Question about Epson Stylus Photo Px660
Fatal code : 0xE
Print error
How do I fix Fatal Error Fatal Codes:0X50 for Epson WF-2530
there is a driver update to this on there website.. http://2682220.r.msn.com/?ld=d3r7GeHDlTJrBUpqiKpMxT4jVUCUxr5V_qRawzP5W1kwg55cbcz5eg53VjPRThl_AClX5g-BdWf6mHDw2SlSJsTLfN9nJeK4phMY0-ErdgNCyKWWQgEXUUIi9nCuedGmcy6X7gtUKmemkIwZMZZFqFwJ3TIWhMol4QEau4TTcG8TFQ8ApN&u=https%3a%2f%2fwww.pcsupport4me.com%2fprinter-tech-support%2f
Nov 11, 2014 | Epson WorkForce WF-2530
What is a Fatal Error: 140 on a Xante HSE?
That error is image yellow drum up/down senser. Shut down your printer and reseat the drum make sure it is loose and not tight when placing it into the unit.
Oct 02, 2014 | Xante CL30 HSE Laser Printer
Fatal Error code 10H
C 0010H - Color PC drum malfunction.Check the motor for proper drive coupling and correct as necessary.Check the motor connector and the electrical board connectors and the mechanical transport drive components(gears,couple).
Apr 05, 2013 | Konica Minolta Magicolor 2530 DL Laser...
OD ERROR
Fatal error code 0D: No head error
A check of the print head thermistor circuit during power-on initialization determined that the PRINT HEAD is not installed. This error is caused by the following:
? The Print Head is not installed.
? The Print Head built-in thermistor element has failed.
? The Carrier Cable is disconnected or damaged.
? The Print Head temperature detection circuit has failed
Jun 07, 2011 | Epson DFX-9000 Matrix Printer
Fatal code 0x50
Hi, Hope this helps,I downloaded & manually Translated it from a Russian Website (I speak Fluent Russian)!!
fatal error code 10x50 Home position error. Possible causes : Foreign object, Deformation of the Main Frame, Change Lever failure, Paper jam.
Last fatal error code 20xF1 PF PID excess load error. Possible causes : PF Motor failure, PF drive mechanism overload (paper jam, foreign object, insufficient grease, deformation of the Main Frame), Tooth skip of the PF Timing Belt, Improper tension of the PF Timing Belt, Cable disconnection, Main Board failure (Motor driver failure).
Last fatal error code 30x50 Home position error. Possible causes : Foreign object, Deformation of the Main Frame, Change Lever failure, Paper jam.
Last fatal error code 40x0A CR load position excess load error. Possible causes : CR Motor failure, CR Unit drive mechanism overload (paper jam, foreign object, Change Lever failure), Cable disconnection, Main Board failure (Motor driver failure).
Last fatal error code 50x50 Home position error. Possible causes : Foreign object, Deformation of the Main Frame, Change Lever failure, Paper jam.
Oct 10, 2010 | Epson PictureMate 500 InkJet Photo Printer
I just replaced the fuser unit in my Okidata 5200 and it will print for awhile and then stop with a fatal error #177. How do I fix this?
lift your top cover up and check the ribbon cables to the black leds (4) under the cover 2 on each led, these have been known to be loose and cause those fatal error codes
Jul 09, 2009 | Office Equipment & Supplies
Minolta 2300 dl laser printer fatal error 17H
had printer for approximately 2 years. Used daily in office setting. today the printer tried to print, then just stopped and it said fatal error 17H in the window. We cleared paper jam and rebooted, gives the same error message. Anything we can do?
Apr 14, 2008 | Konica Minolta Magicolor 2530 DL Laser...
Fatal error 163
Fatal Error 161-Toner Sensor Error, Color:Magenta
When magenta toner sensor error has occurred
Fatal Error 163-Toner Sensor Error, Color:Black
Both are Sensor errors....You would first check the lock levers that hold the toner cartridges in, if everything is fine with them then you could possible have toner dust on the sensors. First take out the cartridge that you are having problems with, then use a dust off can and carefully clean out any axcess toner that you can see where the toner sits. there is a sensor that looks like a clear plastic or glass eye that reads the cartridges and it sometimes gets dirty.
Jan 11, 2008 | OKI C5200n Laser Printer
Konica Magicolor 5430 DL Fatal Error Code: 0300H
0300H: Polygon Motor malfunction
try restart if not helping then there can be problem with ph unit or PWB-A board
Sep 11, 2006 | Konica Minolta magicolor 5430 DL Laser...
Epson Stylus Photo Px660 Logo
46 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
