Question about Quantum Rz28-e 2.1gb 50 Pin Scsi Hard Drive Rev:j01
How to fix disk drive errors on rz28-e
What rae the commands to fix the disk drive errors. It's running under system software vers VMS 6.1
    Master:
  • 785 Answers
Replace it
Posted on Aug 18, 2014
How to fix InPageCoFire error
this is a decide error code. Your hard drive may be having problems. I would suggest doing a disk scan
CHKDSK /R /F
as well as system file scan/repair
SFC /scannow
Do this from a DOS command line (make sure to run as administrator)
ex.
http://www.howtogeek.com/howto/windows-vista/guide-to-using-check-disk-in-windows-vista/
Feb 22, 2015 | Microsoft Windows 7 Home Premium 64BIT...
Tip
Fixing Errors On Your PC for Windows Vista,7,8 and 8.1
I'm only going to show those interested how to run chkdsk (check disk) and fix errors, there are other commands mostly you'll just want to run this command. Click the Start button in the Search box, type command prompt in the list of results, right-click Command Prompt, and then click Run as administrator. In the command prompt, type in the following command chkdsk C: /F . Only type what is in bold, what this is going to do is check the drive for error and fix those errors. If the drive isn't locked it will bring up a message asking to scan the drive on the next restart click yes, if the drive is locked it will start scanning automatically. This depending on how large your hard drive is can take some time or not, be patient because this usually always fixes issues people are having that call me, other times I have to look at their PCs. Hope this helps you out.
on Feb 20, 2015 | Microsoft Windows Vista Ultimate Edition
How to fix error code 2000-0142
Did you try booting your computer in Safe mode to check if you receive this error message?
1. Use F8 while restarting the computer.
2. Under Windows Advanced Boot Options select Safe mode and hit Enter.
Check if you receive this error message in Safe mode.
It seems like your drive might be corrupted. If your computer is still under warranty, I would suggest you to contact them to get a replacement. But before you contact them, let us see whether Check disk utility would make a way to boot windows succesfully or not.
If you've Windows Vista Operating System disc, then try running the check disk utility from Windows Recovery Environment.
1. Put the Windows Vista installation disc in the disc drive, and then start the computer.
2. Press a key when you are prompted.
3. Select a language, a time, a currency, a keyboard or an input method, and then click Next.
4. Click Repair your computer.
5. Click the operating system that you want to repair, and then click Next.
6. In the System Recovery Options dialog box, click Command Prompt.
7. Type the following command and press enter.
Chkdsk /r
Once your machine has finished repairing the hard drive, type EXIT and press ENTER to restart your laptop.
You can also try typing the following command if Check disk fails to fix the issue. At the same command prompt, type fixboot and press enter.
For your information: If you've a Dell Laptop, then according to Dell, the error code 2000-0142 is a Drive Self Test failed error code. Visit the link below:http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?c=us&cs=19&dl=false&l=en&s=dhs&docid=14B3819735D6B40EE0401E0A55177ED2&doclang=en#HDD
hope 2 help
http://www.bostonrecycling.net/
Jun 18, 2012 | Dell Inspiron 1525 Laptop
Disk read error occurred on hp mini 110-3135
Sounds like your disk drive has a problem. Now is the time when you need a CD drive to fix it or attempt to fix it by running the Check Disk Utility.
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when the options appear.
In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
May 11, 2012 | Computers & Internet
Non-System Disk or Disk Error Boot from CD
The error means that the CD you have in the drive is not a system disk. Remove it. Are you trying to boot from a CD, if so make sure it is a repair disk or operating system disk. If not, remove the disk and you system will then look to boot from the Hard Drive.
Run the Check Disk Utility.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
Apr 30, 2012 | E-Machines eMachines Desktop PC
Upon connecting the samsung G2 to my laptop, it says "needs formatting" but when click the format disk option it says "disk can not be formatted'
Many errors in Windows are caused by corrupt files. Those files could have become corrupt because of errors on your hard drive. The Check Disk tool checks for errors and attempts to fix any it finds.
