Question about Reliable V100 Iron
No led display
Display does not light up
Heat goes off and red light blinks
Contact Rowenta if the yellow and red LED lights start to blink; this indicates an internal electrical failure.
There are over 200 complaints on the consumer affairs website, that include same this problem.
Its better to be safe than sorry.
Apr 24, 2014 | Rowenta Irons
Iron getting power light on but not heating up and dripping water
I have a Breville Iron 2200W it went into auto shut down and now i can't get it to work
Jun 30, 2011 | Breville Irons
My DZ9080 does not heat up. The lights come on.
If it does not heat up but lights is on, the reason being is the connection to the heaters is open or disconnected. It might be due to rust(water seepage) or overheat issues. Why the light is still on, its because the tap the supply to the led before the connections to the heaters. Try dismantling it to check the connection but most irons now is difficult to dismanlte without breaking something
Jun 10, 2010 | Rowenta DZ9080 Iron with Auto Shut-off
My iron stooped working all of sudden.I was pressing cotton clothes, all of sudden it stopped heating. No light in it.
If the input led is not glowing it means the connection to the mains inside your iron has got disconnected. Just open the iron. Check the input on the mains and check all the three wires are connected properly. It will heat again. When you were changing to cotton. You asked more voltage to the heating element and possibly due to more voltage the connection got broke and now the circuit is incomplete hence no led and no heatup.
Apr 25, 2010 | Irons
Is there a thermal fuse in a RUSK STR8 flat iron (problem: no heat ,but LED lights ) THANKS !
yes there is a thermal fuse in series with the heating element inside the unit
Mar 19, 2010 | Irons
The red power light comes on but the digital display doesn't always come on
The red power light indicates that your main power is getting to your iron and the digital display not working indicates that you have a problem with your iron electronics control circuit: if still under warranty, return it to be fixed otherwise consider buying a new iron as the repair cost in general can be quite high for 'electronic' iron (unless you have a handyman available!).
Hope it helps.
Feb 21, 2010 | Black & Decker Irons
It shuts itself off
The SHARK ELECTRONIC Iron is equipped with an electronic auto-off. The electronic auto-off switches the iron off if it has been left standing unmoved in any position (sideways, flat or upright) for approximately 7-9 minutes. A red light on the LED display panel will flash when the iron switches itself off. (Fig. 7) To switch the iron back on, just shake the iron side-to-side several times.
Jul 31, 2009 | Euro-Pro Shark GI490 Iron
On off light never shuts off
Clarification: When you "switch off" the unit, does the light stay on, but the steamer itself shut off (cools off to no steam)? If this is the case, only the LED does not light (which will not affect actual performance, other than being a "false" indicator driving some users crazy) like an Engine light that stays on in your car. It is likely a bad connection rather than a bad LED (Light Emitting Diode indicator). If the steamer portion is powered on all the time regardless of the switch position, try turning the temperature settings all the way down on the base and iron before unplugging unit to prevent the arcing (sparks) from damaging the input AC plug.
Solution: you will need a small Security Torx Bit/Driver to take unit far enough apart to inspect, troubleshoot and determine cause. You will also need an analog or digital multi-meter to check the unplugged unit' switch using self-powered ohm-out (continuity check) function, testing forward & reverse diode for lo & hi resistance reading respectively, (if you use the Rx1 range, the diode will glow slightly in one direction if it is good & you use an old analog meter). If you are so inclined or know somebody into electronics to do this, you can get these tools at Harbor Freight for $10-$20, good luck and keep in touch.
Apr 26, 2008 | Rowenta DG5030 Iron
Reliable V100 Iron Logo
27 people viewed this question
Top Reliable Irons Experts
Tom Chichester
Bill Boyd
Are you a Reliable Iron Expert? Answer questions, earn points and help others
