Question about Cub Cadet Street Sign- tractor lawn riding mower parts
Cub model 1170 drive wont disengage
I have a cub mod 1170 i am fixing for a friend it has new drive belts 1 new idler and a new double pulley in the rear i have adjusted the idler from 1 extreme to the other same result there is no slip in the system to allow the mower to stop moving and the drive pedal has a nasty vibration i have checked belt routing and went by the book to adj the idler and its all correct any help would be great thanks
    Problem Solver:
  • 12 Answers
There should be a pulley somewhere in the belt assembly that lifts up ti allow slack in the belt. your problem sounds to me like you have messed something on the clutch up and the pulley isn't lifting up to let there be some slack in the belt to disengage the drive.
Posted on Jun 15, 2009
Have a 1045 ltx cub cadet lawn tractor,belt for deck keeps coming off when disengaging?
be sure the belt guides are in place. they hold the belt in so the belt wont fall off when not tight or at an angle.
Jun 29, 2017 | Cub Cadet Garden
Cub cadet 1170 will not move drive belt looks ok
Safety pin in the drive pulley may be broken.
May 12, 2017 | Cub Cadet Garden
I need help putting rear end back together on a 10 hp30 Murray riding lawnmower
Safety and Preparation Serious injury can occur if the engine or mower blades accidentally start while you are working with lawn tractors. To prevent this, drive the Murray lawn tractor onto a flat work surface and disengage the mowing deck cutting blades. Engage the parking brake to keep the mower from moving; chock the wheels with a wooden block or brick. Adjust the mowing deck to the lowest position. Turn off the engine and remove the key from the ignition. While not necessary, you may even wish to disconnect the spark plug wire from the spark plug. Mowing Deck Removal You must remove the mowing deck on a Murray lawn tractor to gain access to the belts. Remove the adjustment rod hairpins, followed by the adjustment rod pins from the front left and right sides of the mowing deck. At the rear on the left and right sides, pull out the retaining hairpins and slide the mowing deck suspension links from the adjuster plates to separate the rear mowing deck from the frame. Remove the blade control rod stud, including the hairpin and washer, from the top of the blade control lever shift linkage at the left rear of the deck. Remove the front hanger rod, including the hairpin and flat washer that hold the rod in place. Loosen the belt guide retaining bolts with a socket wrench and remove the engine stack pulley belt so you can slide the mower deck out from under the tractor Transmission Drive Belt Installation Slide the new transmission drive belt between the engine stack pulley belt guides, over the belt guide plate and under the engine stack pulley. Fit the transmission drive belt around the top engine stack pulley. Push the free end of the transmission drive belt up through the transmission shifter hole in the lawn tractor floorboard. Slip the transmission drive belt loop over the transmission shifter. Pull the transmission drive belt down through the transmission shifter hole. Fit the transmission drive belt around the transmission drive pulley and tighten the transmission drive pulley belt guide retaining bolts to hold it in place. Fit the transmission drive belt flat side around the idler pulley. Slide the idler pulley onto the idler pulley stud while holding the belt in place. Tighten the transmission idler pulley retaining nut with a socket wrench to secure the idler pulley to the idler pulley stud. Mowing Deck Drive Belt Installation Pull back on the right side mowing deck mandrel pulley spring-tensioned belt retainer. Guide the new mowing deck drive belt around the right side mandrel pulley and release the belt retainer. Pull the drive belt spring-tensioned retainer away from the mowing deck idler pulley, guiding the deck drive belt around the idler pulley. Fit the mowing deck drive belt around the left side mandrel pulley and under the rear mowing deck cross link rod between the right and left side mandrel pulley. Slide the mowing deck under the right side lawn tractor frame, reconnecting the deck to the frame in reverse order of removal. Engage and disengage the mower deck while driving the mower to test the belt for proper operation.
Sep 28, 2016 | Murray Garden
Can you show me the correct diagram for the drive belt on a 44in Dixon zero turn mower
Hope this helps. Serpentine Blade Drive Belt
1 Lower the mower deck to its lowest position.
2 Route the serpentine blade drive belt (part number 6109) onto the V-pulleys located on the mower deck. One double pulley is located at the front of the deck near the center. The other two pulleys are located near each side of the deck. Route the belt around the outside -- the side toward the outer edge of the mower deck -- of each pulley. For the double pulley near the front of the deck, route the belt around the lower pulley (part number 6058) only. If pulleys are fitted with belt guards, work the belt in between the pulley and shield.
3 Push the idler pulley toward the center of the deck with your hand. The idler pulley (part number 6059) is the fourth pulley on the deck and is located near the rear of the deck. It is the only movable pulley on the deck. Wrap the belt around the side of the pulley nearest the edge of the deck. Release the idler pulley to place tension on the belt. No adjustment is necessary because the serpentine idler spring (part number 6065), located on the idler pulley, adjusts the belt to the correct tension.