Warning: Use Check Disk at your own risk. On rare occasions I've experienced problems when using check disk in Windows Vista. Here are a few things to watch out for:
If you run check disk and your computer has to be restarted to scan your computer and your computer hangs at a black screen when it boots up, do the following: Turn the computer off and back on and immediately start pressing F8 on your keyboard repeatedly. A black screen with different boot options will appear. Select to use the Last known good configuration (advanced) boot option.
Never stop check disk once it has started. It could take hours to days to scan your hard drive depending on its size. How-to Use Check Disk Using the Graphical User Interface (GUI)
Open the Start Menu and click Computer. Right-click the drive you want to perform a check disk on and select Properties. Click the Tools tab in the drive Properties window.
Click Check Now under error checking. To perform a complete check of your hard drive for errors check off both options in the check disk window that pops up.
Click the Start button to start the process. If you are trying to check a hard drive that has open files you'll get a message similar to the one shown below.
Click Schedule disk check. Disk check can't check a hard drive that has open files. Your computer will reboot and check the disk before Windows Vista boots up. If you want to cancel the scheduled disk check for any reason, check out this guide.
Using the Command Line Interface
Check Disk can also be run using the command line (DOS) prompt.
Open the command prompt with administrative privileges by typing cmd in the search box in the Start Menu and right-click cmd.exe in the search results and then select Run as Administrator. Type chkdsk followed by one or a combination of switches listed below in the command prompt. If you run the check disk (chkdsk) command from the command prompt by typing just chkdsk check disk will run in read only mode. All it does is check for errors. It will not fix any errors it finds unless told to do so. This is done by adding switches when typing chkdsk in the command prompt.
A switch looks something like chkdsk /F. Notice the switch /F after the chkdsk command.
Below is a list of most of the switches used with the check disk command. You can use one or a combination of switches with the check disk command.
D: If you want check disk to scan a drive other than the C: drive, add the drive letter after chkdsk to tell it to scan that drive. If the drive is called X: on your computer it would look like chkdsk X:.
/F: The /F switch is the most common of the chkdsk switches. It tells chkdsk to fix any errors it finds. Chkdsk can't fix errors on a disk that has open files. If chkdsk asks you if you want to check the drive next time Windows Vista boots or dismount the drive choose to check the drive next time Windows Vista boots. Never choose to dismount the drive. That option should only be used by a professional.
/R: The /R switch tells chkdsk to attempt to recover any bad sectors of the hard drive if any are found. A bad sector is a spot on the hard drive that can't hold saved data anymore.
/I: The /I switch tells chkdsk to perform a less detailed but faster disk check.
/C: The /C switch tells chkdsk to skip the checking of cycles within a folder structure which reduces the scan time. Don't ask me what this means.
An example of an exhaustive disk check using the command line interface is:
chkdsk D: /F /R
The check disk command shown above will fix any errors it finds and also attempt to recover bad sectors of the D: drive if any are found.
If all else fails, try 3rd party tool SpinRite.
Apr 18, 2011 | Samsung G2 Portable External HX-MU064DC/...
I have done a monthly backup on my laptop for more than a year, but this time I'm getting an error message "corrupted file system 0x81000008
Run a check disk on the Drive and select Fix bad sectors.
    Running CHKDSK through the Windows Command Prompt:
  1. Go to the Windows Command Prompt. You can do this by clicking first the Start button and then clicking the Run button. After this, type "cmd" in the Open text box and press Enter.
  2. View the displayed Command Prompt screen.
    If you want CHKDSK to run in read-only mode, type:
    CHKDSK c:
    If you want CHKDSK to fix errors and not to check bad sectors, type:
    CHKDSK c:/f
    and press Enter in the Command Prompt.
    If you want CHKDSK to run thoroughly; that is, fix errors, find bad sectors in your hard drive and recuperate still readable data, type:
    CHKDSK c:/r or
    CHKDSK c:/p and press Enter in the Command Prompt.
  3. Running CHKDSK through My Computer (Windows XP)
  4. 1
    Initialize the properties of the hard drive you want CHKDSK to run. Open My Computer. Right click your mouse on the drive in which you want CHKDSK to run. Click the Properties button and click the Tools tab. In the Error-checking box, click the Check Now button.
