Question about Samsung DV218AG Gas Dryer
De code flashes on gas dryer
Flashes de code
4 Suggested Answers
joshy999
  • 241 Answers
SOURCE: code de deblocage de portable samsung
on peut faire ca, mais on a besoin le portable. le code de securite doit etre resete.
nous sommes en canada si vous voulez le service - $15 + shipping
http://horizonwirelessonline.com
Posted on Jan 21, 2008
dali1195
SOURCE: le code de formatage de SAMSUNG Gt-S5230
samsunge j700
Posted on Oct 24, 2012
xerray
SOURCE: Code dE
right hand side under lid there is a magnet may have come unstuck. mine did through corrosion just put it back in same position with glue or something else. should do the job.
Posted on Feb 09, 2015
DE error code on Kenmore HE front loading washer
that is telling you there is a DOOR ERROR sometimes the magnet slips out of place or the wire comes loose .
Dec 21, 2016 | Kenmore Washing Machines
Como puedo aser para k se apage el chek trans de mi isuzu trooper 93
Check transmission lamp? my Isuzu trooper Apage 93 And disconnected plug, and even blinks stills
the lamp means transmission errors.
IS this car an automatic transmission.?
if yes, then some flash the OD lamp and others blink a check transmission warning lamp.
we find the car has TCM ? transmission brain and we scan it.
this old car has flash codes for TCM.
we insert the jump to the TCM DLC connector and it flashes out error codes, we write down and use to fix car.
translated
Compruebe la l?mpara de la transmisi?n? mi soldado Isuzu apage 93 Y enchufe desconectado, e incluso parpadea alambiques
la l?mpara significa errores de transmisi?n.
Este es un coche de una transmisi?n autom?tica.?
en caso afirmativo, a continuaci?n, algunos de flash El indicador OD y otros parpadear una luz de aviso de transmisi?n cheque.
Podemos encontrar el coche tiene TCM? cerebro de transmisi?n y escanearlo.
este viejo coche tiene c?digos de flash para TCM.
insertamos el salto al conector DLC TCM y destellos a cabo los c?digos de error, escribimos y usamos para fijar coche.
Oct 12, 2015 | Isuzu Cars & Trucks
El telefono galaxi spica se me bloqueo y me pide q inici cesion y le doy mi correo y no inicia
SE ME BLOQUE EL TELEFONO Samsung Galaxy Spica Gt-i5700 POR PASARME DE INTENTOS DE PATRON DE BLOQUEO Y ME ESTA PIDIENDO Q INICIE SECION GOOGLE Y NO RECUERDO BIEN EL CORREO
Apr 26, 2012 | Samsung Galaxy Spica Gt-i5700 Black...
El tv th-50px80u enciende un minuto y se apaga y luego da 12 flashes el led donde esta el problema en la fuente o en la placa A
Segun el manual servicio, esta falla se debe a la placa A que esta defectuosa. Antes de reemplazar la placa A, seria necesario de revisar los voltages de la fuente de alimentacion.
Si necesitas el manual de servicio, te lo puedo mandar via email.
Tengo una placa A disponible si estas interesado.
Nov 02, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
Como programar un control de dish a una tele panasonic
Depende del modelo del control remoto. Pero en general:
Press and hold the desired mode button (about three seconds) until all mode keys light up, then release.
Use the number pad buttons to enter the three-digit number corresponding to the equipment. The light will blink off after each digit is entered and then return to a steady light. Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times. To verify the code works, try several functions for that equipment.
Panasonic TV: 508, 509, 510, 511, 512, 566, 574, 575, 628, 644, 651, 662, 663, 668, 672, 673, 676, 685, 687, 689, 698, 697, 700, 706, 714, 716, 234, 247
Panasonic: 008, 009, 010, 011, 012, 066, 074, 075
Mar 05, 2011 | DISH Network IR Remote Control
"DE" system light flashing
The DE error comes up when the refrigerator has not detected a defrostcurrent within a certain amount of time. This is most often the resultof a burnt out defrost heater. The refrigerator will likelykeep working for a week or so until the frost builds up and blocks theair flow over the evaporator (the cooling coils behind the back wall ofthe freezer). The defrost heater is located at the bottom of saidevaporator.
You can try your zip code in http://www.geappliances.com/buy/ and look for a servicing dealer.
Good luck.Please rate my answer if accepted.Thank you.
Jan 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Panasonic CT32HXC14J Red Light flashes 6 times
tengo un panasonic th-50px80u tiene una raya negra de seis pulgadas el lado derecho de la pantalla como soluciono este problema.
Nov 23, 2008 | Televison & Video
AOC 7 F 17" the OSD keeps on flashing
DIAGRAMA DE CABLE VGA DE MONITOR AOC MODELO F1770 DE FABRICACION O MONTAGE EN CHINA
Aug 03, 2008 | AOC 7F 17" CRT Monitor
I NEED FAULT CODES FOR DRYERS
PF Power Failure
“PF”
flashes to indicate that a power failure occurred while the dryer was
running. Press START to continue the cycle, or press PAUSE/CANCEL to
clear the display.
F-01 Primary Control Failure “F-01” flashes when there is a primary control failure. Replace the machine
control electronics. See Accessing & Removing the Electronic Assemblies.
F-02 Keypad/User Interface
Failure
“F-02”
flashes when there is a stuck button or user interface mismatch. This
fault code will ONLY appear when in the diagnostic test mode. See TEST #5.
F-22 Exhaust Thermistor Open “F-22” flashes if the thermistor is open. See TEST #3a.
F-23 Exhaust Thermistor Shorted “F-23” flashes if the thermistor has shorted. See TEST #3a.
F-26 Motor Drive System Failure “F-26” flashes if there is a motor drive system failure. See TEST #2.
F-28 Moisture Sensor Open “F-28” flashes if the moisture sensor strip is open. This fault code will ONLY
appear when in the diagnostic test mode. See TEST #4.
F-29 Moisture Sensor Shorted “F-29” flashes if the moisture sensor strip has shorted. This fault code will
ONLY appear when in the diagnostic test mode. See TEST #4.
1M 2M 3M 5M 6M
= Contacts closed
Contacts
Function
Start
Run Red
Lt. Blue
Blue-White (Elec)
White (Gas)
Green-Yellow
Red
Black-White
BLACK
BLUE
WHITE BLUE
WHITE
WHITE
Pluggable Drive Motor Switch Gas Valve - Gas Dryer
Centrifugal Switch (Motor)
Gas Valve this is about close as i can come its matag electronic but not comercial should be about the same software though some where on or in the dryer should be a tech sheet with codes
May 21, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Samsung DV218AG Gas Dryer Logo
24 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