May 10, 2016 | Garden
I have a 2006 Cub cadet LT 1045. My model only has one idle pulley. I am having a hard time keeping belts on. Does anyone know a fix for this
have you got the belt on the right side of the idler pulley
the back of the belt should be running on the pulley
Sep 25, 2015 | Cub Cadet Garden
How to replace mower belt for ZTR cub cadet mower
Changing the Blade Drive Belts:
a.Set the parking brake. Remove ignition key and both spark plug caps.
b.Unscrew the wing nuts from the deck covers and remove both covers.
c.Using a 3/8" socket breaker bar or socket ratchet insert the drive end into the 3/8" square opening in the lower idler arm assembly and push the idler arm counterclockwise. While holding the idler arm back, loosen the blade drive belt from the pulley and slide the belt away from the pulley.
d.Remove tension of the PTO belt by moving the belt tensioning rod. Loosen the belt retaining bolt.
e.Pull the tensioner pulley away from the belt and remove the PTO belt then remove the blade drive belt.
f.Reverse the process to install the belt.
Jan 08, 2015 | Cub Cadet z-force 60
Cub cadet SLT 1554 keeps throwing the drive belt
Double check the routing diagram. Check to make sure your idler pulleys are in good condition. Bearings are good. Lastly the tension spring may be worn. The belt should fit very snug. No more than 1 1/2" of deflection when you push on the belt with your thumb
Oct 15, 2012 | Garden
It makes a loud knocking noise when running with or without someone on it.
Dear Sir:
I will help you inmediately.
The troubleshooting is Mechanical here is the details:
Treadmill Noise:
1)Front or rear Roller(PULLEY) ASSEMBLY BEARING: Solution: Isolate and replace roller assenbly
2)Drive Belt loosing ......................................................Solution: Adjust tension belt
3)Idler PULLEY.........................................................
Solution: Replace Idler Pulley
4)Belt Seam Need breaking in...................................
Solution:New Belt Replace
Thank you in advance,If you need some extra help reach me, sincerely. blessing.
E.CUADRA
Managua, Nicaragua. C.A.
Sep 13, 2011 | Exercise & Fitness
How do i set the timing belt on a 1997 cadillac catera?the betl did not break but how do i make sure the belt did not move a couple of teeth.
Hi, there should be marks on the belt itslf that align with hatch marks on the timing gears. Below are the instructions for installation. From these, you should be able to verify that the belt is in time. There are also some diagrams here: http://www.2carpros.com/diagrams/cadillac/catera/1997
To install:
  1. Install the timing belt.
    1. Start at the crankshaft pulley.
    2. Install the timing belt with a double dash (TDC) mark on the belt aligned with the marks on the oil pump and belt drive gear.
    3. Pinch the belt with special tool J 42069-30 to prevent the splines from jumping.
  2. Route the timing belt through the idler pulley for camshafts 3 & 4 then route the timing belt through the camshaft gears 3 & 4.
    1. Ensure the dash marks on the timing belt align with marks on the camshaft gears and the notches on the rear timing belt cover.
    2. If necessary, loosen timing belt idler pulley or move the cam gears slightly, with J 42069-1 and 2 still in place, until the timing belt can be installed.
    3. Tighten the idler pulley locking bolt until snug. The idler pulley bolt will be tightened to specifications after the final adjustments are made.
NOTE Timing belt deflection between the camshaft gears number 4 and the idler pulley for camshafts 3 & 4, must be no more than 0.4 inch (1 CM.).
  1. If necessary, adjust the timing belt deflection by turning the timing bolt idler pulley eccentric, for camshafts 3 & 4, counter-clockwise with the special tool J 42069-40, or equivalent.
  1. Route the timing belt through the timing belt idler pulley for camshafts 1 & 2 then route the timing belt through camshaft gears 1 & 2.
    1. Ensure the dash marks on the timing belt align with the marks on the camshaft gears and the notches on the rear timing belt cover.
    2. If necessary, loosen the timing belt idler pulley or move the cam gear slightly, with J 42069-1 and 2 still in place, until the timing belt can be installed.
    3. Apply sufficient tension to the timing belt to prevent it from slipping off the gears by turning the timing belt idler pulley eccentric for camshafts 1 & 2 counter-clockwise with special tool J 42069-40 or equivalent.
    4. Tighten the idler pulley locking bolt until snug. Idler pulley bolt will be tightened to specifications after final adjustments are made.
  2. Route the timing belt through the timing belt tensioner.
  3. Apply initial tension to the timing belt by turning tensioner eccentric counter-clockwise, with a 5 mm hex wrench, until marks are set.
    1. Tighten the belt tensioner-locking nut to 15 ft. lbs. (20 Nm).
  4. Adjust the timing belt.
    1. The timing belt must be properly adjusted or engine damage may occur. Do not continue with the engine assembly procedure until the timing belt is properly adjusted.
  5. Install the timing belt cover. Tighten the timing belt cover bolts to 71 inch lbs. (8 Nm).
  6. Install the power steering pump pulley and bolts. Install the water pump pulley and bolts.
    1. Tighten the power steering pump pulley bolts and the water pump pulley bolts after the serpentine drive belt is installed.
Mar 04, 2011 | 1997 Cadillac Catera
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
484 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
