Question about Air Ride Management 1997-2006 Buick Regal, Century Plug and Play Air Suspension Kit
Dead car battery
Car battery goes dead if the car is not driven daily. All lights, etc are off, and there is absolutely no turnover of the battery, which has been replaced.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 127 Answers
Get Auto Elec to find problem
Posted on Jul 28, 2015
Why won't my key turn the ignition for my 2000 Dodge Stratus. The steering wheel is not locked but neither key will turn in the ignition.
Probably aftermarket alarm. Should be a small switch close to it to turn it off. If it were mine, I would remove the system .
Nov 28, 2015 | 2000 Dodge Stratus
Why won;t my 1982 toyota tercel start
Is it driven daily? Has it been sitting? The more information posted, the better. With this information.....out of fuel, blown fuse, fuel pump, timing belt, fuel filter, dead battery, etc. Does it turn over? Does it try to start but don't? Does it start and die?
Oct 18, 2014 | 1982 Toyota Tercel
04 PT Cruiser s off while driving and wont turnover at all
have a load test done on the battery as it may be dead flat or have a failed cell. Check the alternator output and check the condition and tension of the drive belt
Mar 15, 2014 | Chrysler PT Cruiser Cars & Trucks
When im driven my 02 pathfinder with the lights on the lights goes dim and the car starts to **** then goes dead while driven i have put a new battery and a new alternator on and it still does that so
could be starter or any number of wires best bet from my expirence is auto electician i had this fault on a customers car a year or so back and spent days on it then gave up and took it to my electrician who sorted it in no time for not a lot of cash
Feb 21, 2013 | Nissan Pathfinder Cars & Trucks
BMW X5 2001... Will not start/turnover when the key is in the ignition and turned lights on cluster etc work/come on but engine will not turnover and when trying to turnover lights start blinking ie...
This sounds like the battery may be weak or a bad connection. I would start by have the battery checked or try jump starting the car, try jumpimg it and see if that will make it start, if it starts then you may have a charging or battery problem, seeeing that this car is over 10yrs old and if the battery is the same one that came with the car then i would have to think you may have a bad battery. good day
Apr 10, 2011 | 2005 BMW X5
When car sits for 3-4 days, battery goes down. Car will not start. Turn switch, sounds like machine gun. Lights ( in and out) blink, horn beeps, pumps make noises, etc. Samde for additional attempts. ...
You either have a battery that is giving out on you or something is draining the battery when it stands for a while. Have the battery tested first . If that checks out ok then you will have to check for the electrical leakage in your system.
Feb 05, 2011 | 2004 Lincoln LS
2000 ford focus sedan 2.0 dohc ztec engine rear
check all battery leads and earth straps
"" car body and engen bay straps""
also check battery terminals are tight check its full of battery water too if its been low for a time bump it!
and have a ""drop meeter test"" done on the battery if its a bad battery it should show that up first time it could have cracked plates inside the battery its self, test by turning on head lights then hit starter, if every thing go's dead!!!! put ""good jump start"" battery on to car and try it again,,, all should work just fine then,,,,it could just be a flat battery?????
Oct 27, 2009 | 2000 Ford Focus
I went to the car yesterday and there is absolutly nothing it will not even turn over the only thing i noticed was the dash said gearbox fault but had just driven 20 miles untroubled please help
check the battery cables and the battery if it is weak or dead this will happen. try jumping the car off with another car. be sure to stand back once you attach the neg. side
Aug 23, 2009 | 2002 Jaguar X-Type
07 charger RT will not turnover
Could be a bad starter. crank no start?no start?
Aug 20, 2009 | 2006 Dodge Charger
Air Ride Management 1997-2006 Buick Regal, Century Plug and Play Air Suspension Kit Logo
96 people viewed this question
Top Air Ride Management Air Tools & Compressors Experts
Timllfixit
Andrew Taylor
Andrew Taylor
Are you an Air Ride Management Air Tool and Compressor Expert? Answer questions, earn points and help others
