Question about Newco ACE-LP Coffee Maker
Sometimes the water will not shut off
Runs pots over with water
I need to know how to clean my coffee pot.
The pot or the whole coffee maker?
The pot you can wash with dish soap and warm water. Rise really good. If you want to clean the whole coffee maker you can fill your coffee pot with about 1/4 cup of vinger and the rest water run that through it and after that has run then run it 2 more times with just warm water to make sure all of the vinger is out.
Mar 09, 2016 | Coffee Makers & Espresso Machines
My keurig coffee maker is going really slow all of a sudden .. why would that normally happen
sometimes they become partially blocked and the best thing to do is run a quarter cup of vinegar mixed with a full pot of water through it empty and repeat if necessary. This will help to clean the tubes out of any residue and help to put it back to normal,
Be sure to run a pot or two of just water through it after the vinegar to rinse it clean of vinegar.
Oct 07, 2010 | Vacuums
Car turns off while driving it. Electricity still works car just stops working. Leaks water. Random sensors light up.
I have been having the same problem. Do you hit pot holes when driving that may possibly jar the battery in the car enough to shut the engine off? I have been having that issue, the only thing I can thing of is that the battery isn't securly on or even the possitive and negative cables need switched.
Leaking water-Have you had the radiator and water pump checked? I know in my case it has to be a hose (it could possibly be the reserve tank too) We fixed the main hose that goes to the radiator, but no such luck. I'm gonna need to put it up on the ramp and check all the hoses out.
Random Sensors- If you hit pot holes does your track off light come on? In that case I know that's normal. I also have been told that the older the car the more likely the "Service Engine Soon" light will stay on. I know I also have a problem with the fuse box, sometimes the lights in my car will turn off then turn on, and sometimes one headlight will work and sometimes it won't.
Jul 18, 2010 | 1998 Oldsmobile Intrigue
Water will not pass through seems clogged
Sometimes coffee grounds get into the intake if you don't use the intake filter. Unplug, set the pot aside and then turn the coffe maker upside down in a sink with a good hose sprayer. Direct the water up into the intake side of the coffe maker with the filter out.
Then refill and see if water will flow through. If it works, run vinegar or a pot of water with a tablespoon of dissolved baking soda (dissolve in pot first or it will clog the coffee maker).
It worked for me.
Apr 24, 2010 | Cuisinart DCC-1200 Coffee Maker
My Cuisinart 10 cup Grind & Brew does not finish the brew cycle. After brewing 2 cups of coffee, it beeps 5 times as if the brew cycle has ended. Then it continues to drip very very slowly. It's only...
you need to run a few pots of straight white vinegar through the machine to clean out the lime build up in the tubes. the first time you do it, after it starts to pump the water, shut it off for a few hours and let the vinegar sit in the tubes. after doing this run a few pots of cold water through before making coffee.
Nov 07, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Machine shuts off during brewing
Hello bean_54806,
This is a really common problem with the cuisinarts. I am most familiar with the DCC-1200, but you may be able to solve the problem. The may be an indication that something is plugged up. Open the top of the unit and in one of the corners you should find a water filter stick or column that is removable. Pull it out and open it up to clean out the clogged up carbon filter in there. (You can later buy a new filter on Amazon.) Clean out the debris from the bottom of the cavity. Replace the stick into the cavity once cleaned. Now it's time to run through a solution of 2 parts water and 1 part vinegar. Do this once or twice with fresh solutions, then with a pot of fresh water. When the filter stick is plugged up the sensor says its time to clean it or shuts the unit down, but most people don't know about this fix. I hope this is helpful to you, bean. Positive feedback is appreciated. Good luck. NormanZ
Jul 08, 2009 | Cuisinart DCC490SA Coffee Maker
Takes forever to make a pot of coffee
Decalcify the water holder. Run some CLR and water thru the brew cycle.
Mar 05, 2009 | Krups Caffe Bistro 867 Espresso & Coffee...
Won't make full pot
Okay, try this, make sure that everything is cool first, then take a turkey baster full of hot water and vinegar and shoot it backwards through the coffee maker...where the water falls on to the grinds. After that, try running either a commercial coffee pot cleaner or just again, vinegar through the brew cycle with no coffee in there. Try it two or three times, there may be calcium buildup in the filter and pump. You could also try that CLR cleaner, but make sure you rinse the pot out really good, and run a few cycles of just water before you drink anything from it.
Hope this makes sense and helps you out!
Jan 12, 2009 | GE Coffee Makers & Espresso Machines
When I turn the coffe pot on the light and everything turns on and it gets warm but the water doesn't come out. I shut it off for 2 hours and turned it back on and it started up then stoped again and just...
Sounds like a float is stuck in the shut position. You might need to take that to a service technician to double check that operation. Sometimes lines get scalled up with hot water deposits.
Run vinegar through the maker and see if that helps.
Apr 22, 2008 | Bunn BT10B Coffee Maker
Coffee Makers & Espresso Machines Logo
Top Newco Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Newco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
