Question about Microsoft Windows XP Home Edition
Problem rebooting turning on and even if using start up
6 days ago when a friend turned on her computer, it wouldn't turn on. Finally after 11 tries the computer turned on. 5 days ago it took 15 attempts to turn the computer on. That's when she contacted me for help. What we have found so far. . .We contacted support through microsoft, who recommended we run a onecare scan on her computer. The computer ran the scan, but before I could return to see the results, the computer was turned off. After repeated tries we got the computer to turn on and we ran the scan again. It said it found 1 major problem and it was Win32Winfix. We ran the process to clean the problem. I also ran a scandisk, and it found a few things run, so I ran the scandisk/f on reboot. Of course, we had problems getting the computer on again. Yesterday, microsoft support recommended to restore the computer to an earlier setting, even though that meant hitting restart once again. That's where we are at now. I've not run into a problem like this with a computer not starting when you use the stop, turn off computer, restart. I am currently away from the computer that has the problem. Not sure if it is going to start when I get there. Any suggestions?
  • Microsoft Master
  • 4,924 Answers
If it just do not start ...the problem may be the operating system that cached some issue...but if the problem is that the system keep on restarting itself on boot until starts...the problem is more then sure with the RAM memory ....I bet its gave some blue screen errors almost each time it wont start ..and said something about failing ...0000000and something like letters or a digit
anyway ..do not insist in ..just try t reinstall a clean os ..fromthe disc...and format in NTFS slow the partition windows will run ...and see if it fix the problem ...it may also be caused by a missing file that was deleted during the clean up ...( bug related) ...lets hope that s the issue ...cause if it is like I suspect ...you wil have to replace the ram memory
Posted on Jun 14, 2009
D:/ is not accessible. Disk structure is corrupted and unreadable.
You may have simply 'cooked' the DVD drive and the motherboard on it fried. Replacement drives start at 20 quid for a desktop and 30 quid for a laptop. It's held in with 1 screw if a laptop. Remove the drive, get the model number and replace it.
Mar 10, 2014 | HP 530 Notebook
My toshiba Satellite l455d-s5976 will power up but screen stays black. Now this problem has been reoccuring since maybe last week where my stepfather left it on and it locked itself. I tried to turn it on...
when the laptop is off hold the power button until 1) the screen goes on or 2) it turns on. if 2 then try connecting a monitor to the laptop and reboot.
Sep 07, 2013 | Computers & Internet
Hi I am having a bit of a problem... A few days ago I kept getting this message saying I needed to update my flash player. So I said yes, my computer went nuts! I started to panic so I tried setting it...
It's possible that the "extra" disk-activity (downloading & installing Flash Player, and using "System Restore" to activate a previous check-point) was enough to cause the disk-drive to "die".
Take your computer to a qualified technician, for proper trouble-shooting. You'll probably need to buy a new disk-drive, and to reinstall Windows.
Nov 01, 2010 | Sony Computers & Internet
Hi, i have a dell inspiron 6400 and since yesterday when i turned it off it re-started itself on and enter directly in to the media direct express automatically. i´ve been starting it and pushing the...
turn off, as it starts to reboot tap f8 key continually and choose safe mode. from safe mode do a system restore to last restore point before problem began.
good luck
Oct 21, 2010 | Dell Inspiron 6400 Notebook
Light Status on Netgear WGR614
Access router. What does it say? did you set up the wireless network yourself? Is the cable modem working properly? Rebooted it? Is there a problem with the internet provider?
Dec 14, 2008 | NetGear WGR614 Router
Why won`t my mp3 take itself off hold?
Power & Hold switch
Slide and hold in the opposite direction
of the arrow for power on/off.
Slide in the direction of the arrow to
lock the button functions.
If that fails,
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Apr 15, 2008 | Samsung YP-T10 Digital Media Player
Problem when turning monitor off
mcdevito75 here LCD, or liquid Crystal display, chances are the crackling is the inside liquid display trying to capture the in comming electricity to make a display picture. Remember even an LCD is nothing more than a light bulb, a very intricate light bulb but a light bulb, and you have light bulbs burn out when you put them on and almost never as the are on burning. Turning the monitor itself off won"t really save electricity or the monitor itself as, when you shut down the computer from Start (left side of screen) the monitors screen saver comes on for 10--20 minutes then goes off, at this point the electricity is at the monitors on/off switch and not going thru the monitor at all. If you turn the monitor off at it"s on/off switch, the sudden jump of electricity to the monitor from it"s on/off switch could hurt it, or even the switch. I have a friend who turns off the monitor also and that friend had a bad monitor in 3 years. I never turn my monitor off just the computer itself. I'd speak with a Radio Shack, Staples, Best Buy ETC. for more advise. Me I;d say leave the monitor on. Hope this helps.
Mar 27, 2007 | Samsung Syncmaster 730B 17" Flat Panel LCD...
Microsoft Windows XP Home Edition Logo
111 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
