Fujitsu fi 6010n
Screen freezes after short time
Fujitsu Fi-6670. I have a little (microscopic) piece of paper stuck under the lower screen, so when scanning it appears a blu line over the whole page. How can i get it out? Thanks
Hello Alex,
You need to open the scanner and de-assemble some parts to remove the piece of paper which involves technical expertise. I would recommend to contact a Fujitsu scanner technician or call your nearest service center for assistance.
Thanks & regards,
ScanCare
Aug 28, 2013 | Fujitsu Fi-6240 Flatbed Scanner
Does fi 5120 driver works on Window 7?
Fujitsu fi-5120C is compatible with Windows 7. However, you have to download and install the scanner drivers for Windows 7. Click HERE to download the required drivers and toolkit (Installation & User Guides are also available).
Run the downloaded file and follow the on-screen instructions to install the scanner drivers/ toolkit.
Hope it helps! Good Luck!
CreativeTECH
Mar 16, 2011 | Fujitsu fi-5120C
I hope someone knows of an fi-4530c driver capable
Please be informed currently Windows-7 64-bit supported version of TWAIN & ISIS drivers for your Fi-4530C model is not yet released by Fujitsu. For more information, please visit the following link:
http://www.fujitsu.com/global/support/computing/peripheral/scanners/drivers/index.html#twain
You may also contact Fujitsu Support for further assistance.
Hope the above information is helpful.
Thank you for contacting FixYa.
Regards,
TechSatya
Aug 01, 2010 | Fujitsu fi-4530C Pass-Through Scanner
Please i use a fujitsu laptop E lifebook. When i boot the system on but gets a black screen. i tried taking out the hdd and still the problem persisted. Some times when i continually boot for couple of...
I have to tell you that 1 long beep followed by 2 short beeps are generated from bios for vga errors... This means that you have to get your laptor at the technician as sooner as posible in order to check the vga part of the motherboard for ventilation problems (that's the best solution for you) or for motherboard replacement (I don't think that this solution is very comfortable, since it will cost as a new laptop)
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Jun 26, 2010 | Fujitsu LifeBook E7010 Notebook
How do i get the driver to work for my Scansnap fi-5110eox2 onmy 64 bit system?
Check the link, look for the word 'Download' at the bottom portion of the screen:
http://www.fujitsu.com/au/support/scanners/drivers/eol_ss3.html
Have a great day!
Sep 12, 2009 | Fujitsu ScanSnap fi-4110EOX2 Path-Through...
Fujitsu fi-4530C
Hi
F at power on is a ROM Error. sounds like a main board issue. check for dry joints, but may need the whole board replacing.
Sep 04, 2008 | Fujitsu fi-4530C Pass-Through Scanner
How to remove Assembly pad message after replacement
you can reset this message in the scanner controll panel.
Please call windows <start>
<settings>
<system control>
<scanner and cameras>
open <scanner and cameras>
inside you will find your fujitsu scanner fi-5120C
now call <attributes>
-- in WIN2000 there is a button, in XP use the right mouse button--
in <device settings> you see the ADF counter, an the consumable counters for pad and pick roller.
Reset the changed parts, confirm the EEPROM writing
and the message will be cleared.
Jun 24, 2008 | Fujitsu fi-5120C
18 people viewed this question
k24674
