Question about Kitchen Appliances - Others
Cu2026 not making much ice
Little ice
  • 957 Answers
Sometimes the water inlet gets clogged. This happens a lot if u are using well water. Take the water line loose from back of fridge. fold the tube to stop water from leaking on floor if it is a plastic tube. have a bucket handy and put line in bucket let the water flow. It should come hard and fast. If not go to water valve where it pirces the main water line. check the hole and make sure it is large enough to supply the water. I had to take a drill bit and make the hole a little larger. That fixed mine. If that is not the problem then I would replace water inlet valve on the fridge.
Posted on Mar 26, 2014
Scottsman cu2026
does the water overflow?,, if its not pumping, its not being told to pump by level indicator or the pump is bad(common issue)
Apr 07, 2014 | Scotsman Ice Machine - 290lb...
Ice machine no longer makes ice consistently.
is this a ice machine or on a refrigerator ... either way you want to make sure your getting water to unit... make sure nothing is obstructing fill line and you are actually getting good pressure and fill time is correct... make sure you have a clean filter on unit and there is no scale build up in ice components... make sure temp. on unit is cool enough alot of the units out there have to maintain a certain temperature in order for ice production to stay up.... need a little more detail on what we are actually working on... hope this help out a little...
Dec 31, 2010 | KitchenAid Refrigerators
Not making ice
make sure the little wire handle is down on (over) the top of the ice bucket
Mar 29, 2010 | Frigidaire 26.0 Cu. Ft. Side-by-Side...
Frigidaire FRS26ZNHD2-ice maker stopped making ice called Frigidaires 800# they told me to replace the 2 stage water valve did that still no water to ice maker
ice maker is bad has it,s own timer built in to let water in if you have water to your unit ,,, be sure the little lever is down on top of the ice bucket. if it is up this will stop the ice making process this i s a device to keep the ice from over filling the ice bucket
Mar 29, 2010 | Frigidaire FRS26R4A Side by Side...
Ice maker makes too much ice
In my Kitchen Aid bottom freezer there is a metal arm(?) that I lift up to stop the ice maker from making ice. When I start running low on ice, I push the metal arm(?) back down for it to make ice again. Hope this is the solution for your Kitchen Aid too.
Jul 22, 2009 | KitchenAid Superba Architect KSCS25INSS...
GE Bottom freezermakes little ice
The ice maker has a temperature sensor inside that lets the ice maker know its time to drop the ice and refill with water. That could be the problem or the water control valve for the ice maker is not opening when its called to refill the trays. I will try to help you, Sea Breeze
May 19, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice maker has stoped making ice. The bar that cuts it off when enough ice is made moves a little while in the up position.
lifting the bar to the full up position is how you stop the ice maker from making ice. move the bar back down and ice making will resume.
Mar 08, 2009 | Whirlpool ED2FHEXN Side by Side...
Ice maker making little ice/Leaking water on floor.
The ice trays bust be cleaned to prevent calcium build up. This will prevent the ice from froming in trays.
The overflow could be caused by the freezer not being level, or by the water fill timer not shutting of the incoming water. This will keep the water temp. too high to freeze the water. Also check the fill valve for sepage.
Feb 05, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker not making ice. red light on control panel blinking twice.
Remove the ice bucket and inspect the ice maker for an ice cube stuck in the ejector. Hit it with a little heat of a hair dryer till it gets loose and the ice maker starts rotating. Replace the ice bucket. See if it starts making ice again amigo.
Jan 31, 2009 | Kenmore 53642 / 53644 Side by Side...
Makes little ice
this is normal when the ice is full it put the lever up o it wont continue making ice and must be reset once some ice is removed
Oct 06, 2008 | Maytag MSD2436GR Side by Side Refrigerator
Kitchen Appliances - Others Logo
41 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
