Question about Canon P150 Portable Scanner
Unknown error used on windows 8.1 operating system
How do I fix windows error update 8 to 8.1 0x80070003?
copied from windows website.
Windows Update error 0x80070003 Applies to Windows 8.1, Windows RT 8.1 If you receive Windows Update error 0x80070003 or 80070003 when you use Windows Update, try running the Windows Update Troubleshooter.
May 15, 2014 | Microsoft Windows 8 For Tablets
Tip
How To Identify Unknown Devices In Your Device Manager
Unknown Device Identifier enables you to identify Unknown Devices with the yellow question mark label in your Device Manager and reports a detailed summary including the manufacturer name, OEM name, device type, device model and even the exact name of the unknown devices. With this information you might contact your hardware manufacturer for support or search the Internet for drivers. Known devices recognized by Microsoft Windows will also be analyzed independent of the operating system.<br /><br />Supported Operating Systems include: Windows 95, Windows 98, Windows 98SE, Windows Me, Windows 2000, Windows XP, Windows Server 2003, Windows Server 2008, Windows Vista, and Windows 7<br /> <ol> <li><a href="http://www.zhangduo.com/UnknownDeviceIdentifier.exe">Download Now (HTTP)</a> Size: 948KB (971,455 bytes)</li> <li>When download completes, install Unknown Device Identifier.</li> <li>Open the Unknown Device Identifier when the installation completes and wait for the program to finish Analyzing all devices on your system.</li> <li>When the Analysis is complete, find your Unidentified Device in the list of devices.</li> <li>Click the + sign next to your Unidentified Device, and use the Chip, Vendor and Device information to find and download drivers for your device.</li></ol>
on Mar 11, 2011 | Computers & Internet
My desk calendars does not work with windows 8
try using the compatibility settings and see if it helps:
Right click the program and select Properties;
Select the Compatibility tab;
Check the Run this program in compatiblity mode for: checkbox;
Choose the Windows Xp Sp you had before;
If you want (sometimes it resolves the issue) then check the Run this program as an administrator checkbox.
Click Apply and then OK.
Now try re-launching the program.
If it still does not help:
Right click the program;
Select Troubleshoot compatibility;
Follow the instructions it gives you.
IF this still does not help then please reply!
Apr 01, 2013 | Computers & Internet
Is windows internet explorer 8 the same as microsoft internet explorer 8
Restoring Computer to earlier state is the best solution. Only update the Internet explorer by using online updates that is downloaded from Microsoft website. WebRepOverall ratingThis site has no rating(not enough votes)
Also try to update the drivers that control your PC.
If problem still occurs then use system utility tool PCFresher that will fix windows internal errors and will fix corrupt registry errors.
Dec 07, 2012 | Microsoft Windows XP Professional for PC
When trying to open WaveLab 6 using Windows 7 I get an Unknown TException error message.
""When trying to open WaveLab 6 using Windows 7 I get an Unknown TException error message."Don't know if this helps. I'm using Win 10 with Presonus Firestudio as my audio interface. I kept getting the unknown TException when I tried to open Wavelab 6. Solved it by going to device manager and disabling the internal AMD sound card and two "High Definition Audio devices" with mfg shown as Microsoft. Must have been hardware conflict between Presonus and internal sound card.
Dec 15, 2010 | Computers & Internet
Can I fix a C00D11CD: Unknown error for free ?
This problem has to do with codecs
(compression/decompression schemes) needed by Windows Media Player in
order to play back specific file formats. Try DL VLC PLayer see if that helps, plays just about everything.
Mar 16, 2010 | Microsoft Windows XP Home Edition
STOP C0000221 erro de hardware desconhecido systemroot system32 ntdll.dll
You may receive one of the following stop error messages while working on your Windows XP computer.
STOP: C0000221 unknown hard error
Path\File_nameSTOP: 0xC0000221 unknown hard error
C:\Winnt\System32\Ntdll.dll (or another specific file or driver)
STOP: 0xC0000221 STATUS_IMAGE_CHECKSUM_MISMATCH
Path\File_name
Note: The error message may be discussed in many different formats-blue screen or message box. It depends on when the corrupt file was detected.
Similarly, you may receive the following STOP messages when a critical system file fails to load on your Windows NT and Windows 2000 computer.
<path>\<file_name>STOP: 0xC0000221 unknown hard error
c:\winnt\system32\ntdll.dll
Note: Some other drive may also be given in the message.
On Windows 2000 the following error message may display:
<path>\<file_name>
You usually face this problem when an incorrect driver for one or more hardware is installed on your system. For instance, the error messages described above are displayed when you install a millions of instructions per second (MIPS) driver on a x86 system.
Cause of the Error
This error occurs if the file given in the error message is damaged.
Your Windows XP operating system checks the following files for integrity during system startup:
  • All driver files, excluding the files that loaded using the system loader to start your system .
  • All DLL (Dynamic Link Libraries) on the system. These include, Graphics Driver Interface (GDI), User, Ntdll, Crtdll, Shell, Kernel and several other DLL files on the system.
  • On Windows NT and 2000 computers, all DLLs loaded in the Window server address space are also checked.
The problem may also occur if an Iomega Zip drive is connected to the same cable as your hard disk drive.
Resolution Method
You can resolve this issue by removing the corrupt driver from your computer and then reinstalling a fresh and healthy copy of the driver. You may need to use the Device Manager utility to remove the driver. It is recommended that you clean your registry with the help of a reliable tool, such as RegGenie to ensure that all entries related to the uninstalled driver are removed from the system. After you have completely removed the corrupt driver, restart your system and install a fresh copy of the driver on the system.
If this step does not resolve the problem, you may have to reinstall Windows XP.
It is recommended that you regularly clean your registry with the help of a registry cleaner tool and perform antivirus and antispyware scan using tools, such as Antivirus Plus and StopZilla to prevent such errors from occurring on your system.
GOOD LUCK :-)
Feb 03, 2010 | Intel Computers & Internet
Itunes shuts down when itouch is connected
you need to look up help on disabling DEP for itunes.
Jan 04, 2009 | Microsoft Windows Vista Home Premium with...
C000221
change the operating system cd try again change ur ram with any other ram from ur friends and try thats it ur probelm gets solevd in one of the cases try them gud luck
Apr 16, 2008 | Microsoft Windows XP Professional With...
Canon P150 Portable Scanner Logo
43 people viewed this question
old marine
old marine
