Victor 1260-2 will power on, give a very short hum/buzz then go quiet and not work.
It sounds like there may be an issue with the motor that drives the paper feed mechanism. The hum/buzz that you hear when you turn it on could be the motor trying to start but failing to do so. The tightness of the paper feed could also be related to the motor issue.
The green "E" on the screen likely indicates an error. Without more specific information about the error code, it's difficult to determine the exact issue. However, it's possible that the error code is related to the motor or paper feed issue.
If you're comfortable doing so, you may want to try opening up the machine to see if there are any obvious issues with the motor or paper feed mechanism, such as a loose or broken part. If you're not comfortable doing this or if you're unable to identify the problem, it may be best to take it to a professional for repair.
