Question about 2010 Audi A5 - Coupe - Sunbrella Extreme Sun Car Cover
Intermittent speaker sound
I need to check the wiring connections to the central speakers
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Covercraft Master
  • 1,449 Answers
Check the connections on your amp may be dirty or loose.
Posted on Mar 03, 2015
Why is it intermittently losing channels...front speakers and or rear surround?
How to troubleshoot low sound or no audio from the rear ...
https://us.en.kb.sony.com/.../how-to-troubleshoot-low-sound-or-no-audi...
Aug 15, 2015 - Verify that the rear surround speakers are properly connected to the ...For Dolby® ProLogic surround sound, the center-channel mode must be set to ... the center or rear surround speakers for the Home Theatre (HT) system.
Why Are My Speakers Producing Static? - Electronic House ...
www.electronichouse.com/.../home-audio/why-are-my-speakers-produci...
Here are 3 reasons that speakers produce static and solutions you can try. ... If they are your dedicated front L/R channels speakers in a 5.1 or 7.1 system, you more ...Since you have no problem with your existing rear speakers, if they begin to distort on... Home Theater Subwoofer Puts Boom in This Room · Soundbase vs ...
How to Check if your Speakers are Wired Correctly ' Richard ...
www.richardfarrar.com > Podcasting
Mar 25, 2009 - Attaching speakers to your Hi-Fi system usually only requires a few cables. ..... Is this test applicable for a home theater setup with 5 speakers? ... frontstereo speakers, but to do a similar test on your rear surround speakers would ... Yes, switching polarity on one channel of the amp output to your speakers ...
Pioneer VSX-816 speaker drop out - AVS Forum ' Home Theater ...
www.avsforum.com/.../1068233-pioneer-vsx-816-speaker-drop-out.htm...
Sep 20, 2008 - 30 posts - ‎24 authors
The right front speaker sound drops out intermittently as of about 6 months ago. ...mode and back to Auto Surround would bring the center channel back. ... the push pin that holds several grey wires in place, and pull the wires loose. 9. ..... Is it possible that the cold joints are elsewhere in the system, but that ... Yamaha RX-V663: Intermittent/No Audio in Front ...
Jan 23, 2014
Sony Receiver going in to Protect Mode
Jan 12, 2012
The Official Sony STR-DH820 Thread
Aug 29, 2011
Denon AVR-1910 - No more sound.
Feb 15, 2011
More results from www.avsforum.com
Dec 12, 2015 | Audio Players & Recorders
Control pod failure on bose companion speakers , the sound stops
check your wiring connections, sounds like you may have intermittent connection somewhere, and this is the most likely culprit. be certain that all connections are solid. multi pin plugs are notorious for having one bad pin.
Mar 06, 2015 | Bose Companion 5 Multimedia Speaker System...
How do I repair
I guess you have tried switching the speaks left to right to check its the speaker rather than the output to the speaker?
If you have it might be worth (If you are able to) opening up the speaker unit to check the wires are still attached and solid, maybe need a little re-solder is needed as the wires are usually very thin.
Sep 19, 2014 | Altec Lansing VS2121 Computer Speakers
No sound from speaker but through ear piece I get sound.
Many devices will automatically switch off the large speaker when ear phones are plugged into them. Also there may be a switch or button or prompt on your radio to switch between regular speaker and ear phone jack. Look for that first.
Try connecting and disconnection ear phones while listening to a station and see if the problem is intermittent. If is works sometimes but not every time then it is most likely an internal connection.
You will have to access the inside of the radio to investigate further. Connect a working external music or sound source with speaker wire to the terminals inside the radio that connect to the radio's speaker. If the radio's speaker works with the external sound source then you know it is a bad connection inside your radio. If the radio's speaker does not work with the external sound source then it is most likely a faulty radio speaker. Look closely for a broken solder point or broken/disconnected wire.
Sep 10, 2013 | Eton E100 SW/FM/AM Radio
Technics stereo
These units are known for having bad solder connections develop over time. Would have to check bottom of main board for bad connections especially around amp ic's and voltage regulators.
Apr 26, 2013 | Audio Players & Recorders
Dialog track not playing for a 5.1 DVD
swap the audio jacks and then try.
Dec 03, 2008 | Onkyo TX-SR705 Receiver
A215 Speaker no sound on right speaker
I'm having the same problem with my speakers, and I'm convinced it's a faulty wire. I've noticed when I wiggle the connections on the back of the speaker the sound comes out intermittently. I'm currently trying to figure out how to open the casing so I can more closely examine the connections inside and hopefully fix the problem permanently.
Nov 28, 2008 | Audio Players & Recorders
Intermittent problem no sound
Double and triple check your connections. I soldered my connections on a speaker a little while ago and I found out that it only looked soldered and it was alittle loose and would cut out. Also you could check a site out, installdr.com. You should be able to find out the wire colors for you speakers there. Although I don't think that, that will cause a big problem. If you are listening to music at loud volumes, I would also recomend an aftermarket amplifier. It adds so much more that a factory amp can. Just food for thought. Good luck.
-Andrew Hawkins
Sep 04, 2008 | Q-Logic Q-Customs Car Speaker
Sound
I dont Believe you can! If its the central speaker its made to be louder if look at the tech details here:
http://www.amazon.com/Logitech-X-540-5-1-Speaker-System/dp/B000JJM8XE/ref=dp_return_1?ie=UTF8&n=172282&s=electronics
it says 15.4 watts for central channel
unless you know how to wire in resistors then i cant think of anything else
Dec 19, 2007 | Logitech X-540 Computer Speakers
2010 Audi A5 - Coupe - Sunbrella Extreme Sun Car Cover Logo
37 people viewed this question
Top Covercraft Vehicle Parts & Accessories Experts
Tenderfoot
Tom
ptpumpman
Are you a Covercraft Vehicle Part and Accessory Expert? Answer questions, earn points and help others
