Question about Kodak Picture Maker Kiosk Printer
Stalls at starting application
Error message failed to start
IMF.exe missing component rtl120.bpl how to restore it?
error is a common system error which tells you that rtl120.bpl file is missing or corrupted when you try to open certain files, applications or just start up the computer. Usually rtl120.bplerror happens when there is a conflict in the path of the Dynamic Link Library or when there is some missing/ corrupted entries in Windows registry. rtl120.bpl error may cause the related programs stop functioning and accesses areas of your system memory incorrectly.
Method 1. Fix rtl120.bpl error Manually by Going Tweaking The Registry Keys.
  • a. Click "Start" menu--"Run"--type in "regedit".
  • b. Delete these registry keys as below manually:
    HKEY_CURRENT_USERSoftwareMicrosoftWindowsCurrentVersionRun
    HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindowsCurrentVersionRun
list.jpgMethod 2. Fix rtl120.bpl error by Disabling Related Programs from Startup.
The DLL file would be infected by virus or Trojan. If the anti-virus program on your computer detects and deletes the infected file, you would probably receive error message alarming you that the DLL file cannot be found. You absolutely will fail to run the relevant application or program but keep receiving DLL error message on the startup. In such situation, you have to re-download and install the application to re-register the DLL information. Accordingly you have to disable an application run automatically on system startup in order to avoid such DLL error message:
  • a. Click "Start" menu--"Run"--type in "msconfig"---Start--- select the certain item to disable.
  • b. Reboot your computer.
Mar 21, 2012 | Toshiba Satellite L35-S2194...
I get an error message when starting web cam on my HP notebook
there is a problem with web cam drivers. if you want i can fix it online.
Nov 23, 2011 | HP Pavilion dv7-1132nr Notebook PC
The application has failed to start becous the application configuration is incorrect.this message appear when i start my messenger
Go to yoru control panel and remove yahoo messenger. Remove everything in the control panel that is yahoo related. When finished do a search and find yahoo messenger and reinstall it. Reboot your pc and that should fix the error. Your computer is missing files that are necessary to run yahoo.
Jun 29, 2011 | Yahoo Messenger
When I start game error message : "This
Hi Amysanford83,
I suggest that you download the CCleaner. Once installed, launch CCleaner and click REGISTRY on the left menu. SCAN for issues then click FIX all issues. After this, re install the application again.
Jan 31, 2011 | Viva Media My Boyfriend - Windows
Urlmon can't be found
goto Start--> Run and then type msconfig , now go to "Start UP " tab and then in the down pane you can find many services that start up when the computer is turned on. You can find the missing DLL profile there , the box may be unchecked or else select the option " Enable All" then click Apply and then OK. The error will be solved , and moreover this wont create any problem with the error message displayed. U can skip the error message if it again comes. This error message is due to the uninstallation of any program recently.
Oct 20, 2009 | Computers & Internet
YahooMessenger.exe - Application Error
install new version yahoo messenger from filehippo.com
it will solve ur problem
Jan 29, 2009 | Yahoo Messenger
Error Message
Try to clear your private data by clicking tools in the browser then options then privacy click clear private data. Restart your computer then reintall yahoo messenger.
Oct 17, 2008 | Yahoo Messenger
Kodak Picture Maker Kiosk Printer Logo
18 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
