Question about AccessData Password Recovery Tool Kit (ftk 1.4x)
Roku password how do i recover my password?
Will I be charged for customer service, device activation, or creating a Roku account?
Roku doesn't charge for help. When you connect the Roku and you want to add a channel there will be an instruction screen pop up telling you how to do it Initial setup will require you to tell it what screen size your TV has, the password for the router if you connect by wireless.
Mar 23, 2018 | Roku Televison & Video
Forgot my CODE, CAN YOU HELP?
Open a browser session on a PC or Mac - Go to www.roku.com/link Log into your existing Roku account or create a new Roku account. And enter the code.
If you forgot your password, you can recover it here. A new password will be sent to the email account listed in your account. If you do not see the email, be sure to check your spam filter.
Dec 28, 2014 | Roku Streaming Stick HDMI Version
How do I set up Wi-Fi?
First, you will need you network password, if password protected. Next, connect your Roku device to the television nearest your router.
Start your Roku device, and wait for the Roku main-screen to appear. Then scroll down to "Settings" and hit "OK" on your Roku remote. Next scroll to "Network" and hit "OK' on your remote, then choose wireless, or wired. If you using an Ethernet cable to connect your Roku, you won't need a network password. If your trying to make a wireless connection, this wireless choice is where you'll need your network password.
Nov 17, 2014 | Roku XDS Streaming Player 1080p Wireless-N...
How can i retrieve my password for my roku so i can hook up a second roku to another tv ?
I believe that each Roku must have its own password. You can go to the Roku site and deregister your current box, then re-register it and your second box with new passwords. Or you can press the reset button on your current box and that will flush your old password and return the box to factory settings.
Nov 08, 2014 | Roku HD Streaming Player
How do I enter my password for roku 2?
Start the ROKU app. Click on the "networking" icon, to show the list of available wireless networks. Click to select your network. Enter the router's password.
Oct 31, 2014 | Roku Televison & Video
I cannot get the roku to connect to my wifi i cannot remember original password so i am trying to use the guest it keeps giving me a code 011 help
You will have to either remember your password, or reset your wifi back to factory settings and set up a new password. In order to clear the "code 011" error, you will have to hold the reset button down on the Roku for at least 30 seconds to do a factory reset. But, don't do this until you get your wifi password issue squared away first.
I hope that helps.
--Robet
Oct 28, 2014 | Roku XD Streaming Player 1080P Wireless-N...
How can I enter password in roku 3 I don't know how it connect and not work
I have created this document that will step you through the setup and also enter your password for your network. Hope this helps you.
Follow these steps to setup your Roku player 1. Connect to your TV
  • Use a HDMI cable. Connect one end to the HDMI port of the Roku player, and the other end to an available HDMI input on your TV.
  • Make note of the TV input used.
2. Power up key components
  • Open the battery compartment and carefully insert the provided batteries into the slots, following the correct battery orientation.
  • Power up the Roku player by connecting the provided power adapter to the Roku player and to an available wall outlet.
  • Turn on your TV and select the correct TV input.
3. Connect to your network
  • If you are using a wireless network, select "Wireless" as your network connection:
  • Select your network from the list of available networks.
  • Enter your wireless network password when prompted. (Note: passwords are case-sensitive)
  • If you are using an Ethernet wired connection, select "Wired (Ethernet)" as your network connection.
4. Complete guided setup
  • Get the latest software
  • Your Roku player will let you know if there is a software update available, and will restart after the update
    is complete.
  • Link your Roku player from any Internet browser
  • A link code should be displayed on the TV screen after restart
  • Using an Internet browser, follow the instructions to link your Roku player to a new or an existing Roku account.
Help for common setup mistakes and solutions
Symptom
Possible causes
Try these!
I don't see any picture on the TV
TV is OFF
Cable loose
Roku is OFF
Wrong TV input
Ensure TV is ON (it's more common than you think)
Check all connectors are snugly in place
Check power adapter is snugly connected, and wall outlet is working
Select the correct TV input
I can not connect to wireless network
Weak wireless signal
Wrong wireless name
Wrong wireless password Wireless name hidden
Move Roku player location (even a few inches may help)
Ensure correct network name selected
Ensure correct password entered
SSID can be hidden, use "Add Network" from wireless network screen
My remote does not work
Not in line of site
Batteries weak
Get closer and ensure there are no obstacles between your remote and the Roku player
Try a fresh set of batteries
Resolving wireless connectivity
If your Roku player isn't connecting to your wireless network, try the following:
Description
Do this
Tips
Repeat guided setup • •
Go to Settings>Network>Wireless•
If "Update connection" is available, select it to refresh your connection
If not, just select your wireless network from the list, enter your wireless password when prompted
If you were previously and just lost connection, you may not need to enter your password again
Passwords are case-sensitive
Restart the Roku player and • your wireless network
Unplug the power connector from • the back of the Roku player
Unplug the power connector from the back of your wireless router
Unplug the power connector from the back of your modem
Plug the power connector back into modem (wait a couple of minutes for it to fully boot)
Plug the power connector back into the wireless router (wait a couple of minutes for it to fully boot)
Plug the power connector back into your Roku player, and wait for the image on your TV
Follow repeat guided instructions above
Your wireless router and modem may be combined as one device
Factory reset the Roku player
From the Roku home screen, sele•ct Settings>Factory reset and follow the instructions
Note: You can also reset the Roku• player using the reset button. Find the reset button on your Roku player, press and hold for 15-20 seconds ( the front LED will rapidly blink a few times)
Factory reset should be used as the last resort, if all other steps failed to recover functionality
After a reset, you will need to relink your Roku player to your Roku account, and setup subscribed channels with username and password, if applicable
If you forgot your password, you can recover it here at this URL:
Forgot Password
Sep 12, 2014 | Computers & Internet
Help finding my roku3 user name and passward
If you check out Roku's site, linked below, and enter your email address you used to create your account with, they'll help you recover your username and password.
https://owner.roku.com/Password/Reset
Hope this helps!
Aug 25, 2014 | Computers & Internet
Have new computer - need to transfer
Your Roku is associated with your network, not an individual computer. Go to support.roku.com for assistance in recovering your password if you do not have it.
Jan 14, 2014 | Cisco Lynksys Dual Band Wireless N Gigabit...
Need serial key for recover my files v4.7.2
Please contact at support@roku.com and provide in detail the product or code module.
Refer to http://www.roku.com/about/privacy
Oct 20, 2013 | Computers & Internet
Computers & Internet Logo
24 people viewed this question
Top AccessData Computers & Internet Experts
Ivan Gavric
ray gallant
Stan Ford
Are you an AccessData Computer and Internet Expert? Answer questions, earn points and help others