  5. 2
    Set up the Check Disk options by checking one or both check boxes displayed. These are labeled "automatically fix file system errors" and "scan for and attempt recovery of bad sectors". If you want CHKDSK to run in read-only mode, do not check either box. After this, click the Start button.
Jan 01, 2011 | Western Digital My Book Essential Edition...
When i power on the laptop it says "please install windows in your hard disk " but when i reboot it 5-6 times it loads the windoes automaticaaly . please help
Hi, This problem usually occurs when your HDD or your Hard Disk Drive is showing signs of bad sector. I would suggest that you run this command in Command prompt to check the integrity of your file system. its not loading normally because it is sensing from problems with the files. > click start > run > cmd > hit enter.. on command line type "sfc /scannow" after hitting enter you will see a progress bar. Any corrupt, missing or incorrect files would be replaced by this process. If this option doesn't work, you could try to run a checkdisk to see if there is a bad sector in the hard drive. heres how:
  • go to my computer
  • right-click local disk c: and choose properties
  • go to tools tab
  • then click error checking
  • a box will appear and you have 2 choices
  1. Automatically Fix file system errors
  2. Scan for and attempt recovery of bad sectors check boxes
After clicking on start a window will appear telling you that you need to restart the computer to run the Check Disk before loading windows to check the windows file. click yes and then wait for the reboot and check disk to start.
It may be a long process but it will definitely inform you what is wrong with your computer.
Hope this would help you.
Cheers!!
Aug 12, 2010 | Computers & Internet
After i use partitionmagic to merge drive (D & E ) and rename to D the Drive D disappear and wheni check error it shown Error #1520 Externak attribute header mismatch How to solve this problem
This error occurs when the PC hard disk has error(s) and your using particular software as you have mentioned like partition magic. To solve this problem shut down all your applications and running software.
If you are using Windows XP
Go to Start>Run>In the run box type cmd
A black Window will open its called CLI or Command line interface. In this Window run the following command on the C partition CHKDSK /F if the message appears"Check the system next time the system restarts (Y/N) type "y". then type "d:"to enter D partition. When the D prompt (D:) appears type the same check disk /Fix command which is "CHKDSK /F" and hit enter.
Similarly repeat this command for all the partitions.
If the this option statement appears "would you like to force dismount on this volume? (Y/N). Select "Y".
If you are using Windows Vista or Windows 7 then when you perform the first step which is Start>Run>In the run box type cmd before hitting enter in the start menu look for a small black icon named cmd on the top of the start menu. Right click it and select "Run as Administrator" When the black cmd window opens all the steps after that are the same as described above.
Good Luck!
Jul 29, 2010 | Computers & Internet
Raw file system
To fix the problem
Disable the S.M.A.R.T error detection feature in the CPUCool program or similar utility.
Boot to the Windows 2000 or XP installation CD, and at the Startup menu, press R for repair.
In the Recovery Console, type the following:
chkdsk /p
When the CHKDSK process has finished, reboot the computer.
Run the program again.
The error should no longer be reported unless you start using the S.M.A.R.T error detection feature again.
Error occurs with PartitionMagic 8.0
If you encounter Error 1516 with PartitionMagic 8, first run CHKDSK /F on the affected partition. For instructions on how to run CHKDSK, read How to Run Microsoft's CHKDSK from the Command Line. If this does not fix the error, try running PartitionMagic with the /IFC switch, which causes file system errors to be ignored.
To run PartitionMagic with the /IFC switch
Boot from the first PartitionMagic rescue disk.
When you are prompted to insert the second rescue disk, press Ctrl+C to drop to the command (A:>) prompt.
Insert the second PartitionMagic rescue disk and type the following:
pqmagic /ifc
Press Enter.
please go ahead and try the above steps may be it will fix it
Feb 26, 2009 | Symantec Norton Partition Magic-8.0...
Quantum Rz28-e 2.1gb 50 Pin Scsi Hard Drive Rev:j01 Logo
51 people viewed this question
Top Quantum Computers & Internet Experts
Tape-Techie
SirEbrum
terminalcon
Are you a Quantum Computer and Internet Expert? Answer questions, earn points and help others
