. Put the batteries back in but not the memory card, restart the camera. Does it work know? If it does, turn the camera off put the memory card back in. Turn the camera on, does it work now? If it doesn't, replace the memory card.
Dec 27, 2008 | Samsung Digimax L730 Digital Camera
Vivicam 8400
I have a ViviCam 8400 and have the same problem UNLESS I buy Duracell Power Pix or Energizer Titanium batteries. These cost more than the regular grade AA batteries, but when I used brand new regular batteries, the camera would turn on for 2 seconds then turn right off. Titanium or Power Pix batteries make the camera work fine. And, because they are made for digital media, they do allow you to use the camera for longer periods of time.
Jun 09, 2008 | Vivitar ViviCam 8400 Digital Camera
Vivitar ViviCam 3615 Digital Camera
i have a vivitar vivicam 3720 digital camera need sofewear
Nov 13, 2007 | Vivitar ViviCam 3615 Digital Camera
Vivitar 3630 digital camera
You don't need to buy it. Just go to the Vivitar web site and you can download it directly to your computer. Good luck ! http://www.vivitar.com/support.asp
Sep 03, 2007 | Vivitar ViviCam 3630 Digital Camera
Vivitar ViviCam 3632 Digital Camera Logo
49 people viewed this question
Top Vivitar Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
