Question about Wecheer Carving Handpiece
My wecheer carver makes a loud POP noise after about one minute of use and that blows all the garage power
Could it be a loose wire in the carver
What could be causing loud grinding noise when i switch on aircon? Aircon now not working but only makes loud sound.
Sounds like the bearing or part of the clutch in the A/C compressor has failed, or possibly component on a/c fouling on something due to recent repairs however would be unlikely and probably just a coincidence..
Check A/C compressor turns by hand, should be firm but not make any noises.
Check for fouling components related to a/c compressor clutch.
Feb 12, 2016 | Cars & Trucks
Rear HVAC unit in 2002 trailblazer making loud poping noise and then quits after a couple of minutes
The only thing i can think this would be is a blower motor noise, have shop take a listen is my best advice.
Oct 25, 2012 | 2002 Chevrolet TrailBlazer
Why does my carver receiver keep blowing the 4 amp fuse??(4amp 125v)
check speaker wires for shorts. verify correct speaker impedance (if amp if for 8 ohms, don't use 2 ohm speakers. Make sure not overheating issues with junk on top of amp.
Dec 29, 2009 | Carver Audio Players & Recorders
RCA HD50LPW164 turned on TV made a pop
the loud pop you heard was probably a capacitor blowing its top. The grinding noise is likely high voltage arching that was occuring due to rising voltage since capacitor isn't there to smooth it out.
Nov 02, 2009 | RCA HD50LPW164 50" Rear Projection HDTV
Not working plmv169dc
HI, the sound you herd was the noise filter and running diode. these important components have failed at this point. you will need to replace these components asap, if possible. this will fix your issue.
The Magnetron Cut-off fuse will need to be replace as well. this will blow if there is a malfunction within the unit.
Jul 22, 2009 | Frigidaire PLMV169DC Microwave Oven
On one minute then POP loud noise, burning smell
Loud popping and loss of power is common on plasma TVs and is usually either the Y sustain or Z sustain boards or buffers; in these instances the damaged part will be quite evident.
If this is an LCD you might have degraded insulation on one of the pink/blue backlight power leads causing high voltage to 'arc' to the chassis.
The loud bang and smell is actually to your advantage as in these circumstances the damaged part is usually evident. It'll just be a matter of popping the back off and sleuthing around. :)
May 18, 2009 | Sylvania Televison & Video
My r85 rinnai water heater vibrates significantly and makes
Sounds like there is something loose in the line.Like cut off valve,check valve.
Mar 09, 2009 | Rinnai Digital Remote Water Heater Control...
Heater fan noise-'02 Nissan Maxima
Had same problem. Replace Blower Motor. Over a 100 dollars at local parts store, but found online for half price. About 30 minutes to replace. http://www.rockauto.com/catalog/raframecatalog.php?carcode=1431961&parttype=6916
6 screws to remove glove box, One plastic nut on kick panel and 3 screws hold the blower to the air box.
Jan 28, 2009 | 2002 Nissan Maxima
Sub woofer making a screaching loud noise when powered on
The pop from other electrical items makes me think it's a ground problem but I am do not have a clue as to what type of setup you are running over there. Did you try a surge protector?Is it 110volts with a seperate ground wire?
Have you tried running a UPS?
Sep 26, 2008 | Logitech X-230 Computer Speakers
Wecheer Carving Handpiece Logo
82 people viewed this question
Top Wecheer Medical Experts
Andrew Taylor
Andrew Taylor
Are you a Wecheer Medical Expert? Answer questions, earn points and help others
