Question about Worx (16") 3.5 HP Electric Chain Saw - WG303
Spring at back of trigger is offs
How does it fit?
Fixing a trigger on an old impact wrench.
You will need to find a spring for the trigger, parts are hard to come by new unless it is a Snap-on or MAC brand.
Sep 07, 2016 | Impact Air Tools & Compressors
How to fit a trigger spring on a Ryobi Trimmer model PBC-3020
I have to go on general experience with my knowledge of Rybobi on this one. The handle of the unit where the spring is should have several screws in recessed holes. If you remove those the handle should split in two. When you do this make sure you are careful when separating it. There are usually some small parts that have specific places and you want to see how they seat back in there as you reassemble.
Aug 15, 2014 | Ryobi Garden
Why does my Hitachi nv45ab gun double fire nails?
This gun should be bump-fired only. Do not place the gun on the work and press trigger. Make sure that the safety spring is in place and has good tension. The spring helps to push the foot off the trigger so that it fires once. You could also adjust the screw that pushes on the firing valve. Turn in or out several turns till head of nail is correct when bump firing then lock the nut. The safety foot fits rather loose on the gun and should still work ok but can get so loose that it falls off the nose. Good luck
Jan 23, 2013 | Hitachi Air Tools & Compressors
Does anybody know how the spring catch in nds lite goes back together?
sry didnt quite understand your question but what i can get... its the trigger?? if it is the little spring with a loop of wire goes into the hole with 1 end of the wire going into the trigger then you drop the pin through and then put in the trigger slot then take a small flat screwdriver is what i use and push the wire into the slot that holds it...hope this helps
Mar 18, 2012 | Nintendo DS Lite Console
I think you call it the throttle trigger i dropped and it broke i cant give it the gas
You need to rplace the trigger, if this is a 350, start by removing the throttle lock on the top of the back handle, gently open up the slot where the latch fits, at the same time pry the rear end of the latch up, it will pop up at the back, once up pull the latch toward the back of the saw and away, now knock out the roll pin that the trigger pivots on, once out pull the trigger slightly back and down, it will just pull away, replace with a new trigger and re fit the the roll pin, push the throttle lock latch back into the tank and push the back end down to lock it into the tank, make sure the spring locates into the latch. adw1_11.jpg
Sep 18, 2011 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
Winchester model 88. with the trigger assembly
Less Than Perfect
The Model 88 had its faults. The trigger moves with the lever and the resulting linkage to the sear results in a rather spongy, creepy trigger break. If you want to see your gunsmith turn pale, waltz into the shop with an M88 and ask for a crisp three-pound trigger.
If you already have taken the gun apart, don't be afraid to hone the parts on a stone , keep them flat, you don't want anything rounded off. Especially the sear. I found that quote up top from a winchester sight,
Feb 22, 2010 | Optics
Trouble reassembling a daisy buckmaster 840 bb gun. We can not figure out the trigger mechanism in order to fit the side panels back into place.
1) Stack the trigger, seer (long black metal piece) and trigger block (large L shaped silver piece) on top of each other, with the seer in the middle.
2) You should have 3 springs, the long one attached to the end of the seer, the skinny one on the bottom of the seer and the fat one back between the trigger and trigger block on the back side
3) Compress the trigger block and the trigger together thus compressing that spring between them, keeping everything together. Now back the entire unit into the stock cavity. This is tricky and will take some practice. Be sure to keep the pieces squeezed together.
4) Insert the pin through the side which is countersunk. It only goes one way.
Jul 19, 2009 | Toys
Poulan 3400 chainsaw throttle trigger
Its a missing or broken spring in the handle(trigger). If you look inside the handle you should see a circular spring around the post of the trigger. This spring returns trigger to idle position. If its missing or broken the trigger won't spring back.
Oct 12, 2008 | Poulan Garden
Worx (16") 3.5 HP Electric Chain Saw - WG303 Logo
27 people viewed this question
Top Worx Garden Experts
Tim Whalen
ray gallant
Jay Finke
Jay Finke
Are you a Worx Garden Expert? Answer questions, earn points and help others
