Question about Sharp LC-37A33M 37 inch Multi-System LCD TV
Sharp lc37a33m burned component in motherboard near component identification no ic2802 (C011A E10813).
Can't find the interior fuse box on a Cadillac CTS 07...looked under the back seat not there.
This Cadillac factory service info . Doesn't lie ! your vehicle has four fuse boxes !
Fuse Block - Left Rear
In the passenger compartment, under the left side of the rear seat at carpet
Power and Grounding Component Views
Electrical Center Identification Views
Fuse Block - Right Rear
In the passenger compartment, under the right side of the rear seat at carpet
Fuse Block - Steering Column
In the passenger compartment, behind the driver knee bolster, at the base of the steering column near C202
Fuse Block - Underhood
In the engine compartment, in the right front corner
Aug 23, 2016 | Cadillac Cars & Trucks
Were is the fuel filter my my olds sill. van 2001?
Fuel filter component identification-the fuel filter is located on the frame rail near the tank
Oct 29, 2010 | 2001 Oldsmobile Silhouette
MY Compaq 6910p Laptop powers on for about 3 seconds and then powers off when the battery is installed. With AC power this sequence continues nonstop. I have check the battery and the power supply with...
There might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Oct 08, 2010 | HP Compaq nc6320 Notebook
Bumped computer on door casing..power female connection broken inside. how easy to fix???
The DC jack, where you plug the power adapter cable, might be loose or defective, & needs to be either re-soldered or replaced.
In order to do this, the laptop needs to be disassembled & the motherboard taken out. Also, the motherboard needs to be checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Sep 16, 2010 | Acer Aspire 5000 Notebook
My Dell laptop only charges when the plug in where the charger meets the computer is propped up or held up. I tried my new charger and have the same problem. Now, the icon says plugged in, but not...
Sep 16, 2010 | Dell Latitude D510 Notebook
I HAVE BEEN TOLD THE MOTHERBOARD HAS COME UNSODDERED FROM "SOMETHING". I HAVE TO HOLD THE POWER JACK AT A CERTAIN ANGLE TO BE ABLE TO START THE LAPTOP UP, THEN IT WILL SHUT DOWN AFTER 10 SECONDS. CAN...
Sep 15, 2010 | Toshiba Satellite A75-S211 Notebook
DC Power jack heats up to very hot to touch on HP NX9010 laptop.
Sep 09, 2010 | HP NX9010 Notebook
Msi wind u120 ac connector quit working? problem @ the computer not the ac cord. can i repair this?
Sep 08, 2010 | MSI Wind U120-020US Netbook
MY CHARGING ADAPTER IS UNABLE TO PLUG IN TO MY LAPTOP THE DC IN SECTION ON THE NOTEBOOK SEEMS TO BE DAMAGED WHAT DO I DO?
Aug 31, 2010 | Sony Computers & Internet
I steped on the power cable to my laptop and now the cable doesnt charge. i think it is in the plug in area there alot of wiggle in the computer any way to fix it?
Aug 29, 2010 | Computers & Internet
Sharp LC-37A33M 37 inch Multi-System LCD TV Logo
24 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
