Question about Flavia Creation 400 Drinks Station
Flavia creation coffee, pours out 1/4 cup
When inserting the flavia pouch, It makes a noise and pours 1/4 cup
It wont brew
Carefully clean the sharp pin that pouches the hole in the top of the k-cups by inserting a toothpick or paperclip into the hole where the water is pushed into the k-cup.You need to descale it by cycling some vinegar and water through it. Pour a couple cups of vinegar and a cup of water in the reservoir push the large cup size, you can reuse the vinegar mix just don't pour any grounds back into the resevoir.Do this several times (you should see noticeable improvement)then run some clean tap water through so your coffee doesn't taste like vinegar. Hope this helps!Justin
Mar 29, 2014 | Keurig Coffee Makers & Espresso Machines
HOW DO I CLEAN THIS COFFEE POT
I suggest you use vinegar acid.
You need a solution with half part water and half part vinegar acid.
1) pour 4 cups of water into your coffee machines water tank.
2) pour 4 cups of vinegar acid into your coffee machines water tank.
3) turn on your coffee machine to decalc.
4) refill tank with clean cold water and let it run through ( 2 times)
REMEMBER !!! ALWAYS POUR ACID into WATER !!!! AND NOT THE OPPOSITE !!!
If you pour water into acid it can explode and make terrible damages and cause chemical burns!!!
Hope this will help ypu
Jun 28, 2011 | Mr. Coffee JWX27 12-Cup Coffee Maker
Sometimes it pours only 1/2 a cup
clean the cup holder and clear the sharp tube . These get clogged from use, especially from cocoa
May 17, 2010 | Keurig Elite B40 Coffee Maker
The Keurig is heating up the water, yet is does
1. Power off machine.
2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle.
3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal.
4. Reassemble KCup cradle and reinsert it back into coffee maker.
May 13, 2010 | Keurig B60 Coffee Maker
I don't know how to make coffee.
The best way, if using ground coffee, 1 teaspoon per cup. Depends how big your coffee pot holds of water. So if you're planning to make coffee for 12 cups, just put in 12 teaspoons. Best Part is you can ground your own fresh ground coffee, or ground them at your Favorite Store, like Hazelnut etc.
You can buy the pouches. They make them for 4 cups 6 cups 8 cups, etc. (Like the ones they give you when you stay at the hotel). Fill the proper amount of water, for cups you're making.
My favorite are the single cups. Folgers makes them in regular and decaf. Look like tea bags, and they for 1 Medium Cup of Coffee. After you are done, just throw away.
Good Luck :0)
Nov 11, 2009 | Krups Coffee Makers & Espresso Machines
Flavia Coffee Maker coffee sprays outside cup
I bet that's wild thing to see. Ok, Is ther a basket that'ds supposed to be there? If not,heat up a large paper clip,straightened of course and run it yhrough the hole. If the nozzle will come off, clean the burrs of the edges of the hole on the inside. It sounds like it's restricted if it's spraying. Good luck
Jul 10, 2009 | Coffee Makers & Espresso Machines
First cup of the day ony fills half way
Have you cleaned the exit needle? Seem to be clogged up, more info here: http://www.keurig.com/help/B60_Use&Care_guide_spreads.pdf
Nov 16, 2008 | Keurig B60 Coffee Maker
Flavia Creation 400 Drinks Station Logo
51 people viewed this question
Top Flavia Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Flavia Office Equipment and Supply Expert? Answer questions, earn points and help others
