Question about Lexmark X6650 4-In-One Wireless InkJet Printer
Paper lost in printer
5" x7" paper is lost inside the Lexmarx x 6650 printer. How can we located it without taking the whole printer apart?
    Sergeant:
  • 199 Answers
If printer not show any error message (and in ready mode) then place a art sheet in tray and print a page attend paper forcefully by hand to remove lost paper with this art sheet if printer show any error message like paper jam try to remove with open the front door
Posted on Jun 14, 2009
Hi I have HP 1210 All in one, and now it wont print. It tell me to check paper (none there, even inside..) and cardridge. And whats more important, when I turn it on, cardridge start riding from left to...
hi
1. 1 Switch off the printer and disconnect the powersupply. Allow any residual charge to fade away before putting your hands ormetal tools inside the chassis. 2. Step 2 Pin down the exact location of the jam. Thethree hot spots for a jam are the paper tray, anywhere between the feed trayand the print carriage, or between the print carriage and the output tray. 3. Step 3 Take off the front paper tray if the sheet gotstuck while it was still in the front area of the printer. If the sheet jammedhere, you should be able to see most of the paper. 4. Step 4 Pull on the sheet with both hands and steadypressure. Do not tug as you might rip the paper, leaving a chunk of it deeperin the machine. 5. Step 5 Open the back panel to reach paper jammedbetween the feed tray area and the print carriage of the all-in-one printer.Carefully remove the jammed paper from the machine. 6. Step 6 Use the carriage access door to reach a jamfurther inside the all-in-one printer. You may need to move the print carriageout of your way to clear the jam. 7. Step 7 Return any access panels to their closed andlocked positions. Plug your printer back in and flip the power switch.
Jun 14, 2011 | HP PSC 1210 All-In-One InkJet Printer
Printer will give a message of paper jam appears to be unable to pick up paper from tray . Can I fix this with a new paper tray if so where do I get one ? Or is there a better solution
I have worked on many a printer and I have yet to find one that when it says there is a paper jam is lying. You may need to take the printer apart to find the jam. It can be the tiniest of paper and can be located in an area that is difficult to find without taking the printer apart.
It also may be that the rollers that pick up the paper are bad. These should be easily replaced. Check the manual or help support online with the printer manufacturer for replacement parts. Typically the paper tray does not have the rollers so replacing the tray may not help you.
Apr 27, 2011 | Brother HL-4040CN Laser Printer
Epson R2400 letterhalf borderless printing
No Borderless option for custom paper sized. Borderless prints are only available for pre-define paper size like 8.5"x11", 4"x6", 5"x7", 8"x10", etc.
Jan 23, 2010 | Epson Stylus Photo R1800 InkJet Printer
There is a tiny piece of paper stuck inside that we can see but can't manage to get out. How do we take the printer apart to get the paper out without damaging the printer?
Instead of taking it apart,try to get a stiff piece of paper or a thin cardboard to force into the paper path to push the stuck paper out.
Oct 09, 2009 | HP PhotoSmart 7960 InkJet Printer
I need to print on 5 x7
Go into the print settings and change the size of the document there. The printer may be set to 5x7 but the document you are printing isn't.
Jan 10, 2018 | HP PSC 1315xi All-in-One Printer
Lexmark T614 horizontal lines on right the left margins
This sounds like a cartridge problem if you have changed the cartridge and the problem persists I would say it is the positive charge roller inside the printer. If you open the cartridge door and remove the cartridge with the cartridge out starting closing the door and you will see this roller moving down from the top inside of the printer. do not touch this without a glove or lint free cloth. not hard job to change if you can get one in your area if not we have them available.
laserguy@nbnet,nb,ca
Feb 05, 2009 | Lexmark Optra T614 Laser Printer
Epson Aculaser CX11NF
I've reviewed your printer design and suspect there is truely a "paper jam" located in the process feeder. If you will follow the directions for cleaning the printer head located on page 15/16 of the link below, I bet you will find your lost paper. This printer requires a long path of travel for the printed paper to eject. The printer head is about the half-way point of its travel, so this would be a great place to investigate.
http://files.support.epson.com/pdf/cx11n_/cx11n_pg.pdf
I hope this helps!
T-Mo
Feb 09, 2008 | Epson ACULASER CX11NF All-In-One Printer
Samsung 300CLP "paper jam"
I have just posted my "fix" for the paper jam elsewhere on this forum. Check it out and I hope it helps you too?
Nov 24, 2007 | Samsung CLP 300 Laser Printer
Printing problem
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} When printer does not have visible paper jam and printer is showing error paper jam
Check if the Encoder Strip is Broken or Missing
1.Power down the printer and unplug the power.
2.Slide the cartridge carrier inside the printer a couple of inches to the left.
3.Locate the encoder strip (Figure 1) on the right-side of the cartridge carrier encoder strip
Note:
The encoder strip is a plastic strip with small markings over its entire length. The strip may appear to be translucent.
Reposition the Encoder Strip
1. Remove the power cord from the printer.
2. Lift the scanner unit to expose the inside, where the printer cartridges are located.
3. Gently slide the ink cartridge carrier to the middle of the printer.
4. Gently move the top part of the printer belt to the right.
5. Using an index finger, gently push encoder strip (Figure 1) down and then back up, to get it back into the slot located on the back of the ink cartridge carrier.
6. Gently press the strip first to the rear, and then forward, to ensure that it is seated correctly.
7. Manually move the ink cartridge carrier to the left, then to the right, to check the positioning of the encoder strip.
8. Once the encoder strip has been re-seated, close the scanner lid.
9. Re-connect the power cord to the printer.
Ensure the Paper Tray is Not Overfilled
Each printer tray has a maximum capacity rating, and this rating is based on a specific paper weight and or thickness. Consequently, situations might arise in which the tray will not be able to accommodate the maximum number of sheets listed in the printer specifications. Verify that the paper is not packed too tightly in the paper tray.
Adjust the Printer Paper Guides
Adjust the paper guides to fit the size paper being used .The guides should be close (1/16" or less) to the paper without touching, so that the paper stays properly aligned without continually rubbing the guides.
Locate and Remove Any Obstructions Inside the Printer and Input Tray
1. Open the front cover and make sure the kickstand (if there is one) is engaged.
2. Locate and remove any obstructions within the printer, such as paper pieces, staples, tape, or other objects.
3. Close the cover.
4. Remove all paper from the input tray.
5. Inspect the input tray for any obstructions.\
6. Remove any visible obstructions.
7. Reinsert the paper.
Nov 22, 2007 | Dell 922 All-In-One InkJet Printer
Lexmark X6650 4-In-One Wireless InkJet Printer Logo
118 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
