Question about Samsung DV218AG Gas Dryer
De code flashes on dryer
De code flashes dv210agw/xaa
Dv328aew/xaa runs about 10 seconds then stops with error code hE
Heater Error. Samsung believes only its customer support team is capable of solving the problem. If you go to www.repairclinic.com and enter Dv328aew/xaa, you may find a more practical answer.
Aug 29, 2016 | Samsung WF419AA Front Load Washer / Dryer
I am receiving an error message of L5 for my Samsung Dryer DV328AEW/XAA
I have uploaded the manual for this dryer to Fixya.com and the link to same is below. The following error information is on page 26 of the manual. Good luck to you:
INFORMATION CODES
Information codes may be displayed to help you better understand what is occurring with your Dryer.
CODE SYMBOL ( L5 )
MEANING
- Heater temperature control problem.
SOLUTION
- Call for service. See below. (see contact info in manual.)
Please let us know if helpful by clicking the button below, thanks!
http://www.samsung.com/us/support/owners/product/DV328AEW/XAA
7 3 cu ft Large Capacity Stainless Drum Dryer Neat White Samsung DV328AEW...
Jul 29, 2016 | Samsung DV328AEW Front Load Electric Dryer
Dryer has power, displaying no error code but will not run when I hit start
Try rebooting the electronics, by unplugging the power cord for 30 seconds. Then, plug it back in and try again. Can you give us any more symptoms?
Dec 23, 2015 | Samsung DV210AGW - 7.3 cu. ft. Sensor Dry...
Washer will not turn on
The main PCB control board has failed & will need replacing. I would recommend using a qualified technician to change it over.
Sep 01, 2015 | Samsung WF210ANW Front Load Washer and...
Error codes
what is the model number is to your dryer so we can get you fixed then okay??
Sep 15, 2013 | Samsung DV218AEB/XAA 7.3-CuFt Electric...
Samsung DV210AGW/XAA Dryer, drum wont turn nor heat up
hi all, thanks for your comments. to note, it's my dryer not my washer so the suggested solutions wont work. Also, forgot to note, the unit is only 14 months old and just out of warranty. What I've done so far:
- vacuumed the filter
- striped the dryer, meaning removed top. front and small exhaust panel in the back
- vacuumed everything
- checked the belt, tight, not loose, broken or off the roles
- child safty not enguaged, toggled it anyway to be safe
- the checked micro switch next to belt by motor, not engaged
put it all back, turned on with nothing, tried every setting in auto and manual tied high to low temps and times, the time is noted, such as 40 min, but does not time down, over time, the unit sound the I'm done tone, if left as is, continues to chime then end like it did something. all along, the drum never rotated nor did it heat up.
Does one impact the other, such as if the drum does not roll then the heater wont start or vise-a-versa. Could the control panel have taken a hit or are there sensors that might have shut down to prevent the unit from starting are there fuse's that I didn't see that might have been tripped.
Jan 04, 2013 | Samsung Washing Machines
My Samsung Dryer (DV218AEB/XAA) Error code HE
invalid heating temp when running. call for service.
Jun 07, 2010 | Samsung DV218AEW Electric Dryer
Samsung dryer dv317aeg/xaa has code on display
http://www.washingmachinereviews.org.uk/fault-codes/errors-and-solutions/ use this site try this solution is what the company suggests simply folo down the list till u see your error code with there solution if this does not work u willhave t call a tech to do test on your heater as well as the wiring going to the heater
Jun 24, 2009 | Samsung DV317AEG Electric Dryer
Samsung DV218AG Gas Dryer Logo
26 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
