Question about Tools & Hardware - Others
SCM T-100 shaper manual
L'invincible
Have a ch1001 shaper image 100 cd changer stuck in Jammed mode? Tried powering off and unplugging. No luck! Help!
There is usually a tiny pin hole at the front were you insert something like a paper clip that overrides the lock and allows you to pull the draw out manually.
May 02, 2015 | Car Audio & Video
Smith Corona SD650 Model 5A Ribbon
This takes an "H" series ribbon SCM #21000
DickyO
Apr 10, 2013 | Smith Corona Typewriter SD650 Refurbished...
User manual for an (1993?) SCM Panelsaw Model SCM SI 12 SW?
I am looking for one too! Have you had any luck?
Feb 16, 2012 | Garden
Delta+router/shaper+manual
you are welcome, I didn't post but the thanks are grealy appreciated.
Dec 31, 2011 | Delta Tools & Hardware - Others
I have a jvc kd-s590 in my car & have no idea how to set the clock. It'd driving me crazy. Please help!
1 Press and hold SEL (Select) for more than 2 seconds. "CLOCK H", "CLOCK M", "SCM LINK" or "LEVEL" appears on the display. 2 Set the hour. 1 Select "CLOCK H" if not shown on the display. 2 Adjust the hour. 3 Set the minute. 1 Select "CLOCK M." 2 Adjust the minute. 4 Press SEL (select) to finish the setting. 1 2 During tuner operation: During CD operation: Frequency Clock To check the current clock time (changing the display mode) Press DISP repeatedly. Each time you press the button, the display mode changes as follows. To Cancel Advanced SCM You can cancel the Advanced SCM (Sound Control Memory), and unlink the sound modes and the playback sources. When shipped from the factory, a different sound mode can be stored in memory for each source so that you can change the sound modes simply by changing the sources. LINK ON: Advanced SCM (different SCM for different sources) LINK OFF: Conventional SCM (one SCM for all sources) 1 Press and hold SEL for more than 2 seconds. "CLOCK H", "CLOCK M", "SCM LINK" or "LEVEL" appears on the display. 2 Select "SCM LINK" if not shown on the display. 3 Select the desire mode - "LINK ON" or "LINK OFF". 4 Press SEL (select) to finish the setting. • If the unit is not in use when you press DISP, the power turns on, the clock time is shown for 5 seconds, then the power turns off. 1 2
Nov 03, 2010 | JVC KD-S590 CD Player
Need manual for Delta shaper cat, # 43 375
Here's a link to a 43-370 HD shaper manual (13mb), but that's the only one delta seems to have online. (See search results here.) For older machines, you may find something useful here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jun 28, 2009 | Delta 43 - 455 Heavy Duty 5 - Horsepower...
Looking for a Manual for the Delta SH100 Shaper, how to Operate this Shaper
Hi, Bob, Check E-Bay. I have seen several different instruction manuals come up for auction from time to time. They may be photo copies, I'm not sure. But its worth a shot. Rick
Apr 11, 2009 | Delta Tools & Hardware - Others
Tools & Hardware - Others Logo
57 people viewed this question
Top Tools & Hardware - Others Experts
john h
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
