Question about Dometic Heating & Cooling
There is a white wire at the back of our Dometic DS600H. What is this for?
    Genius:
  • Dometic Master
  • 1,363 Answers
If your talking about outside the unit it is a ground bonding wire.
Posted on Aug 24, 2015
I need a wiring diagram for the thermostat to the air conditioner
Typically red is power green is fan yellow is cool white is heat. Those four should make it work if it has batteries.
Dec 12, 2016 | Dometic Heating & Cooling
Place heating element on dometic 2652 . The 2 heater leads j7 and j8 need plugged back in. Does it matter which goes where? they are both black wires
heating elements are simply resistance wires and allow current flow in either direction
so there is noconsideration for polarity
either way will be correct
Mar 08, 2016 | Dometic RM2652 Refrigerator
How to wire six wire to three wire termenal
I'm pretty sure this thermostat uses digital communications with a dometic control board. In other words, there are no contacts in the digital thermostat to turn something on and off. Even if you ran a 12VDC wire to the thermostat for power, it won't work to replace a "real" thermostat. I bought one to replace my old analog thermostat and it's not going to work for me.
Oct 10, 2015 | Dometic 3313192.000 White Single Zone LCD...
I have a Duo-Therm Thermastat I diconnected the wires without marking them. I have a yellow, blue, red, white, orange, and black wires. Termination points are +.75, cool, fur, hi fan,fan,gnd. Where can...
Not knowing your model number, try here and click on AC-vehicles to expand for necessary info. If you can't get it from there, please reply with model number of your unit and I will assist you further. Good Luck.
http://www.dometic.com/enus/Americas/USA/Customer-Support/Operation--Installation-Manuals/
Aug 21, 2011 | Dometic Rooftop RV Air Conditioner
Mars motor has no white (common) wire??
You are looking for the nuetral wire,look on the mars motor it should have a wiring diagram stamped on it to answer your question
Jul 20, 2010 | Dometic Rooftop RV Air Conditioner
The Dometic DM2652 doesn't have temperature controls. My 2008 model freezes alomost everything on the top two shelves of the refridgerator. I use a low volume air circulator. Is there a way to lower the...
I have the same model in my 5th wheel. I found a white plastic piece on the far right side of the metal slats inside the refrigerator. This plastic piece has some kind of a probe attached to it. The white plastic piece slides up/down on the metal slat. There is a sticker next to this thing on the right side of the refrigerator (inside) that shows a range of "colder to coldest". I think if you slide that piece up/down, that is what controls the temp inside the frig.
Jul 12, 2009 | Dometic RM2652 Refrigerator
I have a DuoTherm BriskAIr 13.5K BTU. The Dometic thermostat also controls my HydroFlame 8531-IV furnace. This morning, the furnace would not come on. I checked the wiring and there is no voltage at the...
If you look at control box at roof unit, they usually use a separate set of wires for furnace. See what colors they are attached to at harness to thermostat. Some just follow other harness, and come out at thermostat. (bypass control box) Once you've determined which 2 they are, join them together & see if furnace starts, as it should. If it does, thermostat is faulty. If not, pull outside cover off & check voltages at furnace. I'm guessing by furnace model that your unit is approx 30 ft , but if it's a park model, you may have 24 volt system on furnace or 12 volt. Another way of confirming is to go to back of furnace where air intake grille is inside your unit, and locate 2 blue wires going to furnace & remove whatever wires are attached to them & connect them together. Furnace should start up.
Jul 08, 2009 | Dometic Rooftop RV Air Conditioner
Thermostat wiring for second ac unit
I replaced one unite with another and the wires are differance colors the old unites wires are red,purple,yellow,bleck and white the new one have orange,brown,cream,darkpurple,and white
Aug 01, 2008 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
47 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
