Question about Kyocera Copystar 25600 Copier/printer/fax Machine
Cassette tray failure
Paper cassette tray failure
I Have an EPSON Stylus TX700W Printer , & am having problems getting it to feed paper. Have tried all the Paper Jam solving problems to no avail. Printer just keeps saying "The Paper Cassette is...
This can also be caused when the upper cassette tray (for small paper stock / photo paper) becomes detached from the lower tray. There is a gear attached to the lower paper tray which handles movement of the upper paper tray. Make sure that moving this gear causes the upper paper tray to move. If it doesn't, then you need to snap the upper paper try on a little better.
Jul 10, 2011 | Office Equipment & Supplies
Trying to print - got Warning message THe paper cassette is no set correctly. Check for any objects in the cassett of block the cassett path and insert correctly
Jun 26, 2011 | Epson Stylus Photo 810 InkJet Printer
I am getting a "fax output error - cassette." It
Pretty sure your paper tray button is set to get paper from the bottom paper cassette which is the tray that slides into the bottom of the printer.
If you switch the paper tray selection button* to use the rear feed tray you'll probably find it will print faxes successfully or you can put paper in the cassette tray...
*The paper tray selection button is just under (and slightly right of) the "Memory Card" button and has an icon image of the printer with two LED's (top and bottom). These lights indicate which of the trays is currently selected...
Hope that helps.
Dec 10, 2010 | Canon PIXMA MP830 All-In-One InkJet...
I cant find my manual how to i place the paper underneath so it feeds through the bottom
You can use the paper cassette located at the bottom of the printer, on the front when the output paper tray is closed concealing the paper feed switch, the usb port and the cassette lamp.
1 Gently pull out the cassette from the printer.
2. Remove the cover from the cassette.
3. Place your paper in the cassette tray.
a. when using A5 or larger sized paper (non standard sized paper, pinch the tab and extend the cassette if needed.
b. legal sized paper is not loadable in the cassette
4. Do not load paper above the load limit mar4k.
5. Make sure the print side of the paper is facing down.
6. Align the paper stack against the right side of the cassette
7. Slide the paper guides so they fit the loaded paper stack.
8. The paper cassette will hold up to 150 sheets of plain paper, however you do not eant to stack any more than 50 sheets in the Paper Output Tray.
9. Reinsert the cassette into the printer. Then set the cover on the cassette. Now make sure the cassette is pushed al the way into the printer. (If long paper was used and the cassette was extended iy will now extend beyond the front of the printer
10. Prepare the paper output tray by opening the front cover and pulling out the tray extension until extended completely.
11. Press the paper feed switch so the cassette lamp lights.
You can slo select the paper source with the printer driver if you prefer .
Mar 07, 2010 | Canon Office Equipment & Supplies
Message keeps paper tray is full and it is full.
pull cassette out and look inside the cassette bay on the left side. there is a white gear that lifts up your paper. that might have come unseated. make sure its seated in right by pushing it back in. last but not least, make sure you don't have your rear paper stopper in cassette pushing paper too hard against the front of cassette preventing paper from raising up.
Mar 09, 2009 | Brother MFC-8460N All-In-One Printer
Keeps saying no paper in tray although paper is in tray
I encounter that problem before, after I checked the sensors, feed unit and mechanism nothing is wrong or broken but still NO PAPER indicates on the display .I only noticed with the machine is the cassette tray or the paper tray, when you try to pullout the cassette tray and look at its left side, there is missing parts on it. There is a spring and actuator on it that will engage on the feed unit drive. Try to find the same machine and look at the cassette tray to see the missing parts on it. You can buy a new cassette because the parts that is missing maybe not available.
Feb 19, 2009 | Brother DCP-8065DN Black and White Copier
We have a Canon Laser Class 700 series fax machine. When it runs out of paper in cassette tray 1 it doesn't automatically begin to use paper from cassette tray 2. Both cassettes have plain white letter...
Swap cassettes.. The side guides on one of them may not be tight against the paper.
Only put paper in the lower cassette and try to print a journal.
Print out a configuration page or parameter list to see if the machine knows you have two trays.
Oct 30, 2008 | Canon Office Equipment & Supplies
Paper won't load from both cassettes
is the copier seeing the paper in the cassette, if yes then your pick up assy. connectors could be loose or your pick up assy s. are bad. try switching the assy first before replacing also check your connectors
Jun 19, 2008 | Canon CLC 1150 Color Copier
Kyocera Copystar 25600 Copier/printer/fax Machine Logo
27 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
