Question about Blueant S4 Handsfree Voice Controlled Bluetooh Car Speakerphone
On/Off Switch broken - Blueant S4 Handsfree Voice Controlled Bluetooh Car Speakerphone
McCulloch ms354 on/off switch does not stop engine when switch to off position. Easy fix or does the module that connects switch to spark plug need replacing?
wire broken on the switch or switch is broken the switch is part of a very simple circuit that when switched on shorts to ground the wire from the coil
Oct 30, 2017 | McCulloch Garden
Thanks.. I have a onan 7500k living in from the storm. Will not start with remote inside switch. But you can shut it off with inside switch. Outside switch works great.
Need more info.
Inside does it have an 'on/start' switch and a separate 'off' switch ?
If it does -
1) the start switch is bad.
2) could be a broken/loose/corroded wire at the start switch 3) broken/cut wire to the Onan
4) broken/loose/corroded wire at the Onan where the inside start switch connects.
The fact that it starts at the Onan tells you it's OK.
Sep 17, 2017 | Electrical Supplies
Brake light switch not working
If you press the brake pedal and the rear lights don't work, It can be a number of things. Blown bulbs, Blown fuse or a broken circuit. The broken circuit could be a cable or connection failed, a broken switch or a bad earth. The fact that both lights don't work would indicate the problem is most likely to be a fuse or a switch. Just because you can hear the switch click, doesn't mean it is working. Replacement of a brake switch should only take a novice mechanic about 30 minutes.
Mar 24, 2013 | Cars & Trucks
Samsung notebook N150 on/off switch broken
One of two things is broken. 1) the rear fork of the plastic switch is suseptable to bending a breakage. 2) The springloaded switch whick is soldered to the base circuitboard could also be broken.
Jun 05, 2011 | Samsung Tablets & eReaders
Wireless switch is broken on my acer aspire 3680.
No you need switch,if you use a tiny screw driver you can turn it on with that if its just the plastic peice thats broke.use the screw driver to slide the mechanisam
Oct 04, 2009 | Acer Aspire 3680 Laptop
Will not start up. It has power to it.
Check the following to address this issue.
Door switch / Door switch actuator lever
The dryer will not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
If all the above inspection check out ok and, the door switch or actuator is functional, replace the timer or control board.
Jun 18, 2009 | GE Dryers
97 expedition new window motor and switch still don't work
You have to use a voltmeter and make sure the motor is getting power. If no power at the motor, check for power at the switch, first make sure power is coming into switch, and then operate the switch and make sure power is going out to the motor.
Make sure you have a good ground on the door.
Could have a broken wire between switch and door, or between fuse block and switch. A wire can be broken on the inside without the insulation being broken
Jun 10, 2009 | 1999 Ford Expedition
Dryer knob sticks in one spot- won't move
 Door switch / Door switch actuator leverThe dryer would not start with a broken door switch. Replace the door switch if found defective.
Oct 25, 2008 | Maytag Clothes Dryer Almond Timer Knob...
Broken on/off switch
need to replace the on/off switch for this camera. I have the broken piece that cannot be repaired. How can i find a replacement switch. I can repair the camera myself with the new switch. thanks.
Jul 19, 2008 | HP Photosmart M425 Digital Camera
Blueant S4 Handsfree Voice Controlled Bluetooh Car Speakerphone Logo
Top Blueant Cell Phones Experts
Richard Foster
Richard Foster
k24674
Katlin Donnelly
Are you a Blueant Cell Phone Expert? Answer questions, earn points and help others
